1" Bora wheel spacer
Discussion in 'Wheels & Tires' started by hdfanatic, Apr 21, 2017.
  1. May 31, 2017 at 9:26 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Have you actually had .75" on the front with stock trd 18's or know someone who does? I measured my studs. 1" frt and 1 1/8 rear. So the recess in the wheel would need to be a full 1/4" instead of only 1/8 for the rear. That recess doesn't seem that deep and it's hard to measure accurately.
  2. May 31, 2017 at 9:36 PM
    Voyagermike
    Voyagermike New Member
    California
    The bora 1in will fit on the front with no stud trimming on trd pro wheels and suspension.
    EvoTundra, COTundra23 and MDHinSD like this.
  3. May 31, 2017 at 9:38 PM
    Voyagermike
    California
    With the bora 1in spacer and stock studs there are just about flush with the edge of the spacer.
    I don't see how the .75 would fit WITHOUT trimming the studs on the front wheels
  4. May 31, 2017 at 9:41 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Did you put 1" on the rear to?
  5. May 31, 2017 at 9:42 PM
    Voyagermike
    California
    No just the front.
  6. May 31, 2017 at 9:44 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    How does it look with the fronts out further than the back?
  7. May 31, 2017 at 9:46 PM
    Voyagermike
    California
    Don't have any pictures at the moment. I'll take some pictures this weekend. I need to re torque the studs.
  8. May 31, 2017 at 9:53 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Cool, I'm interested in seeing how it looks.
    Voyagermike likes this.
  9. Jun 1, 2017 at 4:14 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    .75 on front will require post trim.
    first hand experience
    Go 1.25 f/r
  10. Feb 4, 2019 at 2:43 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Have you done this yet? I was just wondering this, what 1.25 on the rear and 1 on the front would look equal, since the front is already wider by a little bit. Pic please if you have done the swap. Thanks!
    15whtrd and Mr Swervlin like this.
  11. Feb 4, 2019 at 4:18 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Are you still running the 1" spacer on factory wheels?
    15whtrd likes this.
  12. Feb 4, 2019 at 5:02 PM
    15whtrd
    15whtrd Mr. Blonde
    I know this is an old post and you haven’t been around in a while but here’s a shot in the dark. Did you ever try the spare tire to see if it will clear in the rear? I’m wondering if the spare tire has the voids in the back of the rims like our stock wheels do.
    Mr Swervlin likes this.
  13. Feb 5, 2019 at 6:23 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Resurrecting this thread just for clarification... I have stock TRD wheels now, and in the future plan to put black OEM TRD Pro wheels on. Can I use 1” Boras on the rear using these OEM wheels. From what I understand, these OEM wheels do have enough of an indent where the 1” spacer will clear the lugs.
    619Tundra likes this.
  14. Feb 5, 2019 at 6:31 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That's a good question. It would suck to get stuck with a flat next to the road not being able to get your spare on. The standard steely spares do however seem to have a recess, so it should be good.
  15. Feb 5, 2019 at 6:38 AM
    15whtrd
    15whtrd Mr. Blonde
    Haha thanks! I guess I could’ve crawled my butt under there an looked! But to my defense, it’s been raining lol. Just asking because I’ve considered spacers but want as minimal as possible. Even considering .75” front and 1” rear as I’ve just seen that they aren’t the same track width.
  16. Feb 5, 2019 at 6:47 AM
    Boerseun
    Ferdie
    Sarasota Florida
    My truck is parked right outside the door. I am too lazy to crawl under there, so I just held my phone down there and took a bunch of photos in all directions hoping to catch one. LOL. Sucks to be lazy.
    I also want just a little bit - 0.75 would be perfect if that could work.
    15whtrd[QUOTED] likes this.
  17. Feb 6, 2019 at 8:51 AM
    Halfjap
    Halfjap New Member
    Reno, NV
    2015 White Tundra Crewmax
    Yes I am. I have had zero issues. I check them every time I rotate my tires. Have about 50,000 miles with them on everything from daily driving, towing and off roading.
    MDHinSD and Mr Swervlin[QUOTED] like this.
  18. Apr 6, 2019 at 6:05 PM
    tstieb
    tstieb New Member
    2014 CM TRD
    Just had a shop tell me my studs are rubbing on the rear wheels with my 1in Bora spacers. I installed them 40k miles ago and either didn't notice or they weren't at that time. Numerous tire rotations at Discount and they have never said anything either. Not sure if cutting them down is worth it or necessary at this point.
  19. Apr 6, 2019 at 6:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I think I would lathe out small recesses into the wheel before I’d cut the lugs. Honestly I wouldn’t do neither, I would just buy 2 new spacers.
    GodlessPro likes this.
  20. Apr 6, 2019 at 6:51 PM
    #50
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    What are you running for wheels? Stock Off Road wheels? I want to run 1” with my stock wheels....Based on what others have said on here, it will work with the recesses on the back of the OEM wheels.
  21. Apr 6, 2019 at 9:35 PM
    #51
    tstieb
    tstieb New Member
    2014 CM TRD
    I have the OEM 20s that use to come on Limited and Platinums. Think just Limited has them now
  22. Apr 7, 2019 at 7:49 AM
    #52
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Do you know if your wheels have the OEM indents that supposedly allow for 1” spacers to work?
  23. Apr 7, 2019 at 9:14 AM
    #53
    tstieb
    tstieb New Member
    2014 CM TRD
    Couldn't say. I might try to do an image search to check before I opul the tires off and see.
    Hammy68[QUOTED] likes this.
  24. Apr 10, 2019 at 5:35 PM
    #54
    oneup
    oneup New Member
    Cincinnati
    17 cm
    Can anybody take pic of how much stick on the rear? I’ve see plenty of front but haven’t seen how much stick out on rear. Both 1” and 1.25”. Have anybody run 1” on front and 1.25 on rear?
  25. Sep 17, 2019 at 5:18 AM
    #55
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    I wanted to run .75 Boras, but that seems out of the question.
  26. Sep 17, 2019 at 5:21 AM
    #56
    619Tundra
    I'm running TRD OEM wheels.
  27. Oct 4, 2019 at 3:27 AM
    #57
    619Tundra
    Do you have TRD Offroad wheels?
  28. Oct 4, 2019 at 3:43 AM
    #58
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Running 1.25 all around. I love it and it’s flush with truck sides. Doesn’t stick out at all. 275/70/r18
  29. Oct 4, 2019 at 3:46 AM
    #59
    619Tundra
    I'm running 285/65/18 on TRD Offroad wheels.
  30. Oct 4, 2019 at 4:35 AM
    #60
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I'm using 1" Boras with 2014 Platinum wheels. I only have them in the fronts right now though.
