TECH12VOLTS TUNDRA REMOTE START GROUP BUY
Discussion in 'Deals & Group Buys' started by james@tech12volts, Oct 12, 2019.
  1. Nov 3, 2019 at 11:47 AM
    #181
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    It was super easy to install an I'm stoked to have it to warm up the the truck in the morning. It was 27 when I got up this morning!
    A couple of things...I have an aftermarket stereo and it connects to the OBD II and it keeps the stereo on when the truck is shut off.
    The other thing I noticed is if the truck is locked...I can't get the remote start to work. I have to unlock the truck first then press the lock 3x and the remote start fires up? Anyone else notice this?
    Thanks,
  2. Nov 3, 2019 at 12:37 PM
    #182
    Levinger79
    Levinger79 New Member
    Knoxville TN
    2016 White Tundra Platinum
    Also.... Just noticed my drivers side Amp Research running board half opens and then closes when turning off the truck with the CarLink phone app. Passenger side doesnt do it.
  3. Nov 3, 2019 at 12:48 PM
    #183
    Cdorman
    Cdorman New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    What did you get figured out on the CarLink issue? My remote start is working great, however when I plug in the car link, switch ON-OFF-ON, I never see a red light flash? Am I not waiting long enough?
  4. Nov 3, 2019 at 12:50 PM
    #184
    Cdorman
    Cdorman New Member
    Oklahoma
    image.jpg Also- I understand black goes to blue on the remote, but does blue go to blue on the harness to CarLink or does black also go to blue there as well?
  5. Nov 3, 2019 at 12:58 PM
    #185
    Levinger79
    Knoxville TN
    I didnt have the cord hooked up right. (I had a small harness with two female (Black and Blue) and one male (black) leftover I thought it was extra or for a different model. But you gotta hook the blue to blue coming out of the carlink, and then the black male on the other end into the small blue spot on the Fortin. There should be one open female end that doesn't plug to anything leftover. After that. Key on, off, On... Step on brake 4 times and little red light will flash on Fortin. (Not the red and blue LEDs on top). Its a small light by the cut cord. That outta do it. Worked for mine
  6. Nov 3, 2019 at 12:59 PM
    #186
    Levinger79
    Knoxville TN
    Yes....those blues go together. Then the small black male end goes into the little blue spot on the Fortin
  7. Nov 3, 2019 at 1:18 PM
    #187
    Cdorman
    Cdorman New Member
    Oklahoma
    While I was waiting on a reply, I just plugged all back together and got it to work finally! Thanks for help! All things are working good from the app but my next question is how do I get the app to NOT be in test mode?
    Levinger79 likes this.
  8. Nov 3, 2019 at 1:52 PM
    #188
    Levinger79
    Knoxville TN
    Go to where it says release vehicle. Click that. Then type in the code off the top of your CarLink again. Will take it from test mode to full.
  9. Nov 3, 2019 at 4:55 PM
    #189
    Cdorman
    Cdorman New Member
    Oklahoma
    Thanks for all the assistance! :cheers:
  10. Nov 3, 2019 at 5:20 PM
    #190
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    When does the special end? I want to jump I in. Anyone get the extended warranty? I have 19 platinum.
  11. Nov 4, 2019 at 1:23 AM
    #191
    BigB717
    BigB717 New Member
    MA
    2019 Tundra - Silver Sky DC Limited - TRD Off Road
    I just ordered a kit for a 2019 from James and the plug-n-play harness from 12voltsolutions. The deal is still going on.
    Ridiculous a Limited doesn't come with a remote start, but in the end it's to my benefit. I'm so excited it won't shut off when I get in it like the factory remote starts do!
    jewsNbrews likes this.
  12. Nov 4, 2019 at 9:16 AM
    #192
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Can someone link the 2019-2020 harness we have to buy from 12voltsolutions in order to make this kit plug and play?
  13. Nov 4, 2019 at 4:21 PM
    #193
    BigB717
    BigB717 New Member
    MA
  14. Nov 4, 2019 at 4:25 PM
    #194
    BigB717
    BigB717 New Member
    MA
    Well scrap that link it didn't work after I copied it.
    The link that I used is in the first post of this thread.
  15. Nov 7, 2019 at 3:45 AM
    #195
    Cdorman
    Cdorman New Member
    Oklahoma
    Any idea’s on why the CarLink won’t let me do anything? Was working fine yesterday CAA144F0-48BC-4A96-9DAC-2D596F772A0A.jpg
  16. Nov 7, 2019 at 7:27 AM
    #196
    ndbwhunter
    ndbwhunter New Member
    Can someone please explain how the carlink works? I get that it's an app, but how does the service work. The first year of service is included in the GB price, but is there a monthly/yearly cost after that? Who provides the service?
    Answered my own questions. For those that have it, is the car link worth it for $40 a year?
  17. Nov 7, 2019 at 8:57 AM
    #197
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
  18. Nov 7, 2019 at 8:58 AM
    #198
    YsoSeRiouS!
    NorCaL
    I purchased the car link after I purchase the remote start and prefer the app more than key fob. Also I have a pop n lock and when I use the key fob my pop n lock actuates 3 times and was annoying with the app it doe not
  19. Nov 7, 2019 at 10:51 AM
    #199
    STE4DY
    STE4DY New Member
    Anthony
    2017 Limited TRD Off Road
    check the light on the gps unit in the car. or maybe a pin shook loose in the car. double check all that stuff and also check your app where it says service status. could be an issue they are working on
    Cdorman[QUOTED] likes this.
  20. Nov 10, 2019 at 4:22 AM
    #200
    19Platinum
    19Platinum New Member
    2019 Magnetic Gray Tundra Platinum
    This helped me tremendously! I deleted my install instructions from James by mistake and couldn't figure out how to get my CL6 to work. 30 seconds after reading this, BAM, CL6 is up and running!
    Levinger79[QUOTED] likes this.
  21. Nov 10, 2019 at 5:31 AM
    #201
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Just ordered so group buy still available.
  22. Nov 10, 2019 at 12:19 PM
    #202
    Mark843
    Mark843 New Member
    Mark
    WNY
    2018 Barcelona Red Tundra SR5 with TRD offroad package
    I have mine install with the car last nk and everything seems to be working except the car link still says test mode. How do I get it out of test mode and the cool tundra pic on the app?
  23. Nov 10, 2019 at 3:50 PM
    #203
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    Go back and read # 188 to release from test mode
  24. Nov 11, 2019 at 2:10 AM
    #204
    Cdorman
    Cdorman New Member
    Oklahoma
    ~Random question~ my job takes me to rural areas where cell service is poor, talking 1 bar and 1/2 bar if it was a thing. My question is, would putting a cell signal booster on my truck help the Car Link obtain a better signal?? :monocle:
  25. Nov 11, 2019 at 5:38 AM
    #205
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Got mine Thursday, installed it Saturday morning. Easy peasy. Couldn't be happier. Works perfectly from about 75yds away with my stock fob. Thanks James, you da man!
    classiccat and dwatts222 like this.
  26. Nov 11, 2019 at 8:11 AM
    #206
    dwatts222
    dwatts222 New Member
    Daniel
    For anyone that is on the fence, this is a great DIY option. I went back and forth between this, remote starters on eBay, and offerings from professional installers. I could not be happier with the simplicity of this set up, or the fact that I can use my factory remote. Installiation is pretty straightforward-- just watch the video that James provides, and the video at the beginning of this thread. You can knock this out in 30 minutes or less.
    Big thanks to @james@tech12volts and to the Tundras forum at large for promoting products that work and for providing the know how to get it done. Couldn't be happier.
  27. Nov 13, 2019 at 7:42 AM
    #207
    glide
    glide New Member
    2008 White Toyota Tundra
    Doggone, nothing for a 2008.
  28. Nov 15, 2019 at 8:22 PM
    #208
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I realize I am going to absolutely embarrass myself with this post but I figured I have to for the greater good. The purpose of my post is three fold.....let me explain. I purchased the remote start from James and received it today. Not wanting to cut the tpms wire I ordered the harness from 12 volt solutions. I got home from work around 9pm and wanted a distraction from some stuff and decided to pull the truck into my father in laws garage to install it. The install went easy as Pie. I took apart the dash, sill and steering wheel shroud; ran the wires, installed the module and programmed. Went outside of the car, pushed the lock button three times and the car started up just like it’s supposed to. However, when I went to unlock the door nothing happened. I could see the light in the dash blinking when I pushed unlock but nothing happened. The truck was running and I was locked out. In an absolutely embarrassing brain fart moment I panicked and called James at 10pm. He picked up right away. Yes I am an a-hole and I apologized profusely. Explained the situation and said I couldn’t get in the truck. He told me right away that since the tpms light wasn’t blinking on the dash it was not hooked up correctly. I said ok but how do I get in the truck? He responded in the most polite and non-patronizing way “you have the key don’t you”. ‍Needless to say I was embarrassed and thanked James and apologized again for my lack of discretion calling him that late. I post this for three reasons:
    1. The tpms harness from 12 volt solutions goes into the bottom white harness of the driver side kick panel. It will ALSO fit in the middle white harness of the driver side kick panel. Ask me how I know....
    2. The video that is provided walks you through the entire process and is very helpful.
    3. The customer service that James offers is second to none. For him to pick up and calmly explain what I needed to do just goes to show what a great guy he is and what great products he offers.
    I can’t say thank you enough times James. Thank you for being patient and understanding with me tonight. And I encourage anyone who is on the fence - deal with James with confidence. He is simply the best.
    rockmup, Cdorman, jewsNbrews and 2 others like this.
  29. Nov 15, 2019 at 8:36 PM
    #209
    STE4DY
    STE4DY New Member
    Anthony
    @shawn474 i'm sorry but this was hilarious :rofl:
  30. Nov 15, 2019 at 8:41 PM
    #210
    shawn474
    MoCo, Maryland
    I agree - if you can’t laugh at yourself......or something like that. As embarrassed as I was, I was laughing at myself. I even went over and had a beer with my neighbor afterwards and told him the story. He laughed at me while I was laughing at myself. I REFUSE to tell my wife though.
    ntg, YsoSeRiouS!, jewsNbrews and 3 others like this.
