JT 02 Tundra
Discussion in '1st Gen Builds (2000-2006)' started by 01erionracing, Mar 5, 2018.
  1. Oct 30, 2018 at 4:22 AM
    #121
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Damn Jimmy after looking at those pics, it does seem to me like the UCA is the problem. That snap ring should not release like that. It doesn't even look broken. It looks like it just snapped out of the groove.
    01erionracing[OP] and Casper421 like this.
  2. Nov 14, 2018 at 8:35 AM
    #122
    01erionracing
    01erionracing [OP] KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Alex - The snap-ring broken on two different cases.
    Anyhow this time the snap-ring is eliminated so I welded the UCA lower adaptor, nut and steering knuckle together and placed some flat bar boxed the steering knuckle collar.
    I also fixed the upper coil bucket shock mount that sheared earlier.
    New 6 Cooper STT Pro 285x75x16 also arrived
    Installed
    jc153, Darkness, Sunnier and 3 others like this.
  3. Nov 14, 2018 at 9:34 AM
    #123
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Your truck is looking good!
    01erionracing[OP] likes this.
  4. Nov 14, 2018 at 2:20 PM
    #124
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Damn Jimmy !! Looks good! I'm pissed about my tires because they didn't offer white letters out for my size wth! I love that look
  5. Nov 17, 2018 at 10:44 AM
    #125
    Sunnier
    Sunny
    San Diego, CA
    Hey, Jimmy! Your trucks morphed a bit since you posted these pics:
    When you get a minute, please will you tell me more about your roof rack (where'd you get it? Show me how it's attached. Do you get loud wind noise, either because of the rack, or the light bar?)
    Can you tell me more about how you've secured the spares in the bed (I figure it's something you built in when you reinforced the bed-?
  6. Nov 17, 2018 at 10:53 AM
    #126
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Locking those spares down or did you set up a motion detector with machine gun?
    01erionracing[OP] and Sunnier like this.
  7. Dec 7, 2018 at 4:01 PM
    #127
    01erionracing
    Jimmy
    @Sunnier - I built the roof rack and i attach to the truck using rain gutter. There is no wind noise on the rack neither the light bar. I will attach the photos of the spare tire mount below.
    The bed mount spare tire and the roof rack share the same mounting, so I can mount the tire either.
    Sunnier[QUOTED] and Brown Bear like this.
  8. Aug 4, 2019 at 12:32 AM
    #128
    mrsinister
    mrsinister New Member
    Kenny
    2002 Tundra
    exhaust
    im loving reading about this build! I've got a 2002 tundra and am getting some great ideas. thanks for posting
    zcarpenter92 likes this.
  9. Aug 8, 2019 at 7:55 AM
    #129
    2scars
    2scars New Member
    RVA
    2013 CM Limited 4x4
    Did you just flip the receiver bracket?
  10. Aug 8, 2019 at 9:13 AM
    #130
    01erionracing
    Jimmy
    The receiver tube was cut and relocated upper to fit in the center of the bumper.
  11. Aug 8, 2019 at 9:54 AM
    #131
    osidepunker
    Alex
    2013 Tundra DC 4x4
    when are you gonna wheel that thing mang???
  12. Aug 8, 2019 at 11:00 AM
    #132
    01erionracing
    Jimmy
    Try to install the rack this weekend and swap out the LCA bushing from the last trip. Let me know when the next trip will be.
    osidepunker[QUOTED] likes this.
  13. Aug 8, 2019 at 8:04 PM
    #133
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Nice looking truck you have there. One question. Is the upper uniball snap ring on the top or the bottom side of the cup?
  14. Aug 21, 2019 at 1:07 PM
    #134
    01erionracing
    Jimmy
    It is on the bottom.
  15. Aug 23, 2019 at 3:45 AM
    #135
    KarmaKannon
    Utah
    Some junk
    I wonder if this is just to keep dirt and debris out of it? I just put mine on the top so if it came off the upper arm couldn't come completely off the spindle.
  16. Oct 14, 2019 at 1:28 PM
    #136
    01erionracing
    Jimmy
    During summer I was busy with river camping trip, I got new toy Kawasaki 310 SE (310 HP supercharged) so not much time to work on my truck. Jefferson (my son) who is riding the Yamaha VX cruiser now.
    We spent most of the river time in Lake Havasu.
    Took my son (Jefferson) to Big Sur on the motorcycle trip during summer.
    Last year the LCA passenger sheared during Mojave Road trip with SGU, LCA on the driver side cracked about 3/4"
    The passenger LCA sheared and I was able to replace this on the trail. Thanks to @osidepunker and @jc153 helped removing while thanks @Stewie for the 80 miles round trip ride for part.
    The driver
    I removed both LCA last weekend, re-enforced it and reinstalled with poly bushing.
    I also replaced rack and pinion, LBJ and outer tie-rod end.
    All parts were installed, alignment is also done.
    The truck is now ready for the next adventure trip.
  17. Oct 14, 2019 at 1:59 PM
    #137
    Sunnier
    Sunny
    San Diego, CA
    Very nice, Jimmy; looks like you and Jefferson had a great summer!
    I’ll be thrilled if you show up to cruise around Anza this weekend. I’ll keep my eyes peeled. :)
  18. Oct 14, 2019 at 2:03 PM
    #138
    01erionracing
    Jimmy
    Sunnier, I am exciting to check out your truck too.;)
  19. Oct 14, 2019 at 7:30 PM
    #139
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Jimmy puttin in work! Looks good!
  20. Oct 15, 2019 at 4:36 AM
    #140
    osidepunker
    Alex
    2013 Tundra DC 4x4
    You need to throw those control arms in the trash and get LT arms haha
    See you Fri homie! Sunny, we'll be there!
  21. Oct 15, 2019 at 4:36 AM
    #141
    osidepunker
    Alex
    2013 Tundra DC 4x4
    btw Jimmy, if you go the whole trip without breaking something I'll eat a black egg :rofl::rofl::rofl:
  22. Oct 15, 2019 at 11:43 AM
    #142
    01erionracing
    Jimmy
    Alex, sounds like a plan. Looks like I am going to crack and peel the black egg shells.
    Since you offer the black egg, this will be included for FREE.
  23. Oct 15, 2019 at 1:40 PM
    #143
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'm not eating that!
    Matt @Stewie says he'll take that bet also Jimmy
  24. Oct 15, 2019 at 2:37 PM
    #144
    KarmaKannon
    Utah
    Some junk
    I love it how op has been deemed that guy that always breaks shit and yet you are all so ready for the next adventure. I can make fun of the left coasters all I want but that's pretty solid comradery.
  25. Oct 16, 2019 at 4:29 AM
    #145
    osidepunker
    Alex
    2013 Tundra DC 4x4
    We always help each other out, wheelin in remote territory is way more fun when you dont have to worry about being broke and alone.
    Last time I wheeled anza with jimmy he broke his spindle in two. Right under the upper ball joint. I tied a jack handle to the spindle with ratchet straps, then ran the handle through the upper ball joint. This was enough to keep his wheel straight. He had to drive walking speed though. We spent the next two hours limping his truck to fish creek where we made camp for the night.
    I haven't been on a single trip with that guy where he hasn't broken something major...
  26. Oct 16, 2019 at 10:12 AM
    #146
    KarmaKannon
    Utah
    Some junk
    Reminds me of desert racing haha. Lots of bailing wire and ratchet straps between the start and the finish line
  27. Oct 27, 2019 at 8:56 PM
    #147
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    Very entertaining build thread! Thanks for sharing.
    The way you wheel that thing and break shit, have you contemplated going with a full build? Engine cage tied into tubular bucket replacements, and full LT, or maybe solid axle front? You obviously have the fab skills to do it.
  28. Oct 28, 2019 at 1:31 PM
    #148
    01erionracing
    Jimmy
    Full LT will be my ultimate goal on the Gen1, it will be done in the near future.
  29. Oct 28, 2019 at 2:09 PM
    #149
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Before the Turkey Run?
  30. Oct 29, 2019 at 8:36 AM
    #150
    01erionracing
    Jimmy
    Hahaha - Maybe before the Turkey run next year homie!
