Recovery Board Mount
Discussion in 'Recovery & Gear' started by NorthEastBeast, Oct 6, 2019.
  1. Oct 6, 2019 at 3:04 PM
    NorthEastBeast
    NorthEastBeast [OP] New Member
    2019 TRD Pro
    Me and my body did some brain storming and made some mounts for my recovery boards.
    Material used was 1/4" aluminum and 3/8" hardware.
    These are the genero X-Bull brand boards made famous by eBay and Amazon.
    I have used them a couple of times with good results, and plan to run them until I bust one. Then I will upgrade to some maxtrax.
    The para-cord keeps the tension plated retained so they do not get lost when the boards are in use.
    I also made a new axe/shovel mount because the previous model that I made and used for a couple years needed some improvements.
  2. Oct 6, 2019 at 3:09 PM
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    Nice looking rear!
    NorthEastBeast[OP] likes this.
  3. Oct 6, 2019 at 3:11 PM
    NorthEastBeast
    2019 TRD Pro
    Paint used was semi gloss black with primer
    aperezsh and GODZILLA like this.
  4. Dec 2, 2019 at 7:56 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Love this solution. Plan on buying those same boards and mounting them that way as well. Thanks for the idea!
  5. Dec 2, 2019 at 8:00 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Very clean, nicely done! What hardware did you use to attach them to the track?
    mountainpete likes this.
  6. Dec 3, 2019 at 8:29 AM
    NorthEastBeast
    2019 TRD Pro
    I purchased t-nuts from Amazon and sourced all of the 3/8" hardware at a local hardware store. I used some washers in front of the t-nuts to distribute the weight onto the rail a little bit.
    I can get you some pictures of how they are mounted if you need them.
    GODZILLA and KnuckleHD[QUOTED] like this.
  7. Dec 3, 2019 at 8:33 AM
    KnuckleHD
    That would be awesome if you could grab a picture of that part whenever you have time. I’m a week or two out from doing this myself so no rush. Thanks!
  8. Dec 7, 2019 at 2:46 PM
    NorthEastBeast
    2019 TRD Pro
  9. Dec 7, 2019 at 2:51 PM
    NorthEastBeast
    2019 TRD Pro
    Some of the hardware was sourced online using the below search terms.
    T Slot Nuts For Toyota With 3/8-16 Thread
    3/8" bolts. I think they were 6" or 7" long.
    Plastic 5 Star Go Thru Tool Jig Knobs 3/8 x 16 Metal Threaded.
    4 pieces 1/4" X 2" ALUMINUM 6061 FLAT BAR 14" long T6511 .25" Mill Stock
  10. Dec 7, 2019 at 3:56 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That’s a nice setup!
  11. Dec 7, 2019 at 5:26 PM
    TheBeast
    TheBeast The Beach
    Scott G. and KnuckleHD like this.
  12. Dec 7, 2019 at 5:51 PM
    KnuckleHD
    Awesome, thank you!
  13. Dec 7, 2019 at 5:55 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    ToyoD and NorthEastBeast[OP] like this.
  14. Dec 8, 2019 at 6:19 PM
    NorthEastBeast
    2019 TRD Pro
    You're welcome
  15. Dec 9, 2019 at 9:52 AM
    Scott G.
    Scott G. New Member
    Scott
    2017 Magnetic Grey Tundra SR5
    2 inch wheel spacers, stubby antennae, LED tail light bar, pop&lock tailgate lock.
  16. Apr 20, 2020 at 3:24 PM
    dittothat
    dittothat New Member
    SD
    2016 MGM Platinum
    Used the ideas here but modified slightly 9322C52D-6840-4D5D-847B-F80E213EA865.jpg
    aussieaarons likes this.
  17. Apr 22, 2020 at 1:31 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    Made some brackets with parts found at the hardware, 2 M8 bolts off Amazon and some Toyota Bed rail Plastic nuts. Seem to Work well
  18. Apr 22, 2020 at 1:33 PM
    spdrcer26
    spdrcer26 New Member
    Bakersfield, CA
    2017 Crewmax
    Awesome DIY job - well done
  19. Aug 10, 2020 at 1:50 PM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    What’s the size of hardware that is used to mount the bed rails to the bed of the truck anyone know or have experience with building there own on this forum that can share there knowledge.
  20. Aug 3, 2021 at 4:25 PM
    outlaw.taco
    outlaw.taco New Member
    Houston
    3 zip ties
    ToyoD, BravoDeltaRomeo and Black Wolf like this.
  21. Aug 3, 2021 at 4:47 PM
    Aurora CO
    Kuul, but 3 quick snips and they're gone......faster than cat thieves....
  22. Aug 3, 2021 at 4:52 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Not sure at this point.
    Unless if you have a tonneau, then cool, but it’ll get stolen real quick.
    Get some t-slot nuts to secure it to your rails.
    Black Wolf likes this.
  23. Aug 3, 2021 at 8:12 PM
    outlaw.taco
    Houston
    I bet I can cut that line faster
    :sawzall:
  24. Aug 3, 2021 at 8:17 PM
    Aurora CO
    That would a bit noisy and not as fast as my pocket knife...and my tunny is in my back yard. Bad scenario for the perp that f**ks with my truck or anything else....career ending decision...just sayin
