Need to find flasher relay 2015 SR
Discussion in 'Lighting' started by Lightfreak, Nov 29, 2019.
  1. Nov 29, 2019 at 3:51 PM
    Lightfreak
    Lightfreak [OP] New Member
    Richie
    2015 tundra SR blue ribbon metalic
    Custom lighting
    Hey people. Where is the flasher relay on a 2015 SR ?
    Front Flashers come on only when the heads and markers are off.
    Turn the heads and parking lights on the flashers don't work.
  2. Feb 18, 2020 at 9:29 PM
    Iahcon
    Iahcon New Member
    2014 Limited Tundra
    I'm having the same problem after installing 2020 factory LED headlights on my '14 Limited. Anyone have any ideas?
  3. Feb 18, 2020 at 9:41 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Where did you get the harness from? Maybe ask @iHacker for a conversion harness.
  4. Feb 18, 2020 at 9:45 PM
    Iahcon
    Iahcon New Member
    2014 Limited Tundra
    I'll have to ask the individual that I bought it from. I think there's a good chance it came from Headlight Revolution. Thanks for the advice!
  5. Feb 18, 2020 at 10:02 PM
    Iahcon
    Iahcon New Member
    2014 Limited Tundra
    So I just went to HR's website and found this.
    I'll give it a shot and hopefully it will work and not fry anything..
    "COMPATIBLE: Though the harness itself is completely plug n play, due to the fact that the new headlights use a 7443 front turn signal bulb inside the lights versus the original 3157/4157 - you will just need to re-pin the connector coming from your truck in order to make the blinker work properly. Simply swap the purple & black wire and good to go."
  6. Feb 18, 2020 at 10:58 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Exactly......
    If you have a 2 pin connector you will need to repin it as seen at 3:45 in this video:
    https://www.youtube.com/watch?v=xPZbmI4QMQg
  7. Feb 21, 2020 at 2:58 PM
    Iahcon
    Iahcon New Member
    2014 Limited Tundra
    That fixed it!
    Thanks for the info MJoeP
    MJoeP likes this.
