Touchy gas pedal
Discussion in '2nd Gen Tundras (2007-2013)' started by RR1975, Aug 1, 2018.
  1. Aug 1, 2018 at 4:44 AM
    RR1975
    RR1975 [OP] New Member
    Is there anything that I can do to fix a touchy gas pedal?
    Fiesta346 and MyFj08 like this.
  2. Aug 1, 2018 at 5:48 AM
    LML 3500HD
    I do believe the bully dog tuner can help with this.
    Check out the vendor section. Pretty popular item.
  3. Aug 1, 2018 at 5:58 AM
    Jrfor0
    Jrfor0 New Member
    James
    It might be worth trying to disconnecting the battery for a little bit so the computer can reset and learn driving habits and shift points over again.
  4. Aug 1, 2018 at 9:34 AM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Chris is correct, BD tuner will let you tame the twitchiness. Be aware, if you like to use the tow/haul button it seems to override the BD tune and you're right back to the stock feel.
    MyFj08 and ColoradoTJ[QUOTED] like this.
  5. Aug 1, 2018 at 12:30 PM
    15whtrd
    15whtrd Mr. Blonde
    In definitely? Or just while you’re using the tow haul?
  6. Aug 1, 2018 at 2:32 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Just when using tow/haul.
    Turn the tow/haul off and it's right back to the easily modulated pedal.
    MyFj08 and 15whtrd[QUOTED] like this.
  7. Aug 1, 2018 at 2:36 PM
    15whtrd
    15whtrd Mr. Blonde
    OK I was unsure for the second Gens. That’s pretty much how my third GEN does it as well.
    Taco-Blender[QUOTED] likes this.
  8. Aug 1, 2018 at 3:10 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Hear the BD will work.
    I installed the Pedal Commander which worked as well.
  9. Aug 1, 2018 at 4:09 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I noticed it too when i first got my tundra. I wasnt used to a truck putting this much torque to the wheels coming from gm trucks.
    Pudge and Randy Morton like this.
  10. Aug 1, 2018 at 4:16 PM
    15whtrd
    15whtrd Mr. Blonde
    The second gen is more touchy. 14- is smoother. I added the BD and it’s probably right up the middle. Id say its in between tow haul and factory.
    Pudge and Hondoman[QUOTED] like this.
  11. Aug 1, 2018 at 7:01 PM
    grease pants
    grease pants New Member
    My pedal was lopped off at the dealership and I hated the feel so I made a plate an riveted it on. The longer throw and a more relaxed foot position gave me a more subtle throttle response. I might try some skateboard grip tape on it, but for now it feels great.
    B.Ross, RitcheyRch, D4x4TRD and 5 others like this.
  12. Oct 21, 2019 at 10:03 AM
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    Year Tundra? There’s a shim in the 2nd gen pedal. I just deleted it with a $35 OEM replacement pedal. Made all the difference, but mine wasn’t a tow/haul specific problem. It existed in all “modes.”
    Did the same today. Immediately satisfied with the lack of jerkiness in the 1st/2nd gear speed regime. Much better / finer throttle control.
    5327D72E-916F-4075-B75D-1C4B63295D29.jpg 08C861E2-20BA-4E4F-B335-0F8791C68364.jpg
    YardBird and V10Ace[QUOTED] like this.
  13. Oct 21, 2019 at 10:10 AM
    Trooper2
    JR
    Got the 440C pedal a while back, removed pedal Commander. Much smoother acceleration.
    MyFj08 likes this.
  14. Oct 21, 2019 at 5:33 PM
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    Please explain and add some links to the items you used.
  15. Oct 21, 2019 at 6:15 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I guess I am the only one here that likes the hair-trigger gas pedal.
    D4x4TRD, Mattyc, Larly5000 and 5 others like this.
  16. Oct 21, 2019 at 7:49 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I drove my brother in law's 08 DC and it super touchy rolling thru insections. I thought I just didn't know how to drive it.
    I bought my 08 CM a few months ago and it's not even close to being as twitchy as his. I'll have to check out the shim or get the updated pedal for him.
  17. Oct 22, 2019 at 7:36 AM
    dragon_coma
    Sky
  18. Oct 23, 2019 at 10:39 AM
    RR1975
    I have a 2007 tundra. It isn't a tow/haul problem. It is exists in all "modes" and I just don't like the touchiness of it.
    08crewmax likes this.
  19. Oct 23, 2019 at 11:10 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    No you aren't. I love the responsive throttle on my Tundra. One of my favorite things about the truck.
  20. Oct 23, 2019 at 11:32 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    You're not the only one. It took a little while to get used to the responsiveness of the pedal, but I like it now. I came from a small Chevy truck that had to think about it a while when you pushed the pedal, and even then didn't get in a hurry. The first couple of weeks with the Tundra almost gave my wife whiplash. Once I adjusted, I like having the responsiveness when I need it.
  21. Oct 23, 2019 at 12:41 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    A little more info would be helpful. Looking at the pics you posts and visually...I don't see where the shim would be (or more accurately, where it would be removed from!). Thx!
  22. Oct 23, 2019 at 12:59 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    I guess to add - all I can find out there about pedal issues/recalls specified '07-10, so apparently my 2011 wouldn't be included...but I'd beg to differ lol
    RitcheyRch and MyFj08 like this.
  23. Oct 23, 2019 at 8:09 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    There is no shim regarding what he's mentioning, it's a total gas pedal replacement... Part# 04000-0440C. I've had the replacement pedal for a while now and don't miss the bull riding days while driving the truck.
    mtucker, tnbndr and MyFj08 like this.
  24. Oct 24, 2019 at 6:27 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Hmmm...maybe I read it wrong, the impression I got was the difference in the stock vs. replacement pedal was the lack of a shim. Maybe not. There's not a ton of info out there other than a few random forum posts.
    So...would be 2011 be subject to the same thing? I'll have to take a look at it. It sure does feel rather twitchy, but maybe I'm still getting used to driving the 5.7 right now...it's only been a couple of months.
  25. Oct 24, 2019 at 6:32 AM
    Trooper2
    JR
    Had the same issue with our 07. The replacement pedal is way smoother, makes driveability much better. Cheap and easy fix :thumbsup:
  26. Oct 24, 2019 at 7:17 AM
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    From what I am understanding. the stock existing pedal. Has a metal shim in it that can be remove . To help it feel less twitchy
    Most ppl are replacing the existing pedal with the 0440. Pedal. And getting good results
    Again this is what I am reading and information I am gathering to my understanding
  27. Oct 24, 2019 at 7:22 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Mine is super touchy as well. I just have gotten use to it. It is always fun watching someone new drive it though. You could say it is a "head-jerkin" time...
    wakeboarder likes this.
  28. Oct 24, 2019 at 7:43 AM
    Trooper2
    JR
    I can't comment about the "Shim". There were some discussions about how dealers (early on) attempted to modify the pedal to correct the issue; with shims, angles, and trimming. The replacement pedal is identical physically. The difference is it's electrical characteristics to the ECM, most likely a variable resistor, which "curves" the acceleration to the trucks computer.
    The new accelerator is cheap and easy. Two 10mm mounting studs and two harness connections. Plug and play, 5-10 minutes tops.
  29. Oct 25, 2019 at 6:00 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Would you have a link of where to purchase? Or is it something I should just check with the local dealer on? And any clue if it's different than what my stock pedal would be on a 2011?
  30. Oct 25, 2019 at 6:12 AM
    wakeboarder
    wakeboarder New Member
    13 Tundra
    I’ve gotten used to it now on my 2nd gen. But it’s good to hear I wasn’t the only one! It took me about 6 weeks to condition my foot to apply the right pressure so it accelerates smoothly through all the shift points, low gears being the trickiest. REALLY have to feather it to keep the engine under 2k RPMs.
