Started with secondary pump issues now has become something else.
Discussion in '1st Gen Tundras (2000-2006)' started by Jcow1980, Nov 17, 2019.
  1. Nov 17, 2019 at 4:04 PM
    Jcow1980
    Jcow1980 [OP] New Member
    Joshua
    2006 Gray Toyota Tundra X-SP
    I have a 2006 Toyota Tundra 4.7l V-8 with about 150,000 miles on the engine. I was driving to work and my truck begins to lose power and wouldn't go into passing gear. I could ease into the gas and it would gain speed to about 60 mph but was sluggish and the engine light began to flash. I get it home and ran the codes. It was p0305 cyl 5 misfire, p2441 secondary air injection system switching valve stuck closed bank 1, p1445 secondary air injection system switching valve stuck closed bank 2, p1442 secondary air injection valve stuck open bank 1, p0307 cyl 7 misfire, p0300 random multiple cylinder misfire, p2757 torque converter clutch control solenoid circuit, p0301 cyl 1 misfire. My dad told me he thought I was in limp mode. Thought the secondary pump was causing the engine to drag. I bought the pump, intermotor, 2 air switching valves and 2 vacuum switching valves. As I replaced the parts I saw where the vacuum hoses were destroyed and not attached between the vacuum valves and the switching valves. Also the air tube on the passenger side wasn't attached to the switching valve. Although I found these issues I still used all the new parts when putting everything back together. I replaced the intake and everything in that process. I reset the codes and crank the truck and it sounds like its running good. I go to drive it down the road and it still isn't gaining speed correctly and the engine light is flashing again. I read the codes and I'm getting p0300, p0301, p0303, p0305 and p0307. It says its misfiring on all the driver side cylinders. Is this about to become a timing issue or could it be something simpler than that?
    Prostar 190 and Pinay like this.
  2. Nov 17, 2019 at 4:11 PM
    Professional Hand Model
    Fred
    Hand Protectors
    @empty_lord
    Jcow can you post up some pics of these destroyed hoseson the engine?
  3. Nov 17, 2019 at 4:24 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Say what?
  4. Nov 17, 2019 at 4:25 PM
    Jcow1980
    Joshua
    I'm trying to upload what I have but I didn't take very detailed pics.
  5. Nov 17, 2019 at 4:51 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Sounds like that hood needs to be opened more with all those hose issues.
    I would be suspecting the driver side CAT were it mine.
  6. Nov 17, 2019 at 5:03 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Read it again and you will see the missing space
  7. Nov 17, 2019 at 5:09 PM
    Welcome from Ohio.
  8. Nov 17, 2019 at 5:10 PM
    empty_lord
    05 rollover special
    I see it now
  9. Nov 17, 2019 at 5:19 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Has any standard maintenance been done like plugs, filters, oil changes? I agree with BubbaW looks like the hood needs to be opened more. Give it a good visual going over along with any over due maintenance.
  10. Nov 17, 2019 at 5:43 PM
    Jcow1980
    Joshua
  11. Nov 17, 2019 at 5:49 PM
    Jcow1980
    Joshua
    I would also agree that the hood needs to be opened more. I've only had the truck a couple months. I did an oil change when I got it because I didn't know the maintenance history. So the vacuum hoses I mentioned are pictured. I know it doesn't give an idea where they were located but I've determined they were probably damaged from heat that came from the air tube that was attached on the passenger side air valve. Its pictured as the top one in the 3rd pic. Notice the discoloration? That's from where the air tube wasn't bolted on. I haven't replaced the plugs or coils or any filters yet.
  12. Nov 17, 2019 at 5:55 PM
    empty_lord
    05 rollover special
    Those hoses go to the switching valves. I’m not sure what would happen if they fail, never seen that happen before.
    A code and limp
    Mode obviously. But don’t think it’d cause a misfire.
  13. Nov 17, 2019 at 5:59 PM
    Jcow1980
    Joshua
    I replaced them with new hoses and replaced the switching valves
    empty_lord likes this.
  14. Nov 17, 2019 at 6:01 PM
    empty_lord
    05 rollover special
    Inspect all the wiring on the truck first off. Mouse or something chewing the wrong wire can cause a lot of issues. Past that I would try a compression test on the 4 misfiring cylinders. Make sure they’re good before dumping money on parts you may not need.
    Also there’s ground wires on the engine. Make sure they’re attached.
    speedtre likes this.
  15. Nov 17, 2019 at 6:06 PM
    Jcow1980
    Joshua
    When I replaced all the secondary air pump, intermotor, 2 air switching valves and 2 vacuum switching valves, that's when I found the damaged vacuum hoses and replaced them while putting it all back together. The switching valve codes and air bank codes went away as well as the torque converter code. But its still throwing the code for all the odd number cylinders misfiring randomly
  16. Nov 18, 2019 at 6:52 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    What is the fuel pressure at?
  17. Nov 18, 2019 at 7:01 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    For some reason, after resetting the ecu everytime I gut that p2441, it just fixed it self overtime. 265,000 miles and did not replace any part back there.
  18. Nov 19, 2019 at 5:02 AM
    Fred
    Hand Protectors
    Kinda like working out the cob-webs up in those hoses and chambers so that engine/ecu mojo is restored.
    SprinterAE86[QUOTED] likes this.
  19. Jul 21, 2022 at 4:30 AM
    Brynden29
    Brynden29 2002 Tundra Limited
    Brynden
    Georgetown, Texas
    2002 Tundra Limited
    Did you fix this issue? What was the cause?
  20. Jul 21, 2022 at 6:15 AM
    shifty` Our private little trip to hell
    Thinking you may be out of luck here. We get so many fly-by-nighter posters here who only come b/c they have an issue. Then solve it. And never bother to say what fixed the issue, and this is looking like another one of those:
    Brynden29[QUOTED] likes this.
  21. Jul 21, 2022 at 6:34 AM
    Brynden29
    Brynden
    Georgetown, Texas
    2002 Tundra Limited
    That’s pretty sad. Helping out is what we should all be about.
    Bilgepump and BubbaW like this.
  22. Jul 21, 2022 at 6:58 AM
    Bilgepump
    Bilgepump New Member
    '06 Sequoia Limited 4.7L VVT-i 2WD
    All Stock
    Sounds like he threw a lot of unnecessary parts at the SAIS...maybe just needed vacuum hoses....
