Bilstein 5100’s on front
Discussion in 'Suspension' started by CARLHEIZER, Oct 13, 2019.
  1. Oct 14, 2019 at 9:11 AM
    mrmisky1969
    mrmisky1969 New Member
    James
    Torrance, California
    2016 Toyota Tundra TRD
    5100 Bil’s on Middle Setting 275/70r18 Falken WildPeak ATs Rear Firestone Airbags ECCP Towing Mirrors LED Int/Ext lighting White Out Front Door Handles Blackout Emblems Custom Painted Front Grille
    Thanks Carl! Any suggestion of using the 18" factory Wheels with 33 or 35'a - might even go with 34's
  2. Oct 14, 2019 at 9:52 AM
    CARLHEIZER
    CARLHEIZER [OP] New Member
    San Diego
    2019 TUNDRA 1794 EDITION
    LINE-X, BAK MX4 WITH BAK BOX, UPGRAGED SOUND SYSTEM BY OEM AUDIO + AND CERAMIC WINDOW TINT - ALL SIX WINDOWS.
    I am not the guy to talk to as I want to wear out my 275/65s first. But when they do wear out, I will probably just go with 285/70’s as long as I am towing an 8,000 trailer.
  3. Oct 14, 2019 at 9:55 AM
    mrmisky1969
    James
    Yes I agree as im doing the same pulling!
  4. Oct 14, 2019 at 10:22 AM
    The_Bob88
    The_Bob88 New Member
    08 Tundra Crewmax
    5100s on the middle setting
  5. Oct 14, 2019 at 10:58 AM
    mrmisky1969
    James
    Thanks Bob, looks good!
  6. Oct 14, 2019 at 12:01 PM
    CARLHEIZER
    San Diego
    Yeah I think the middle is going to work best for me.
  7. Oct 14, 2019 at 12:45 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    The consensus is that 2" and under on the front does not require any additional spacers/diff drop. The TRD Pro comes factory with about 2" up front and Toyota makes no additional changes to suspension or otherwise beyond the shocks
  8. Oct 14, 2019 at 1:04 PM
    CARLHEIZER
    San Diego
    Good to know.
  9. Oct 14, 2019 at 2:24 PM
    Ibtang1794
    Ibtang1794 New Member
    IMG_7329[1].jpg 5100s top setting 285/65/20s
  10. Oct 14, 2019 at 6:04 PM
    mrmisky1969
    James
    Thanks Jimbo for the info! Makes sense why they use a spacer on 3” leveling lift. Lot of guys using the middle setting and I think I’ll do the same to avoid mechanical issues. Especially for what I tow.
  11. Jan 8, 2020 at 1:46 PM
    'fro
    'fro New Member
    2014 Tundra 1794 - MGM
    None YET
    Are you guys doing your own install on the 5100's? I did mine on my Tacoma in my garage by doing the following. Hopefully will work on the Tundra too:
    - Jack up truck / put on jack stand (think I kept it on the jack and used 2nd jack for 2nd step)
    - Put a jack under LCA and jack up enough to compress spring and take pressure off of shock
    - unbolt shock from the top and then slowly lower the jack under LCA
    - would have to then loosen the frame > UCA bolts to get it to go down far enough to remove spring / shock. (mark alignment first to get back close when re-assembling)
    - do reverse to install
    - go directly to alignment shop! :)
  12. Jan 8, 2020 at 11:11 PM
    GATORthaBEAST
    GATORthaBEAST New Member
    2019 Tundra SR5 2WD Silver Sky Metallic
    18x9 METHOD MR312 w/BFG A/T KO2s, TRD DUAL EXHAUST, TRD PRO SKID PLATE, BLACK TOYOTA NERF BARS......work in progress.
    I did mine on the middle setting with a Coachbuilder shim on each side. It’s not exactly level but I love how it looks. I need to get some straight on side pics too.
  13. Jan 11, 2020 at 4:48 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    I have installed them both ways, taken the assembly out and then used a spring compressor and the method you described above, only issue I had with the method above was on the middle setting the spring was a little tall to get back under the perch, doable but took some work.
  14. Jan 14, 2020 at 6:42 PM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    Phog .. what do you think about the steering kit? I did almost exact same setup as you, except I went top setting for fronts w/same shims, and did +3 shackles in back. This leaves me visually level with exactly 1” rake from center hub measure and no tundra lean with the shims. Spoke with David on the phone and he said not necessary for the steering kit with this setup. You getting any creaking over uneven driving? ie driveways at angle from the road etc etc
