ICON COILOVERS
Discussion in 'Suspension' started by JaKo, Nov 20, 2019.
  1. Nov 20, 2019 at 6:21 AM
    JaKo
    JaKo [OP] New Member
    Howdy yall, new member here and currently building an 2006 DBL cab SR5 4X4. I love the truck and decided to install the ICON leveling coilovers. the issue I'm having is the upper ball joints seem to be at an extreme angle. is this normal ? ICON.jpg
  2. Nov 20, 2019 at 6:23 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal, JaKo!
    Just stand by, because we have an awesome group of 1st gen owners that will help you out momentarily.
    In the meantime, I hope you're enjoying the forum so far!
    bmf4069, KarmaKannon and TX-TRD1stGEN like this.
  3. Nov 20, 2019 at 7:03 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Welcome!
    A couple of things
    1: take a picture of your overall front suspension on that side from the front, seeing both arms.
    2. I see a lot of collar above the coil spring, it might be turned up way too high
    3. Welcome to the game :) you need new uca’s
  4. Nov 20, 2019 at 7:19 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Is this before or after getting an alignment done? If it's before the angle may get slightly better if you raised it less than 2-2.5".
    Or like @Hbjeff said get new UCAs and you'll be good.
  5. Nov 20, 2019 at 7:22 AM
    JaKo
    This is the angle before an alignment and 285/75R16s
  6. Nov 20, 2019 at 7:35 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wouldn’t waste money on alignment before getting uca’s. You’ll need another one after those
  7. Nov 20, 2019 at 7:41 AM
    JaKo
    I've seen plenty of OEM uca's used with this kit. I cant be the only person who has this problem.
  8. Nov 20, 2019 at 8:37 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    How much lift did you get? On stock arms I wouldnt recommend more than 2". Got a pick of the whole truck?
    seth419 and Hbjeff like this.
  9. Nov 20, 2019 at 9:58 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    From that pic it looks like they are cranked up to high. You are bottomed out on the threads and the UCA is at an extreme angle as well. Like @Darkness said, 2" is the sweet spot on stock UCA's.
    flyfisher and Hbjeff like this.
  10. Nov 20, 2019 at 10:08 AM
    JaKo
    Darkness likes this.
  11. Nov 20, 2019 at 10:21 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    UCA angle doesn't look as bad in those pics. Do you know how much lift you got? Is the front end higher than the back?
  12. Nov 20, 2019 at 10:22 AM
    FirstGenVol Brake Czar
    2002 AC
    If you keep it around 2" of lift(how the ICON's ship) you should be able to use your stock UCA's. Or so it's been reported here.
  13. Nov 20, 2019 at 10:30 AM
    JaKo
    I'm at 2.5 lift currently I'm going to adjust it down after the tires are mounted and see how it changes the angle.
  14. Nov 20, 2019 at 10:34 AM
    2002 AC
    That should help. But either way, if those are old ball joints I would consider replacing them. Were those ICON's used? They do not look new.
  15. Nov 20, 2019 at 10:36 AM
    JaKo
    The BJ's were replaced with Toyota units and the coilovers are rebuilt from icon.
  16. Nov 20, 2019 at 11:35 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That angle seems pretty harsh still, not as bad as the first pic but comparing the upper ballpoint to the pivot point on the arm there is still a big angle.
    See how it goes when you lower the coilover and get aligned. I think the balljoint looks a bit odd as well, I dont recall having that much distance between my upper arm and spindle but it's been 9 years since I had fa story uppers.
    Maybe save some cash and look for SPC arms on black Friday.
    Hbjeff likes this.
  17. Nov 21, 2019 at 6:24 AM
    JaKo
    So this is the end result, the front is about half an inch too high but the stance is great IMO.
    So it looks like the upper BJ angle is still sharp so I'm hoping after I adjust the coilover today the angle will correct.
  18. Nov 21, 2019 at 6:32 AM
    2002 AC
    Your upper control arm is touching your tire. I assume you saw that. Definitely crank those things down and let us know how it sits. The truck looks great though!
    FrenchToasty and Darkness like this.
  19. Nov 21, 2019 at 6:39 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    First off your truck looks fantastic, love a clean first gen! Like it’s been said you’ve got a ton of threads above the collar. I know on my second gen and my wife’s FJ the “max” threads above the collar is supposed to be around 2”. May look into going to a higher spring rate to get more lift with less adjustment. Those springs may be a bit tired.
  20. Nov 21, 2019 at 9:57 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I may be a bit biased but that truck looks killer!!! Is there a block or anything lifting the rear end? From that pic it looks level. Did you adjust the coils at all or did Icon send them back set up like that after they serviced them?
  21. Nov 21, 2019 at 10:25 AM
    JaKo
    Thanks !! The rear is stock leaf's no block with 5100 Bilstein 0-1 shocks.
  22. Nov 21, 2019 at 4:35 PM
    Professional Hand Model
    Fred
    Hand Protectors
    How is the ride with this heavy angle? Are we worried about high speed failure and potential crashes?
  23. Nov 25, 2019 at 2:52 PM
    JaKo
    So I spent the weekend adjusting the coilovers they were maxed out so I took them down an inch and the ride improved instantly. After the truck as on the ground the gap between the upper BJ and tire is wider and he BJ itself is less positive cambered. TUNDY 3.jpg
    All and all I like the way the truck sits but now I've gotten a weird brake pedal shudder at slow rolling stops.
    Darkness and Drfarquad like this.
  24. Nov 25, 2019 at 3:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Now they angle looks much more normal!
  25. Nov 25, 2019 at 3:15 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    All of that looks better!
  26. Nov 25, 2019 at 3:19 PM
    2002 AC
    Are you sure it's not the ABS kicking in at low speeds? I had that issue. Most likely caused by a damaged tone ring on the CV.
  27. Nov 25, 2019 at 7:03 PM
    Drfarquad
    Drfarquad New Member
    Bobby
    Milford
    2005 Tundra Limited DC
    OME 3 inch lift level, UCAs, Icon AAL
    I have the same truck and have been debating buying icons for the front, I need new shocks bad.
  28. Nov 26, 2019 at 6:12 AM
    JaKo
    I replaced the CV axles when I did the ICONs, I'm also going to do a diff drop and see if that helps. I think the ABS ring being at an angle may have something to do with it.
  29. Nov 26, 2019 at 6:15 AM
    2002 AC
    Pull your ABS fuse and see if the problem continues. If it does then you know it's something else. In my case, after adding the ICON's I started having ABS activation at low speeds. I replaced the wheel speed sensor and that didn't fix it. Then another member mentioned it had to be my tone ring on the axle. I pulled the ABS fuses and the problem went away.
    Darkness and JaKo[QUOTED][OP] like this.
  30. Dec 2, 2019 at 11:29 AM
    JaKo
    Thanks !!! I'll see what happens
