Ordered 5100's
Discussion in 'Suspension' started by Zum, Mar 24, 2019.
  1. Mar 24, 2019 at 1:44 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Decided to go the 5100 route all around.( they were cheaper than the 4600s? online)
    Really unsure if my shocks are bad but at 260000km(160k miles) I'd imagine there weak.
    Still debating on which setting, either the lowest or middle. I measured ground to wheel well and have 36.75" up front and 39" in the rear...with cap on, 275 65 18 tires.
    Should I have order any bushing as well?...talked to the manger at my Toyota place and said he has never seen the bushing bad enough to change out in the front.
    I'll do the rear myself unsure if I want to tackle the front
    HappyGilmore likes this.
  2. Mar 24, 2019 at 2:40 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    160k? Man those shocks were due for replacing 100k miles ago lol.
    Unless you have play or bad squeaking in the front end...drive it till the wheels fall off.
    DiegoC and Hbjeff like this.
  3. Mar 25, 2019 at 3:10 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Bought the truck used so don't know what it felt like newer.
    Always had a truck though but all older and road like old trucks with big retreads on them.
    Kinda treated myself to this truck, I think these new 5100s will be at least as good as what's on it now.
    If I go on the middle setting I'm thinking I'll get a light weight helper or add a leaf...the leads probably could use some help as well.
  4. Mar 30, 2019 at 12:07 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Puralator left a note saying I missed them,at lunch....have to wait till Monday.
    I left work an hour early Friday followed 3 different trucks but the didn't get the truck I needed. Id wait till they pulled over to deliver something...didnt cut them off or nothing
  5. Apr 1, 2019 at 12:00 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Picked them up today...one of the adjustable shocks didn't have the kit in the box. Called 4wheelparts they will get one out to me soon.
    If I go middle setting I'm thinking I'll want a AAL or helper spring. Only have a little over an inch rake now,wouldn't want any less.
    r1-superstar likes this.
  6. Apr 5, 2019 at 7:30 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Post up pics once you get them installed!
  7. Oct 25, 2019 at 12:33 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Finally going to install these Monday...middle setting unless I change my mind to the lowest setting. Have new wildpeaks to install as well 265 70 18...just abit taller and narrower.
    Thinking it's going look nose high as theres 1.5"s difference right now and seems even.Going to need new leaf pack so can correct that issue with that,if need be.
  8. Oct 28, 2019 at 1:04 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Finally on,5100s all around,middle clip, no shims,nothing but worn leafs in the rear.
    I'm 38.5" front , 39.2" rear, raised me 1.5"s more really but new tires added .5"s.
    Good for now, when I put new leafs in the rear I might add a shim(2)but don't think I will go to top clip. Haven't driving far enough to say much about the ride but so far seems as good as stock.We have pretty rough patches up roads here anyways.
    parker44, usaf.2012, pop's and 2 others like this.
  9. Nov 1, 2019 at 10:38 PM
    StrmTroop29
    StrmTroop29 New Member
    Anthony
    How’s the ride? Looks good
  10. Nov 1, 2019 at 10:45 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Looks awesome
    Zum[QUOTED][OP] likes this.
  11. Nov 2, 2019 at 6:23 AM
    Zum
    Zum [OP] New Member
    NS Canada
    Hasn't been a week yet but really liking my decision. Between tires and shocks, the front raised approximately 2"s, it really changed how the truck "feels". Steering seems "smoother" almost easier but that is probably due to the height increase or tire compound more than the shocks. I cant say i notice much difference(better/worse),over pot holes or bumps on pave but my decision for 5100s was more for leveling and not performance.Dont get me wrong, I don't want them to ride like crap either. I'm not a hard core 4x4er, mostly pave, gravel,fire/sled roads and feilds. Plan on leaving in a bit to see who is getting all the deer in the backwoods, so maybe 200 miles this weekend, probably some wash board and lots of gravel, be a good test.
    I'll keep people posted on how they feel...good or bad.
  12. Nov 2, 2019 at 6:24 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    Airbags in the rear would work out for you better than springs. 6D70B2B7-39A0-42DB-AA67-EC5376C5CFD6_1_201_a.jpg
    Zum[OP] likes this.
  13. Nov 2, 2019 at 6:41 AM
    Zum
    Zum [OP] New Member
    NS Canada
    Bags would be better, but my springs are shot. Posted a picture somewhere on here and they were flat at best. I can live with it for now but springs are in my future. Hopeing that with the weight I no longer carry back there it will be good.
  14. Nov 2, 2019 at 10:32 AM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    I think the rear leafs on these trucks all look flat regardless of age or miles. When I did my bilsteins 5100s, i went middle setting and it was perfect. I added a fiberglass topper and noticed it definitely weighted the back down and was way closer to level. Once we got our TT and w/the WDH i was always nose high, airbags were one option, but I also wanted to lift the back to have a factory look w/rake, so I went with the ToyTec shackles. They have two settings 1" and 1.5" lift. I went with the 1.5" to give the entire truck the same lift and getting back to almost factory rake. Just another option for you to consider.
    Zum[OP] likes this.
  15. Nov 4, 2019 at 11:18 AM
    RRTEX1
    RRTEX1 New Member
    2016 CrewMax 1794
    I understand on the front you just reuse the current coil springs but if I wanted to get new coil springs and set these up prior to installing on the truck what springs should I look at?
  16. Nov 4, 2019 at 2:34 PM
    Zum
    Zum [OP] New Member
    NS Canada
    I know what your asking is possible, plus you can change the poundage of them if you want a softer ride or need heavier ones if you have a aftermarket bumpwr winch etc.
    You might want to start a new post, your question might get lost here.
    I'm thinking toytec should be able to help you , if you don't start another thread.
  17. Nov 4, 2019 at 2:55 PM
    Zum
    Zum [OP] New Member
    NS Canada
    I never looked at prices but it might be cheaper to order pre assembled coil overs.
  18. Nov 4, 2019 at 5:20 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Should I be able to c the top groove if I'm on the middle clip setting?
    I'm thinking it's good, the height raise seems right.
    usaf.2012 likes this.
  19. Nov 4, 2019 at 5:34 PM
    usaf.2012
    AK
    Yea i can see the top groove using the middle setting. I am guessing someone else did the work and you are QCing it?
    Zum[OP] likes this.
  20. Nov 4, 2019 at 5:45 PM
    Zum
    Zum [OP] New Member
    NS Canada
    I put it in the middle when I left my truck at the garage.
    Reason I'm questioning a little is that the owner never installed this style shock, had to explain the perch direction and clip setting. He was wanting to leave it stock(not even possible, I know) and then was saying the first clip would be better on the truck....you know cv angles, diff. drop etc.
    Anyways, thought I was done the way I asked due to the height raise but your answer reassures me....thx
    usaf.2012[QUOTED] likes this.
  21. Nov 11, 2019 at 1:59 PM
    'fro
    'fro New Member
    2014 Tundra 1794 - MGM
    None YET
    Good to know. I put 5100's on my 07 Tacoma on middle setting and it rode rough. Lighter truck though. I ended up ordering HD coils and going back to bottom setting on the 5100's and it was money. Going to get the 5100's for my Tundra soon.
  22. Nov 12, 2019 at 4:49 PM
    usaf.2012
    AK
    So the bottom setting/groove would result in stock height, for future reference.
  23. Nov 13, 2019 at 3:09 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Yup, .87"
    At least that's what it said in the instructions.
  24. Nov 13, 2019 at 4:18 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    My truck with lowest setting on 5100, 275/60/20 tire. Hope this helps
    usaf.2012 and Zum[OP] like this.
  25. Nov 15, 2019 at 9:25 AM
    lewishenry19
    lewishenry19 New Member
    Had them one my 18 until I got a new kit and I loved them
