Diamondback bins 8” vs 13”
Discussion in 'Tonneau Covers, Caps and Shells' started by equin, Mar 11, 2019.
  1. Mar 11, 2019 at 1:02 PM
    equin
    equin [OP] Texarican Tundra
    Ed
    DFW, TX
    Hi All,
    Am considering one of the bins offered by Diamondback. The 13” is only $20 more but it obviously holds much more than the 8”. Even so, I’m concerned with two things about it:
    1) Space available to store items in the front of the bed and underneath the bin, and;
    2) Ease or added difficulty in removing the bin when needed compared to the 8”.
    Those of you who have one or the other, could you share your experiences? Those with the 8” wish they would’ve gone with the bigger 13”? Those with the 13” have trouble fitting items underneath it or find it much more difficult to remove?
    ToyoD and Pinay like this.
  2. Mar 11, 2019 at 1:05 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    I am wanting to know the same thing.
    :popcorn:
    equin[OP] and Pinay like this.
  3. Mar 11, 2019 at 1:11 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    ^^^ :popcorn:
    equin[OP] and Faht Nocker like this.
  4. Mar 11, 2019 at 1:16 PM
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    I don't have them but I have been getting ready to order one. I guess it comes down to what you are going to keep in the bin and how big of an item you want to have under the bin...
    equin[OP] likes this.
  5. Mar 11, 2019 at 1:44 PM
    mgxsequioa
    mgxsequioa New Member
    I have the 8” and am pretty satisfied with it. I keep tools, hitch and sunshade im there. I’m able to reach in there without issues. There isn’t too much storage below the 8”, fortunately I haven’t had to take it out. If I had the 13”, I would have been SOL a few times to secure things in and not on the bed.
    Hopefully the pictures help.
    AB37CF40-540C-4C91-8764-2E9A28A94243.jpg 4C4900ED-6DB5-41ED-AA72-14111263A062.jpg
  6. Mar 11, 2019 at 6:33 PM
    equin
    Ed
    DFW, TX
    Great pictures. I’ve already taken a measuring tape to try and figure it out, but the pictures sure put it all into perspective. Thanks!
    mgxsequioa[QUOTED] likes this.
  7. Mar 11, 2019 at 7:15 PM
    Faht Nocker
    Woody
    Milky Way
    Thanks for the pic. After seeing this....i think i am going with the 8.
  8. Mar 18, 2019 at 7:22 PM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    Not sure how I missed this. I have the 8” and love it. It holds a lot and is super sturdy. Only draw back is it is a pain to remove and install alone - so I don’t!
    ToyoD and equin[OP] like this.
  9. Mar 18, 2019 at 7:53 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I have the 13” in a DC, and I have plenty of room for hauling things. I tend to carry more gear than I realistically need, but I like to be prepared. Taking the bin out is easy once the cover is removed, but it does require removing most of the contents. A second pair of hands make it easier. I am very happy with the purchase.
    ToyoD, mgxsequioa and equin[OP] like this.
  10. Apr 1, 2019 at 6:35 PM
    equin
    Ed
    DFW, TX
    My 8" finally arrived. Install was fairly easy, but I've read how a few were kind of a tight fit. Luckily, mine fit just right. I found it easier to first lay it in at an angle, and then get underneath it while laying in the bed on my back and "bench pressing" it into place. Works just as well when removing it.
    NewImprovedRon likes this.
  11. Apr 1, 2019 at 6:38 PM
    equin
    Ed
    DFW, TX
    Here’s a picture of it installed with a few items in it already.
    cfus89_TUNDRA and Faht Nocker like this.
  12. Apr 1, 2019 at 6:58 PM
    aw113sgte
    aw113sgte New Member
    I have the 13. Install is the same as 8, just drop in. I love the room of the 13 and would never go with the 8 because I can easily throw backpacks in there with all sorts of other stuff. 8 just wouldn't give the flexibility I want.
    ToyoD likes this.
  13. Apr 1, 2019 at 7:00 PM
    Faht Nocker
    Woody
    Milky Way
    Adequate room? I am thinking bout getting the diamondback soon ....if i do i want one of the bins for sure.
  14. Apr 1, 2019 at 9:08 PM
    equin
    Ed
    DFW, TX
    Adequate room for me. I need the bed space underneath it, though. Otherwise the 13" would've been my preference .
    Bigbird57 and Faht Nocker like this.
  15. Apr 1, 2019 at 9:52 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    Will the 13" fit in a crew max bed?
  16. Apr 2, 2019 at 4:17 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Can someone who has the 8 inch tell me what the overall height is? I'm confused on what the "8 inch" refers too. Is it the overall height or the actual bin height.
  17. Apr 2, 2019 at 7:46 AM
    equin
    Ed
    DFW, TX
  18. Apr 2, 2019 at 8:22 AM
    Steve6
    Steve6 New Member
    Tucson
    I have the 8 inch bin and it's just right for me since I have items that need to fit under it. Also, it would be more difficult for me to reach items toward the middle of the bin if it were deeper.
    The bin is solid and it's a snug fit; however, I also added a T-nut to each side to engage the rail and prevent it from moving.
    NewImprovedRon and equin[OP] like this.
  19. Oct 14, 2019 at 11:27 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    Has anyone considered the BakBox? I bought that a week after I bought my truck. The thing I like the most is when you need the space in the bed, just empty is and fold it up out of the way
  20. Oct 14, 2019 at 8:26 PM
    2chains
    2chains New Member
    Southern Ablerta
    Thanks for the pics I'm looking to pic up the SE with an 8" bin. I'm pretty short and doubt I'd be able to reach into the 13" one....
    Can someone post up how much clearance the 8" has from the arm mechanism? Or is it even an issue? I see in the pics there is soft suitcase which comes above the bin...
  21. Oct 15, 2019 at 9:37 PM
    equin
    Ed
    DFW, TX
    The arm mechanism doesn’t interfere with it at all.
  22. Nov 26, 2019 at 8:52 AM
    xbrandx
    xbrandx New Member
    2019 Voodoo Blue Trd Pro
    285/70/18 Nitto Ridge Grappler, TRD Pro Side stickers
    Do the cross bins utilize the rail system in the bed or sit on top of the sides? Also, anyone with the 13in how much room between the bed and the bottom of the cross bin... Thanks!
    ToyoD likes this.
  23. Nov 26, 2019 at 8:59 AM
    mgxsequioa
    Sits on the side of the bed, above the rails.
  24. Nov 26, 2019 at 9:00 AM
    equin
    Ed
    DFW, TX
    I don’t have a rail system. My 8” sits on top of the plastic bedside caps.
  25. Nov 26, 2019 at 12:17 PM
    xbrandx
    xbrandx New Member
    Gotcha! Thanks for the info..
    equin[QUOTED][OP] likes this.
  26. Nov 27, 2019 at 12:52 PM
    mountainpanda
    mountainpanda New Member
    2016 Super White SR5 TRD 4x4
    How much does stuff rattle around in these things?
  27. Nov 27, 2019 at 4:42 PM
    equin
    Ed
    DFW, TX
    I’ve filled mine with enough stuff that there’s no room for any of it to move around and rattle.
    one4x4dad and xbrandx like this.
  28. Feb 10, 2020 at 12:02 PM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Gonna revive this thread.
    Could those of you with the bins give the measurements from the bed to the bottom of the bin both on the 13" and 8". Just want to know how much space is available underneath each. thanks
  29. Feb 10, 2020 at 3:12 PM
    mountainpanda
    I got 13 inches from the bottom of the 8”
  30. Feb 10, 2020 at 3:19 PM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    Thank you.
    cfus89_TUNDRA likes this.
