Standard wiper too Intermintin 2020 Tundra how too
Discussion in '2.5 Gen Tundras (2014-2021)' started by glock37, Nov 5, 2019.
  1. Nov 5, 2019 at 1:01 PM
    glock37
    glock37 [OP] New Member
    Brother got a 2020 Tundra 4 door 8 ft bed and didnt relize it didnt have intermintin wipers how do you make it intermintin ?
  2. Nov 5, 2019 at 1:20 PM
    gdisarray
    gdisarray Short term member
    MGM SR5 TSS
    According to Toyota's web site where you build your own truck it shows ALL models have intermittent wipers. Starting with base model SR. Go to their site and click "Compare Models" under Tundra for chart. Is he looking at the upper right steering wheel stalk? Or the manual? Lol
  3. Nov 5, 2019 at 6:08 PM
    glock37
    I have not seen the inside truck
    ill have to ask him again
  4. Nov 5, 2019 at 6:36 PM
    gdisarray
    MGM SR5 TSS
    Ooops, my bad. Had surgery this morning and was still under anesthesia , lol
    SR's don't have intermittent and it looks like not available.
    Hopefully someone will pop in here that knows what they are talking about! :anonymous:
    But the SR5's are mostly SR's with convenience packages so it may just be changing the stalk.
  5. Nov 5, 2019 at 8:00 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I am interested to hear how this ends up. The Tacoma’s are the same way, my buddy got a base model and no intermittent wipers. Blows my mind that that’s where Toyota chose to cut cost.
  6. Nov 6, 2019 at 4:49 AM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    My SR loooooooooooooong bed didn't have intermittent wiper or fog light stalks.... so I added them. Truck recognizes these and they work fine.
    JH5370, gdisarray and Pudge like this.
  7. Nov 6, 2019 at 5:49 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    I'm confused about the fact that the SR5 is either gone for every truck except the DC LB or was renamed to the Standard Package...
  8. Nov 6, 2019 at 6:45 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
  9. Nov 6, 2019 at 11:28 AM
    gdisarray
    MGM SR5 TSS
    FYI you shouldn't have to pull steering wheel. There are two screws behind wheel on lower panel (rotate wheel quarter turn one way to access one, turn other way for access to other. ) Then top and bottom pop off.
  10. Nov 21, 2019 at 8:26 PM
    Trebor57
    Trebor57 New Member
    Rob
    Sacramento, CA USA
    2018 Toyota Tundra SR Double Cab - 2-wheel drive
    Like what @gdisarray said, you don't have to pull the steering wheel. I only had the steering wheel pulled to change the switch out to add Fog lights as that could not be done as easy as the wiper switch.
