Cats please help
Discussion in 'Performance and Tuning' started by thomashun1, Nov 6, 2019.
  1. Nov 6, 2019 at 9:04 AM
    thomashun1
    thomashun1 [OP] New Member
    Thomas
    08 tundra 5.7
    I have a 2008 tundra crew max 5.7 an I have a check engine light on for the upper cats. Can I hollow them out and be fine? Thanks in advance this is my first tundra
  2. Nov 6, 2019 at 9:05 AM
    Cats or O2 sensors?
  3. Nov 6, 2019 at 9:07 AM
    thomashun1
    Thomas
    08 tundra 5.7
    P0240 bank 1 code for check engine light
  4. Nov 6, 2019 at 9:08 AM
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
  5. Nov 6, 2019 at 9:13 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
  6. Nov 6, 2019 at 9:16 AM
    thomashun1
    Thomas
    08 tundra 5.7
    Could I order universal cats and replace them? I’m very new to the tundra world. Excuse me for being so green
  7. Nov 6, 2019 at 9:20 AM
    801Tundra
    UTAH
    Hard to know until its welded up if the computer will like the universal cats. Might as well just replace with an OE fit. Check RockAuto.com - they have options starting at $250. Also they are bolt in - no welding required.
    OR18TRD likes this.
  8. Nov 11, 2019 at 8:48 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    If they’re not rattling then just install a spark plug anti foulers on the o2 sensor and the code will go away.
    if it rattles you could move the rear cat up to the front position.
    either way give a call with any questions.
    DirtyDeedsIndustries.com
    760-877-4234
    AZBoatHauler likes this.
  9. Mar 4, 2020 at 8:23 AM
    Tundra196
    Tundra196 New Member
    Dave
    2008 Tundra CrewMax Limited
    Thanks for the post, I'm having the same issue after installing a complete MagnaFlow exhaust system on my Tundra. I'm no mechanic so I'm wondering how would I know which of the 3 included adjustable gas inserts to use with the Vibrant restrictor you recommended? I live in NY and have OBD II restrictions if that makes a difference. I put in all new Denso O2 sensors when I put in the new MagnaFlow system. Thanks for any help you can offer!
  10. Mar 4, 2020 at 8:29 AM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  11. Mar 4, 2020 at 8:31 AM
    smslavin[QUOTED] likes this.
