Back up camera issues
Discussion in '2nd Gen Tundras (2007-2013)' started by andrew, Jul 13, 2014.
  1. Jul 13, 2014 at 5:33 PM
    andrew
    andrew [OP] where's the beer?
    andrew
    2012 rockwarrior
    stock
    On my 2012 tundra, the back up camera doesn't work half the time. Anyone else have issues with this? I just get a blue screen and it shuts off. I am assuming it's overheating in the arizona sun, or a loose connection?
  2. Jul 13, 2014 at 9:57 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Never heard of that one. Sounds like loose connection though. Doubt it's from overheating
  3. Jul 14, 2014 at 7:07 AM
    Sounds like a loose connection....
    ODSteve likes this.
  4. Jul 14, 2014 at 4:51 PM
    andrew
    andrew
    2012 rockwarrior
    stock
    Yeah, loose connection is my first guess. I just think it's odd. It now happens everyone in a while when it's cool out, but it definitely a lot more prevalent in the heat. Maybe that the expanding in heat makes it just loose enough it mess up? Anyone have any diagrams on how the wiring is routed?
  5. Jul 14, 2014 at 5:09 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Im willing to bet money there is a temp cut off in the mirror say 150 degrees... Try this if you have a window shade for your windshield try it and see if temp is the issue.
  6. Jul 14, 2014 at 5:22 PM
    andrew
    andrew
    2012 rockwarrior
    stock
    I'll have to try that out! :thumbsup: I was just thinking about buying one of those anyways. I just took apart the tailgate and checked the connectors, all seemed well. Didn't want to check too much more out since there is a lightning storm outside and all :bananadead:
  7. Jul 15, 2014 at 8:04 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    My '13 has had intermittent camera issues since day one. I don't get a blue screen, I just don't get any response at all and am still looking at the map. Nothing I try gets it to come back, until it just randomly decides to work again later. At first it was happening about every 4th or 5th time going into reverse, but now it's down to maybe once out of every 40 or 50 times. Of course the dealer's never been able to replicate it.:annoyed:Good luck with finding a solution.
  8. Jul 15, 2014 at 9:41 AM
    andrew
    andrew
    2012 rockwarrior
    stock
    That sucks man, have you checked the connections? It sounds like one of the pins might be damaged or lose and it's only gettin partial input.
  9. Jul 15, 2014 at 12:07 PM
    Jack Burton
    Little China
    2013 DC 5.7L TRD/OR
    My guess is there's got to be a shift position sensor somewhere that's sticking and not realizing I'm in reverse. I don't have a clue as to where that is though. Could be mechanical with the shift lever, but I'd assume it's the same switch that tells the backup lights to come on. Crap! I just realized that I've never gotten out of the truck and checked the dang backup lights when it happens, so I could be asking for someone to hit me in a parking lot because they don't know I'm backing down! :mad:
  10. Feb 10, 2015 at 10:00 PM
    sonns904
    sonns904 New Member
    Orlando fl
    2011 white crewmax
    Mine doesn't work at all. I was going to make a new thread but after reading this, it's obviously pointless....
  11. Dec 15, 2015 at 1:27 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    A friend of mine is having the same blue screen issue, except we are in PA, it's definitely not heat related. The dealership has had it in and out of the shop, not the camera, not the mirror, they checked the connections, now going to check in the dash.
    I will let you know what his outcome is.
    Any updates on your end?
  12. Dec 15, 2015 at 2:50 PM
    andrew
    andrew
    2012 rockwarrior
    stock
    Thanks man, still no updates. It does it in regular temps and freezing temps as well so I'm at a loss for what could be causing it. I'm going to see if maybe it's worse when it's humid but since it happens about 1/4 of the times I back up, I just ignore it and forget to log of its humid or not. The pins and stuff on the tailgate looked clean when I tore it apart a while ago. Half the time it goes out, the screen will get wavy and distorted, then just go blue. Other times it will just come in blue. When I get some extra time I will have to try trouble shooting it again.
  13. Dec 15, 2015 at 3:03 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Alright, thanks for the info. He mentioned something about a wire covering for interference in the dash, I guess they are going to look at that next.
    I will post his updates.
  14. Oct 23, 2016 at 12:11 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Sorry I didn't update. Toyota fixed it under warranty after multiple attempts. Their explanation was that there was an interference issue with wires in the dash that should be been shielded that weren't. The interference was causing the error. They corrected that issue and my buddy's truck has been fine since.
    zMaestr0 and Law323 like this.
  15. Oct 25, 2016 at 7:22 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    My back up cam worked fine until we had several days of rain when I was in Houston a few months ago. Now, when I'm in reverse, I just see black. Some of the research I've done says it is possibly a short but I can't fix that. Sooo, at this point, I guess I will take it into the dealership but I have a feeling it's going to cost some bucks! :angrygirl:
    NewImprovedRon likes this.
  16. Oct 15, 2019 at 6:38 PM
    Yotayoda
    Yotayoda New Member
    Chucktown, SC
    2011 Toyota Tundra
    Had the same issue happen today on my 2011 Toyota Tundra SR5 Crew (blue screen || black screen || mirror). I slightly wiggled the wires connected from the rear view mirror to the top of the car and it started working. Definitely think there is a short or need to change out wiring. I’ll keep y’all updated.
  17. Oct 20, 2019 at 7:13 PM
    Maxi13
    Maxi13 GuttenTight
    Montucky
    2020 Cement Sr5 TRD OR
    Nudding yet
    Anyone know why the sequoia rear camera system seems to be much clearer than the tundra? Camera? Head unit? Wonder if the 2019 head unit and camera could be swapped with a 2nd gen system?
  18. Aug 28, 2021 at 7:23 AM
    clintd
    clintd New Member
    Clint
    2014 tundra
    My camera stopped working when it got above 80 degrees, then would come back on at night. Now it doesn’t work at all.
    From what I’m seeing I need to check the wiring harness. The dealer told me it’s a $30 part but the camera itself costs $1200.
  19. Aug 28, 2021 at 8:35 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    clintd[QUOTED] likes this.
  20. Aug 28, 2021 at 12:06 PM
    clintd
    clintd New Member
    Clint
    2014 tundra
    Thanks! Anyone replace the wiring? How hard is it?
  21. Aug 28, 2021 at 12:08 PM
    audiowize
    Paul B.
    There's a wire that snakes through the tail gate and plugs into a connector behind the rear bumper up under the truck. This is intentionally not that hard to remove so you can get the tailgate off somewhat easily.
  22. Aug 30, 2021 at 3:10 PM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    When I replaced my backup bulbs with LED I started to have problems with the camera intermittently not working. Then I put a custom rear bumper on and tapped into the reverse light wires to run to backup LED's in the bumper. Now I get the blue screen when I shift to reverse and then the mirror comes back.
    My shop that does all my wiring thinks its an amp draw problem. With the LED's there is low amp draw so the truck doesn't think it is in reverse.
    I have not had time to leave it with them to diagnose, but maybe it will help someone else.
  23. May 24, 2022 at 10:28 PM
    PlatinumTT12
    PlatinumTT12 New Member
    Filippo
    2012 Toyota Tundra Platinum Crewmax
    Hey guys, I had a blue screen also or just nothing happened when I went into reverse as well on my 2012 tundra. I replaced the wiring harness that runs from the short wiring harness from the camera through the tailgate and out to the bottom to underneath the truck. I guess from use of the tailgate opening and closing the wires broke. (Couldn't even see the brake in the wire). That fixed my issue though. Wasn't an expense wiring harness either
    Good luck out there fellas.
    zMaestr0 and NewImprovedRon like this.
  24. May 26, 2022 at 6:47 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    Do you have the part number?
  25. May 26, 2022 at 11:36 AM
    PlatinumTT12
    Filippo
    Yes I do, it's 821820C011.
    zMaestr0, is348cm and tnbndr[QUOTED] like this.
  26. Feb 3, 2023 at 7:12 PM
    zMaestr0
    zMaestr0 New Member
    Jeffro
    Huntington Beach, CA
    '12 Tundra CrewMax T-Force Stormtrooper
    Appreciate the post and replies! Will check my wiring harness at the tailgate and possibly replace with the model Flippo found. Blue screen shows up at the worst times. :mad:
