Changing oil at 10k?
Discussion in '2.5 Gen Tundras (2014-2021)' started by MrMitch96, Nov 27, 2019.
  1. Nov 28, 2019 at 7:40 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Every 8000km
    Cpl_Punishment likes this.
  2. Nov 28, 2019 at 9:29 PM
    Lawrence
    Lawrence New Member
    Lawrence
    Tundra 2019
    Thanks beer guy drink up
  3. Nov 29, 2019 at 3:12 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Toyota says every 5k or 6 months for mine since it is a Flex Fuel so that is what I do. :)
  4. Nov 29, 2019 at 7:09 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I’ve been using the same bath water to clean myself for 12 months. Its working fine. Had someone test the water and said I’m good to go for another 2-3 months.
    WILLINH, Zero One Actual and WNY PAT like this.
  5. Nov 29, 2019 at 7:21 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Do you void your warrantee if you do it yourself? Also, if you don't void it, what sort of documentation do you have to keep? Do you need to use a Toyota filter or can you use an equivalent like Mobile 1 filter, Napa or Wix?
  6. Nov 29, 2019 at 7:24 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    I buy new tires every 3 months or 3,000 miles regardless of tread depth.
  7. Nov 29, 2019 at 7:28 AM
    Fred
    Hand Protectors
    I change my underwear once a month, regardless of the skid build up.
  8. Nov 29, 2019 at 8:20 AM
    15whtrd
    15whtrd Mr. Blonde
    Irregardless
  9. Nov 29, 2019 at 8:38 AM
    Fred
    Hand Protectors
    Irregardless of my irregularities.
    15whtrd[QUOTED] likes this.
  10. Nov 29, 2019 at 8:44 AM
    gosolo
    Ray
    NW Oregon
    Or,
    “Crustiness not withstanding”
  11. Nov 29, 2019 at 9:52 PM
    ski
    ski New Member
    I was surprised the 1st oil change is at 10k but all others is at 5k.
  12. Nov 29, 2019 at 10:05 PM
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    5k for me every time.
    Oil is cheap might as well change it often
  13. Nov 29, 2019 at 10:29 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    I thought that if you are just using regular gas and not E85 the intervals could be extended? As for the OP you could always have a sample analyzed:
  14. Nov 30, 2019 at 12:39 AM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    Do it every 10k because Toyota says too.
    Also its easy to remember .. 10k. 20k.. 30k
  15. Nov 30, 2019 at 2:54 AM
    Devcom
    It is still 5k I actually had mine tested and when I had the second oil change done back in April. The results had it on the needed to go stage when I brought it in just on the 5k mark. I have never put E85 in it. Also my truck tows a lot so that could be a factor as well and around the second oil change was after my wife and I moved so more workload was put on the truck.
    4Runner likes this.
  16. Nov 30, 2019 at 3:02 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Assuming your favorite brand name Full Synthethic and a "10K mile" oil fitler then
    Towing use = 5000 OCI
    Non-towing use = 10000 OCI
    Easy peasy...enjoy your Toyotas
  17. Nov 30, 2019 at 4:53 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Good call. I talked to my mechanic about going 12 months 12k when switching to Amsoil and knowing my towing is only a 15ft Jon boat, he gave me the green light. I’m doing my first oil change in a few weeks and planning to send sample to Blackstone. Will ash just from there.
  18. Nov 30, 2019 at 5:12 AM
    patek
    patek New Member
    2019 trd sport
    Toyota manual 2019 anyway a flex fuel 5.7 every 5k regardless if you use flex fuel or 6 months non flex fuel 10k or one years. Ill stick with that 0 w 20 and Toyota filter
  19. Nov 30, 2019 at 7:11 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Every 5k worked with me using Mobil one up to the point I traded ther 1st gen with 265k on the odometer.
  20. Nov 30, 2019 at 1:00 PM
    #50
    HighOctane
    HighOctane New Member
    SFV
    2019 White Tundra
    If the manual recommends every 10k do I change my oil every 10 months? I dont daily drive my tundra and Ive had it for over a year now and my mileage is only 4000. Should I change the oil already? lol
  21. Nov 30, 2019 at 1:53 PM
    #51
    SprinterAE86
    Ian
    If that 4000miles are hard driven miles, yes! If not, just check the level and tap it off.
    I do about 100 miles a year max in my autocross car, I change the oil every 2 years due to 50 miles of it is bouncing off the rev limiter.
    HighOctane[QUOTED] likes this.
  22. Nov 30, 2019 at 1:56 PM
    #52
    Aerindel
    Aerindel New Member
    Montana
    I still do mine at 3k, thats just how I was raised.
  23. Nov 30, 2019 at 2:02 PM
    #53
    HighOctane
    SFV
    2019 White Tundra
    I just do ocassional trails close by my house which is about 20 minutes away and drive the truck once in a while to run errands just to start her up. What would you consider hard driven?
  24. Nov 30, 2019 at 2:04 PM
    #54
    SprinterAE86
    Ian
    Contantly revving at high rpms.
  25. Nov 30, 2019 at 2:43 PM
    #55
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    The engines are the exact same except for the fuel system. If you don't run E85 in your tank, then you can do the 10,000 miles OCI just fine.
  26. Nov 30, 2019 at 2:50 PM
    #56
    Zero One Actual
    I replace my seatbelt every 5000 miles just to be sure.
    P-Factor likes this.
  27. Nov 30, 2019 at 2:53 PM
    #57
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I replace my rear brake light bulbs every 4,000 miles. This includes the 3rd light on the back of the cab. Can never be too safe.
    Zero One Actual likes this.
  28. Nov 30, 2019 at 3:08 PM
    #58
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Change mine every 5k. Oil might be good for 10k but is the filter? Besides oil changes are cheap.
  29. Nov 30, 2019 at 3:26 PM
    #59
    Fred
    Hand Protectors
    I spend $7k a year on ‘mods’, but complain about cost of changing oil early for less than $40 diy.
    I don’t rotate tires, but let the fronts bald and buy new ones. Saves the rear tires.
  30. Nov 30, 2019 at 3:48 PM
    #60
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    I get a new wife every 5 years just to keep my house fresh! :thumbsup:
