Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Oct 29, 2019 at 7:35 AM
    #1531
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I've seen that, but hard to justify spending that much on my bedliner thats usually under a bed cover, but also i use mine for all kinds of stuff that'll dirty it up. how's the longevity of it under "pressure"?
  2. Oct 29, 2019 at 7:42 AM
    #1532
    War Machine
    War Machine SSEM # 5 3MW
    There’s some rejuvenator spray that came with some of our trucks. I never used mine, but @NewImprovedRon said it worked very well. Unfortunately the bottle didn’t have any brand or numbers on it, and I don’t have the bottle anymore. Maybe the Toyota dealership sells it, or an auto parts house.
    NewImprovedRon and Pudge like this.
  3. Oct 29, 2019 at 7:43 AM
    #1533
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I had tried using mine after sitting in the cabinet for a few months and it wouldn't come out. Was clogged and when I opened it, it was all messed up/broken down. I put a little bit that I could in a small spot and it seemed to do well, but yes, no name/numbers/code/etc. on it.
  4. Oct 29, 2019 at 7:44 AM
    #1534
    War Machine
    That is one of the few Shine Supply products I haven’t used, but it looks similar to Reload. I haven’t actually applied anything to mine, outside of a spot with Adams Spray Ceramic. I wouldn’t recommend that for any situation.
  5. Oct 29, 2019 at 7:49 AM
    #1535
    War Machine
    Looking on Google, there seems to be a good variety of options, but not sure what works best. Rhino has a product called Rhino Shine that’s made for it, but it wasn’t available on Amazon. Solution Finish would probably work well, but that would be expensive.
  6. Oct 29, 2019 at 7:57 AM
    #1536
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Considering how I use mine sometimes for things like wood/rock/mulch/dirt, I may end up just attaching the 4" bristle brush head to my drill and do a good cleaning/scrubbing on it. I'd also hate to put anything on it that could either fade it more with chemicals, or make it greasy/slippery.
  7. Oct 29, 2019 at 8:01 AM
    #1537
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I use the little flat one on my tires to do a good scrub/clean on them and it's made it easier. have to be careful of course to not hit on your wheels and potentially scratch them.
    Pudge and War Machine like this.
  8. Oct 29, 2019 at 8:04 AM
    #1538
    War Machine
    I’ve used this on my bed liner and it worked great.
    Generac 7664 Power Broom, Gray, Black https://www.amazon.com/dp/B07CG8BZMW/ref=cm_sw_r_cp_tai_StfUDbASRE22D
  9. Oct 29, 2019 at 8:09 AM
    #1539
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
  10. Oct 29, 2019 at 8:32 AM
    #1540
    War Machine
    I had it anyway. I didn’t buy it just for that! And I have three kids, so not rich yet!
    Fotnot[QUOTED] likes this.
  11. Oct 29, 2019 at 9:24 AM
    #1541
    6XC
    6XC OPS4
    '18 MGM Tundra SR5 TSS Crewmax 4x4
    For those without garages or shops...any recommendations on a pop up canopy that won't break the bank?
  12. Oct 29, 2019 at 9:49 AM
    #1542
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Honestly, I'd swing by Dick's or Academy. It's kind of the end of their season, so they may have them on clearance. I went by Dick's once and got a 12x12 for around 40 or 50. I prefer my 10x10 because it's more rigid and a bit easier to set up solo, but it works well. Remember that 12x12's are usually set up with angled legs, so if getting close to your vehicle or wanting to tilt it, it will be something to consider.
  13. Oct 30, 2019 at 4:31 AM
    #1543
    War Machine
    I recently got this one, but have barely used it, so can’t speak to the quality.
    I can say it’s pretty portable for being a larger unit, and shouldn’t be too difficult to load in and out of the truck. I was easily able to load and unload it when I picked it up. I would have gone smaller, but needed to fit the requirements for my Tornador.
    https://www.homedepot.com/p/Husky-2...6?MERCH=REC-_-PLP_Browse-_-NA-_-206189626-_-N
    NewImprovedRon likes this.
  14. Nov 6, 2019 at 4:56 AM
    #1544
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Would there be an issue with doing a paint correction over several days? I work and go to school full time so I am having trouble finding time where I can just focus on working on my truck. I figured I could wash a panel each night for the next couple of days and polish it. This way I spread out the job over the next couple of days. Once it’s finished I will seal and wax. I figured the sealing and wax process doesn’t take all that long (except for the wait time for the power lock sealant) so I would do that Process on the same day.let me know your thoughts!
  15. Nov 6, 2019 at 5:49 AM
    #1545
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have done a few projects spread over a few days. It makes it a little more difficult and you have to duplicate some steps, especially depending on weather and how much you drive but sure, it's fine to do that.
    shhernandez74[QUOTED] likes this.
  16. Nov 6, 2019 at 12:58 PM
    #1546
    War Machine
    Shouldn’t be an issue. If it goes for too many days I’d consider applying sealant on each panel as you finish it.
    shhernandez74[QUOTED] and Pudge like this.
  17. Nov 8, 2019 at 11:40 AM
    #1547
    lsutiger9904
    lsutiger9904 New Member
    2019 Super White Tundra CrewMax 1794 Edition 4x4
    What do you use for cleaning and polishing the chrome on your truck?
  18. Nov 8, 2019 at 11:53 AM
    #1548
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    Carpro just announced a new chrome polish sealant I believe? I love all carpro products, definitely get what you pay for
    Pudge likes this.
  19. Nov 8, 2019 at 11:59 AM
    #1549
    War Machine
    I have only used this a little, since the grill on my wife’s old Sequoia was the only chrome I had on anything, but it seemed to work well. Got it at Walmart.
    Eagle One Nevr-Dull Wadding Metal Polish, Chrome Restoration, for Wheels and More, 5 Ounce Jar https://www.amazon.com/dp/B000CNBI1A/ref=cm_sw_r_cp_tai_mJCXDb77SN49W
  20. Nov 11, 2019 at 1:15 PM
    #1550
    War Machine
    Pudge likes this.
  21. Nov 11, 2019 at 8:38 PM
    #1551
    Bust
    Bust New Member
    Shean
    Part of me thinks these numbers are going to be skewed based on the fact that 97% of people, including myself before I joined the forums, doesn't know of brands and products other than Meg's, turtle wax, mother's. Stuff you find at large box stores and auto parts stores
  22. Nov 12, 2019 at 4:09 AM
    #1552
    War Machine
    Someone made a similar comment on there. For instance, Meg’s Gold Class was the top soap, but pro detailers don’t use it. It’s a decent soap, but nowhere in the league of Reset.
  23. Nov 12, 2019 at 4:53 AM
    #1553
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    So I'm kind of curious how well this will work. I have been using their Hybrid Ceramic Wax in the blue spray bottle and have been pretty happy with it. This is more of a coating, and doesn't enhance paint like the waxes do. But I may try this at some point. Even considered their new Ceramic coating they introduced. SEMA 2019 they released these 2020 items. I believe hit stores in early 2020. https://www.youtube.com/watch?v=-5rNobaGduY
  24. Nov 12, 2019 at 6:13 AM
    #1554
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I love the idea of a glass coating which lasts for years rather than weeks. Has anyone had any experience with https://www.glassparency.com/ and can comment? It's expensive, but if it lasts as long as a pro-ceramic coating (3+ years) it would be worth the money to me. Having trust issues, I don't want to go in blind... lol
  25. Nov 12, 2019 at 6:49 AM
    #1555
    War Machine
    I started to post a thread with all the new products everyone showed at Sema, but there were a ton.
  26. Nov 12, 2019 at 7:10 AM
    #1556
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Yea I figured you have been watching what they're introducing this coming year. lol. I haven't had a chance to look at it all yet. Like you said...it's a lot! haha
  27. Nov 12, 2019 at 10:37 AM
    #1557
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Honestly, I did not read through all 55 pages of this thread, so I apologize if this has been covered.
    I just have some questions about how you go about detailing the exterior when things like vinyl or plastidip have been added to it. I ask because I am considering the plastidip solution to black out my Tundra, SR5, and 4x4 badges, and I want to get a Yodagan vinyl from @boardude along with the black TUNDRA letters for the tailgate. Just don't want to put effort into those, and then fubar it.
    Also, as somebody who has never done any of this, I am a total noob. I have no supplies for any of it. I live out in the county, so I have hard water. Also on a dirt road with no access to shade or shelter from wind for cleaning. What would the gurus recommend as a good starter set up (Affordable if possible) so I can properly go about detailing to protect my truck? A starting bit that I can use to test the waters and grow if I get better at it. I'm terrified I'm going to try this stuff and wreck my paint.
  28. Nov 12, 2019 at 12:53 PM
    #1558
    Pudge
    CT
    There are so many options out there for washing and detailing, you'll get tons of good advice here. One thing I would say is that if you know you have hard water, and a water treatment system isnt an option, find a good way to dry your truck after washing. Whether that be some good drying towels or some kind of blower, you'll save a lot of time and energy investing in an effective way to dry. I know it sounds trivial with all this detailing info, but to me it's very important.
    GODZILLA[QUOTED] and Leo's first like this.
  29. Nov 12, 2019 at 1:13 PM
    #1559
    Wyoming
    I've read enough and seen it stressed that drying the truck properly is a huge thing, so I get that part. It's not really feasible to do a water treatment system for me, at least I don't think it is. I have no garage, and the pump building is a joke. This spring I need to gut it and redo insulation. My handyman skills are non-existant lol. This might be rectified in a few years, if I can pull off getting a house built, but who knows. I just want to try and protect the paint and clearcoat.
    For the starting stuff, I just want to know what your personal recommendation for an absolute beginner would be. The lower the maintenance the better, because wind is an issue about 363 days of the year. Basically, if your neighbor came up and said "I have a max budget of $200-$300 to get exterior detailing equipment" what would that list look like? Would you recommend a youtube guide for a new guy?
  30. Nov 12, 2019 at 1:42 PM
    #1560
    Pudge
    CT
    Okay well I will recommend to you what was recommended to me a few years back by wareagleSteve and it led me down the path of wanting to detail more and do better.
    2 or 3 buckets with grit guards (this could be replaced by one bucket and about a dozen+ wash mits, the idea is not using a dirty mit on your paint)
    2 or 3, really should be, 5 or 6 good wash mitts. No wands or brushes or old sponges.
    A Good car wash soap (carpro reset is king, but megs gold class, chemical guys maxisuds2 is also good)
    A good versatile "quick detailer" like carpro ech2o or optimum no rinse aka ONR. This is really really important as it gets used for many different purposes mixed at various concentrations.
    At least a dozen quality microfiber towels and always wash them separately in warm water and dry on low to no heat.
    A clay bar, synthetic clay is easier and faster. Tons of companies make them. nanoskin is highly regarded in this category.
    Some kind of sealant or wax. I like carpro reload and hydro2, but you can explore many options, like jescar powerlock or optimum opti-seal or any long lasting sealant.
    Drying towels. Griots pfm drying towels are unreal and I wouldnt use anything else
    Now the detailing stuff like tire shine, tire cleaner, trim shine and protection, I like carpro perl for interior, exterior and tires. Aerospace 303 is commonly used and works but it doesnt last as long or look as good.
    I like stoner glass cleaner for glass, and tarminator for cleaning tough grime. Diluted all purpose cleaner is helpful for lots of stuff, even simple green works and is cheap.
    I am sure I missed a lot, but it's a start.
