Audio upgrade suggestions, 2013, 2nd Gen
Discussion in 'Audio & Video' started by IndyRCSB, Jul 22, 2019.
  1. Jul 22, 2019 at 6:52 PM
    IndyRCSB
    IndyRCSB [OP] New Member
    2013 RCSB
    Leather interior, wheels, tires, suspension
    I had a local shop give me a price to upgrade head unit, dash tweeters, door speakers and install a powered sub under the seat. Quote was for $2,300. All Alpine components, the four speakers were R-series. Labor was $690.
    That’s more than I want to spend. I’m thinking perhaps install the four speakers myself and see how that helps. Maybe do the Alpine powered sub as well but keep the oem HU?
    Open to suggestions to get a better sound without breaking the bank. Maybe someone has had the similar question. My truck is a Regular cab, SR5. Thanks.
  2. Jul 25, 2019 at 10:48 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    IndyRCSB[OP] likes this.
  3. Jul 26, 2019 at 3:28 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I 2nd James. Sent you a PM with James` email.
  4. Aug 18, 2019 at 8:24 PM
    AZ_BO
    AZ_BO New Member
    Ricardo
    Colorado Springs, CO
    2018 Tundra SR5
    1) Leveling kit 2) Sound system upgrade 3) Color matched grill 4) Leather seat covers
    Would love to hear what he tells you. Subscribed.
  5. Aug 18, 2019 at 8:37 PM
    e30cabrio
    West Valley, Phoenix, Az.
    2010 Crewmax, 2013 Sequoia Limited
    Sequoia LED Headlights! D.T. L.T. headers, dual exh., BDX, S&B intake, 2018 seat skins.
    My 2010 has a Pioneer NEX 8200 running a 4 channel amp to the doors, speakers are from a local place, called Robot Underground, seriously amazing an adapter running out to the JBL dash speakers and a Pioneer mono amp running James' 10" sub. Sounds great. I did all the labor. I'm about 1400 all in.
  6. Nov 13, 2019 at 4:44 PM
    Jrharvey02
    Jrharvey02 New Member
    With your 8200, are you able to see some of your vehicle info (tire pressure, temps, etc.) via the pioneer?
  7. Nov 13, 2019 at 4:51 PM
    e30cabrio
    Jrharvey02 likes this.
  8. Nov 13, 2019 at 4:56 PM
    Jrharvey02
    Cool, I’ve got the same head unit and wanted this feature. Got any ideas of what it takes to install this maestro rr? I already have working steering wheel controls, which I thought Maestro was for. Figured since you knew enough to install your system, which is damn near identical to mine, you may know this. Thanks
  9. Nov 13, 2019 at 5:03 PM
    e30cabrio
    I did the steering wheel controls with these:
    https://www.crutchfield.com/p_120ASWC1/Axxess-ASWC-1-Steering-Wheel-Control-Adapter.html
    https://www.crutchfield.com/p_120708114/Metra-70-8114-Steering-Wheel-Control-Harness.html
    I assume the maestro wires into the HU & then to the OBD2 port but I am not missing anything from the truck so did not care about doing Maestro.
    A quick search found this:
    http://images.idatalink.com/corporate/Content/Manuals/RR-TOY/ADS-RR(SR)-TOY01-DS-IG-EN_20190703.pdf
    Mozman and Jrharvey02 like this.
  10. Nov 13, 2019 at 5:24 PM
    Jrharvey02
  11. Nov 13, 2019 at 5:28 PM
    e30cabrio
    It offers nothing I care about. If I had a 3rd gen with TPMS and other needed integration and other features it would be different but on my 2010 no need.
  12. Nov 13, 2019 at 5:39 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    New speakers will net very little if anything. A new 50 watt HU would net much more, then install some new speakers.
