best way to refinish black textured mirrors?
Discussion in 'General Tundra Discussion' started by Jwood562, Oct 11, 2019.
  1. Oct 11, 2019 at 11:34 AM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    I picked a used set of tow mirrors and want to refinish them, they have some scratches and a little fading.
    I initially wanted to color match but the more I look at them I may want to stick with the black look.
    Is it trim paint? or a flat black and flat clear?
    Also does someone have a diagram to disassemble tow mirrors? If I could find that it would make the paint job easier and better
  2. Oct 11, 2019 at 11:40 AM
    My Tundra sits out 365 24/7, and my cowl was fading, I took off and used trim paint 3 coats, looks new still, did about 2 years ago
    And do you mean take mirror part off? That I don't know, sorry
    HappyGilmore likes this.
  3. Oct 11, 2019 at 11:57 AM
    Jwood562
    2013 Tundra 4x4
    what trim paint did you use?
    yeah I mean taking the glass off and possibly taking the telescoping parts apart.
  4. Oct 11, 2019 at 11:59 AM
    Rust Oleum trim bumper paint spray can
  5. Oct 11, 2019 at 12:01 PM
    I know someone on here has taken the mirror glass off, just forgot who, they posted it on here
  6. Oct 11, 2019 at 12:44 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I used this stuff on the bed rail caps of my 1st gen and it worked really well, and held up great! I recommend it. Easy touch up if needed. Just did a light scuff, and cleaned with acetone.
  7. Oct 11, 2019 at 12:51 PM
    Jwood562
    2013 Tundra 4x4
    Any need for a matte clear on top of the trim paint
  8. Oct 11, 2019 at 12:52 PM
    HappyGilmore
    Trent
    Lakewood CA
    Ooooo now that you mention it, I think I did do that. Its been awhile.
  9. Oct 11, 2019 at 1:55 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    @Black Wolf redid some mirrors recently. Might have some insight.
    Black Wolf likes this.
  10. Oct 11, 2019 at 4:16 PM
    Aurora CO
    I recently de chromed my mirrors. Cleaned then prepped with alcohol. Used Rustoleum 2X Acrylic Enamel. I used semi gloss but you can get matte black. I used a whole can. Several coats. Came out quite nice.
  11. Oct 11, 2019 at 6:36 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    If you hit an auto body supply store. Ask for SEM trim black no need to clear. Trick to make it look good is many light coats like 5-7 and it will look like new and last
  12. Oct 11, 2019 at 10:21 PM
    Jwood562
    2013 Tundra 4x4
    found it on Amazon for $16 shipped. thanks
  13. Oct 18, 2019 at 9:24 PM
    Jwood562
    2013 Tundra 4x4
    @Theyfzman
    just a follow up, i got the SEM paint as recommended by @Theyfzman. HOLY CRAP! amazing results. they look like new.
    I will be posting pics when I pull the tape and put the smoked lights back in.
    it was super simple too, just a red scotch brite scuffing, rinse and clean. tape the glass, wipe with alcohol and spray light coats
  14. Oct 20, 2019 at 3:46 PM
    Theyfzman
    Pa
    08 TRD
    Good deal !! Glad that worked out for you
