Factory Alarm
Discussion in '2nd Gen Tundras (2007-2013)' started by DevilSquid91, Dec 13, 2016.
  1. Dec 13, 2016 at 3:03 PM
    DevilSquid91
    DevilSquid91 [OP] New Member
  2. Dec 13, 2016 at 6:55 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I highly recommend the Fortin products. Check out the EVO-One or the EVO-All. They have fantastic installation instructions and they give you a one time use pass to www.wirecolor.com which makes the installation even easier. It allows you to use your factory FOB.
    I still wanted some extra range so I'm going with a CrimeStopper remote start, no programming from a dealer is required.
  3. Dec 13, 2016 at 6:56 PM
    Nor7
    Yeah, he's selling Crimestopper products. I ordered my Crimestopper from Amazon for less than $100. But you'll also need an immobilizer bypass. If you just want to use your factory FOB, get the Fortin bypass, it's all you'll need. You'll probably also have to buy their programmer.
  4. Dec 13, 2016 at 7:39 PM
    DevilSquid91
    @Nor7 Thanks brother, would you happen to know the part number for the crimestopper unit on Amazon
  5. Dec 13, 2016 at 7:45 PM
    Nor7
  6. Dec 13, 2016 at 8:01 PM
    DevilSquid91
    Thanks again @Nor7 , sorry to be pain in the assignment, but does evoall bypass come with the t harness?
  7. Dec 13, 2016 at 9:03 PM
    Nor7
    I don't think the Tundra is t-harness compatible. Attached will help.
    Also, if you get the Crimestopper, don't get the evo-all or the evo-one, they will work but are overly advanced.
    Get the Evo-key, it is pre-loaded with software and is a simple bypass that works with the crimestopper.
  8. Dec 13, 2016 at 9:04 PM
    Nor7
    Oops, just realized yours is a 2016. Might not be 100% applicable but I don't imagine the connectors will be much different.
  9. Dec 16, 2016 at 1:20 PM
    Jcars
    Jcars New Member
    Jamie
    2017 Tundra Platinum
    Tint, 2.5' leveling kit, exhaust, intake, 34.5' tires, 20' black wheels
    Does anyone know the range of the OEM remote start for the 2017 Tundra?
  10. Dec 16, 2016 at 1:55 PM
    Nor7
    I believe they are limited to your key FOB range. Test it yourself, take a few steps away and try it, rinse and repeat.
    NewImprovedRon likes this.
