TRD Cold Air Intake upgrade for my 5.7L... Yes/No?
Discussion in 'Performance and Tuning' started by InfernoB, Aug 13, 2016.
  1. Jul 13, 2019 at 8:48 AM
    #61
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Is there any way you could measure the outside diameter of the TRD lid outlet? I believe the factory is 3.75”. Just wondering if the TRD’s is 4”
  2. Jul 13, 2019 at 11:13 PM
    #62
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Nvm. My TRD lid came in. It is 4” for those who may care 152F664B-1738-4D32-86A8-CB1AF2E4ACAE.jpg
  3. Jul 14, 2019 at 1:15 AM
    #63
    kgb4187
    kgb4187 New Member
    Why are you naked tho?
  4. Jul 14, 2019 at 5:40 AM
    #64
    Kyk1e
    Kyk1e New Member
    Kyle
    Limerick, Pa
    2017 Toyota Tundra TRD Pro
    Got a part# from Sparks?
  5. Jul 14, 2019 at 5:43 AM
    #65
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
  6. Jul 20, 2019 at 11:45 AM
    #66
    MR TRD PRO
    MR TRD PRO New Member
    Queens, NYC
    2019 VooDoo Blue Tundra TRD Pro
    HP Tuned
    So far so good, my TRD upper lid is holding up nicely!
  7. Jul 20, 2019 at 12:28 PM
    #67
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    I still haven’t had a chance to install mine. Something about having to be home.
    New_DoorDing likes this.
  8. Aug 4, 2019 at 9:44 PM
    #68
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    707FC4EE-96B5-4262-8663-81F33D927FEC.jpg F42FB74A-0AB9-48E5-915F-F9E8B4C90214.jpg Today I installed my “customized” intake. TRD intake accelorator, TRD intake box top, aFe “not so” super stock intake. Ended up with vibrant couplers as well. Also put a radium catch can at same time. I’m extremely happy with the results. Looks and sounds great.
    BamaMan44 likes this.
  9. Sep 27, 2019 at 6:39 AM
    #69
    TundraPro15
    TundraPro15 New Member
    Quick question. I have a 2015 TRD Pro. I already have the TRD Box. Does the TRD Box already have the air intake accelerator installed or do I need to purchase that and add it in??
  10. Sep 27, 2019 at 6:49 AM
    #70
    TundraPro15
    Sitting Sideways likes this.
  11. Nov 3, 2020 at 5:03 PM
    #71
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    I have this same question!
  12. Nov 3, 2020 at 5:41 PM
    #72
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Never know until you check. Pull your lower box and remove from your fender to confirm. Should take less than 30mins with beer break included.
  13. Dec 31, 2022 at 2:45 PM
    #73
    Bergy24
    Bergy24 New Member
    I know this is an old thread, but can I just replace the top and use the OEM parts (Tubes) that came with my truck?
  14. Dec 31, 2022 at 2:53 PM
    #74
    RobertD
    Robert
    DFW, Texas
    You can but that won't change much. The straight tube that comes with the TRD intake makes the biggest change. The stock tube has a protrusion on it.
    So if you want the cooler looking lid, go for it. But your performance and sound won't be changing much if any.
    Bergy24[QUOTED] likes this.
  15. Dec 31, 2022 at 2:55 PM
    #75
    Bergy24
    Bergy24 New Member
    Understood, Thanks
    RobertD[QUOTED] likes this.
  16. Dec 31, 2022 at 3:20 PM
    #76
    Aurora CO
    My 22 Frontier has an OEM cold air intake. No need to spend $300 or $400 plus on a CAI for little if nothing to gain. Buy a RCI skid......
  17. Dec 31, 2022 at 3:41 PM
    #77
    Daganh62
    Daganh62 New Member
    2017 TRD Off Road
    What's the purpose of a catch can?
