da Green Thunder Mod Garage
Discussion in '2.5 Gen Builds (2014-2021)' started by Green Thunder, Oct 24, 2019.
  1. Oct 24, 2019 at 5:10 PM
    Green Thunder
    Green Thunder [OP] Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    I'm not a master mechanic, nor do I have the facilities to do anything crazy. I do love adding accessories to make the truck more mine...so I'll document my various items here. Feel free to ask any questions...
    This is Green Thunder as of August 2023. Our new trailer is the latest accessory. Loaded with water and gear the trailer is about 7,200lbs. I'm right at my rear axle capacity so will have to watch my loading carefully. Transmission temps were normal on level ground, but climbed quickly on long hills. There is definitely a cooler in my future.
    Mods and Accessories:
    1. Lock’er Down 1/2 size console lock box (here)
    2. Full de-badge (here)
    3. ESP under-seat storage (here)
    4. Scan Gauge II (here)
    5. Toyota tow mirrors (here)
    6. Wireless charger (here)
    7. SDHQ ABS sensor shields/guards (here)
    8. Rigid amber fog light covers (here)
    9. Plasti-Dip center console (here)
    10. AJT interior de-chrome covers (here)
    11. Northstar AGM 27F gel battery (here)
    12. Fog light jiggle mod (here)
    13. Toyota tail gate lock (here)
    14. Disable-in-Reverse harness (here)
    15. HKB Voltage fuse (here)
    16. JLT Catch can (here and here)
    17. BFG A/T KO2s tires in 275/70 R18 (here)
    18. Washer fluid reservoir mod - A GT Original! (here)
    19. Desert Does It Front Multi-mount Panel (here)
    20. Carbon filter removed from air intake
    21. Diamondback HD (here and here)
    22. Victory 4X4 Molle Panel (here)
    23. Removed the TRD exhaust (here)
    24. Wire mesh over the cabin air intake (here)
    25. Dash Cam (here)
    26. Tundra tailgate lettering (here)
    27. Roadmaster Active Suspension (here)
    28. Desert Does It Seat Jackers (here and here)
    29. Rago Dash Mount (here)
    30. ARB Twin Air Compressor; in work (here)
    31. Victory 4X4 Console Mole Panel; in work (here)
    32. Weather seal Center Console Squeak Treatment (here)
    33. Baja Design lights on CBI Offroad Ditch Light Brackets (here and light output pics here)
    34. CBI Offroad sliders (here)
    Mods and Accessories - Pending or Under Consideration
    • Console switch mount and rear window switch...waiting for a few more ideas to use up the additional switch locations.
    • Transmission cooler...waiting for a holiday sale.
    • AJT Steering control repin...purchased, waiting to install
    Mods and Accessories Removed
    • Punisher hood decal: Removed to do something new (#17)
    • Battery Holder: Damaged due to leaking battery (#83)
    • N-Fab cab steps: Finish started to peal (#29)
    • Interior Tundra decal (#58): Color match wasn’t close enough, especially when I added more dechrome accessories from AJT
    • Weather Guard truck box (#26)
    • American flag decals (#4)
    • Desert Eagle Catalytic shield (#88) - Took off to pull a tranny fluid sample and didn't have the energy to put back on. Also like letting the transmission get more air around it for cooling.
    • Rago small bed mount and flag holder (#82) - Doesn't work with the Diamondback cover
    • LED reverse lights (#39) - These cheap POS keep falling out and rattling round inside my light cover assembly. So junked them.
    Oil analysis thread: https://www.tundras.com/threads/green-thunder-oil-analysis-thread.94464/
    MTRock, bulldog93, C.I. and 16 others like this.
  2. Oct 24, 2019 at 5:11 PM
    Green Thunder
    Washington
    First mod...adding a lock box to the center console. Installed this Lock’r Down half-size box yesterday. Very happy with the quality and fit. I have a few mods to the box planned, but that’s for another day...
  3. Oct 24, 2019 at 5:13 PM
    Green Thunder
    Washington
    Next mod was to debadge the truck. I love a clean look, so spent some time today with the wife’s hair dryer and plastic trim shims to pry everything off. Gone are the “Tundra”, “iForce” and “4x4” badges. Then a good wash to get all the grime off...
  4. Oct 24, 2019 at 5:16 PM
    Green Thunder
    Washington
    Edit: Removed the flags in May, ‘22. A few stars were wearing off after all the washing and I didn’t want to age the paint too long and create a shadow.
    And finally, when it was all dry and clean I applied the flags! They’re basically where the iForce badges used to be
    That’s it for now. I’ve got another decal coming for the hood scoop (it might as well serve a purpose) and a lock box for under the rear seat (dealer installed next week). After that, I need to find some steps, install my dash camera and maybe find a place for the Scan Gauge II. And the mods to the center console box
  5. Oct 24, 2019 at 5:31 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Welcome from NCal, nice truck
    Green Thunder[OP] likes this.
  6. Oct 24, 2019 at 5:45 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    That is pretty nice.
  7. Oct 24, 2019 at 7:16 PM
    mr_clark
    mr_clark New Member
    2018 Black Tundra Limited
    Freaking love that color. Haven't seen that at any Toyota dealer around here.
    Ely010606 likes this.
  8. Oct 24, 2019 at 8:34 PM
    AYANG
    AYANG New Member
    Ontario, CA
    2016 Black Tundra Crewmax
    Looks great!
  9. Oct 24, 2019 at 11:31 PM
  10. Oct 28, 2019 at 6:54 AM
    freedomoftime
    freedomoftime Real Estate Advisor
    Buddy
    Washington State
    2020 Tundra TRD PRO Army Green
    AMP Power Step Running Boards - 10.23.19 Tinted front windows to match back - 10.20.19 Tinted windshield (70) - 10.20.19 Flag Decals on front quarter panels (matte black) - 10.23.19 Tailgate insert with USA flag - 10.23.19 Nitto Grappler G2s 285/65/18 - 10.20.19 Toyota factory Tri-Fold Tonneau Cover - 10.20.19
    Love your AG Tundra! I just got one myself out here in Washington State. I just added my flag decals.
  11. Oct 28, 2019 at 12:19 PM
    Dirtfiend
    Dirtfiend New Member
    So.OC
    2019 SSM 5.7 Crew Max 4x4
    Bilstein 6112 front (2.5")/5160 rear Total Chaos UCAs Toytec Shackles 1" Method Roost 18x9 Falken Wildpeaks 295/70 R18 Carven Cat Back Exhaust Baja Designs Squadron Fogs (Amber) Stubby Antennae Blackout Badges/ Tailgate Insert Front Tint (20%) K&N Air Filter Gate King adjustable lift gate Color matched grille/bulge
    freedomoftime likes this.
  12. Oct 28, 2019 at 12:24 PM
    freedomoftime
    Buddy
    Washington State
    I ordered them from a guy on the "Tacoma World" website. ** see attached picture ** He's really good and ships quick.
    His username is: CBoy808 and his email is sales@stickerhi.com - The ones I got are matte black (not glossy). Personal preference.
    bulldog93 likes this.
  13. Oct 28, 2019 at 12:26 PM
    Dirtfiend
    So.OC
  14. Oct 28, 2019 at 12:47 PM
    TheBeast
    TheBeast The Beach
    looking good. which dash cam are you going with ?
  15. Oct 28, 2019 at 10:03 PM
    freedomoftime
    Buddy
    Washington State
    Hey Beast. What do you mean? I'm not following...
  16. Oct 29, 2019 at 7:59 AM
    Green Thunder
    Washington
    @freedomoftime I think @TheBeast is asking me about my dash cam.
    I just have the Voifo A119S. It’s a cheaper unit, but had a lot of good reviews online. I’ve had it for about a year now and like it. My guess is it won’t last much longer and when it dies I’m going to get a nicer unit. Possibly one with a rear camera if I can find a place to mount it. Kind of difficult on the Tundra since the whole rear window goes down.
  17. Oct 29, 2019 at 8:03 AM
    Green Thunder
    Washington
    Edit: Removed. Looked great, but want to go another route
    Last night’s addition...
    Overall I like it, but did hope it would take up more of the scoop. Guess I could have gone with the larger decal. I’ll probably pull it off in the spring as I’ve already got another idea for something that I think will fill out the area better.
  18. Oct 29, 2019 at 7:45 PM
    Green Thunder
    Washington
    Dealer installed the lock box from the Toyota Accessory catalog today. Looks pretty sharp and doesn’t rattle. Not as deep as I’d hoped, but it will work. Fit and finish is nice, but the gauge is pretty thin.
  19. Oct 29, 2019 at 8:52 PM
    freedomoftime
    Buddy
    Washington State
    What is that part number for Toyota for the “gun safe”? :)
    Also, what did it cost + the install? If you’re cool sharing....
  20. Oct 29, 2019 at 9:18 PM
    Green Thunder
    Washington
    No clue on the PN...it was in the catalog. I’ll see if I can find a PN tomorrow.
    As for cost, it was part of the sale for my truck. I think list was $960 installed and they took $300 off. So $660 installed.
    freedomoftime[QUOTED] likes this.
  21. Oct 29, 2019 at 9:26 PM
    freedomoftime
    Buddy
    Washington State
    thanks! That seems super reasonable. Now to the real question..... HYPOTHETICALLY Can it hold an AR and a shotgun?
  22. Oct 29, 2019 at 11:11 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    I dig THE GREEEEEENNNN THUUUUUUNNNNNDDDAAAAAAAAAAR!!!! Name
  23. Oct 29, 2019 at 11:19 PM
    freedomoftime
    Buddy
    Washington State
  24. Oct 30, 2019 at 4:33 AM
    Green Thunder
    Washington
  25. Oct 30, 2019 at 7:07 AM
    freedomoftime
    Buddy
    Washington State
  26. Nov 5, 2019 at 4:52 PM
    Green Thunder
    Washington
    Edit: Truck box was great, but didn’t like the look or needing two people to remove it. Sold it and replaced with the Diamondback cover and Victory 4x4 molle panel
    Needed more storage, so Weather Guard to the rescue. I have a box of theirs that sits inside the bed, but didn’t want to drill into the bed or have something I couldn’t remove easily. So...wife is pissed (again).
    A5E76165-BDF7-4AE9-8836-C41B044D779C.jpg C353B24E-87C7-46D5-97D5-03FA4A211DD5.jpg
  27. Nov 15, 2019 at 10:13 AM
    Green Thunder
    Washington
    Time to add the scan gauge...I love this thing. Have used it in every vehicle I’ve owned since I bought it back in the 2010 timeframe. Took me a few minutes to program it for the transmission temp, but now it’s ready. Looking forward to having this when I’m towing this summer given that this truck doesn’t have the tranny cooler.
  28. Nov 22, 2019 at 8:42 AM
    freedomoftime
    Buddy
    Washington State
    Did you ever get your flag decals put on? I'd love to see em.
  29. Nov 22, 2019 at 4:59 PM
    Green Thunder
    Washington
    Edit: Removed after two years as the finish was pealing. See pics below.
    Enter the N-FAB PRT0784CC-TX steps. The bar tucks up nicely under the body, steps are big and have a good no-slip surface. Made of aluminum, so they’re light weight. The best part is a “damaged box” offer popped up for $130 off MSRP, so I took the risk. Sure enough, the box was roughed up...but the steps were in great shape. I’m happy...
    1B928AF0-92E5-4005-BE91-5AE0BB4CAF23.jpg 72C91E34-2E76-450B-AF83-9369BBB2F2B1.jpg 7A122F40-0E8C-4373-A299-9828C864404D.jpg FAB19AF1-CF62-4654-A604-AF67E702C26F.jpg
    March 2022…the finish on the end caps started to peal off on three of the four corners. So off them come.5A3805A5-68D4-42DE-A214-616C136CCCB8.jpg
  30. Nov 22, 2019 at 6:37 PM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    more like... Schwingggg....
    Excuse me for a few minutes....
    Damn I'm so jealous. Looks awesome. Congrats!!
