Rear Differential Gear Oil Recommendation
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 8, 2019.
  1. Sep 14, 2019 at 5:30 PM
    15whtrd
    15whtrd Mr. Blonde
    That does suck. Lucas, royal purple and Red line have always been my secondary go to besides OEM. I’ve pretty much been a M1 guy for over 20 years. But when I’m feeling like I want to be putting top of the line, I tend to go with Lucas or royal purple as well as red line. If Amsoil was readily available without ordering I would go that way. The fact that I don’t see it on the shelves makes me not want to use it.
    Pudge likes this.
  2. Sep 15, 2019 at 10:09 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    So in my mind the truck drove smoother today on my way to work since the new rear diff fluid change.
    Also in ordered 2 liters of Ravenol 75W transfer case oil from Amazon for the T case. It was about $35 for the fluid compared to $25 for M1 75w90 that some people are using against what is recommended. To me $10 is more than worth it for piece of mind and doing it right. I'll change the T case one day this week then the front diff next weekend. Thanks @15whtrd for all the great info.
    15whtrd likes this.
  3. Sep 15, 2019 at 4:37 PM
    Bigbird57
    Bigbird57 New Member
    #metoo, Valvoline 75W-90 synthetic
    For differentials only
    Pudge likes this.
  4. Sep 15, 2019 at 5:44 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I buy this so that I can buy more of this..
  5. Sep 17, 2019 at 7:37 AM
    scharring100
    scharring100 New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    I live far from my closest dealership but have over 35000 miles on my tundra so need to have the transfer and differential fluids changed. If I have that done at an independent repair facility with that void my warrantee? I can not find anything in the Manuel one way or the other
  6. Sep 17, 2019 at 8:03 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    Amsoil is definitely great stuff, been using it for about 4 years on all my vehicles. I had used Royal purple before, but their formulation changed about 6 years ago and the quality of the additives went down.
    I was also a redline guy for while, but after seeing that Amsoil offers better protection and has a better cleaner package, it's been my go to oil for engine and transmission/differential.
  7. Sep 17, 2019 at 8:06 AM
    Shaggypeach
    Shaggypeach New Member
    Based on the graphs, amsoil is pretty good, correct?
  8. Sep 17, 2019 at 8:14 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Correct
    Shaggypeach likes this.
  9. Sep 17, 2019 at 8:24 AM
    Pudge
    CT
    No it won't void your warranty as long as they use the correct fluids.
    It seems 75w90 is acceptable for differentials, dealers use this weight.
    Dealers also use 75w90 in the transfer case which is not even close in weight to the recommended 75w. If you go to a shop to get it changed, i recommend buying 2 liters of Ravenol 75w from Amazon and tell them to use that in the T case.
  10. Sep 17, 2019 at 2:37 PM
    kevine0001
    kevine0001 New Member
    Kevin
    same here
  11. Sep 17, 2019 at 3:01 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Just a PSA that particular oil is great but it will cause premature wear on the inside of a manual transmission. It is spec'd as GL5 which is what most Toyota transmissions call for however, the limited slip additives in it are known to eat up brass and copper.
    My 99 Tacoma's W59 had the 3rd and 5th gear syncro's go out at 190k. Now I use Stalube 85W90 non syn. It's cheap stuff but does great in the W59.
  12. Sep 17, 2019 at 3:29 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Schaeffer’s 75w-90 in my diffs and t case....but mine is an 08 and specs that in all 3. Truck is almost entirely Schaeffer’s except for the transmission. Diffs, PS, oil, driveline grease are all Schaeffer’s
    jc153 likes this.
  13. Sep 20, 2019 at 8:49 AM
    cb556
    cb556 New Member
    Just a thought, but that amsoil gear oil study was done over 12 years ago and all of those gear oils have been reformulated many times since then, I wouldn't put too much faith in it. I've used the Mobil 1 and Delvac 1 75W90 with good results in the diffs. Didn't like the way the ravenol 75W worked in the Tcase so used the Toyota OEM 75w there. In other trucks I've used the current production Lucas gear oils with excellent results as they are now very low friction, so will try them next in the Toyota.
  14. Nov 6, 2019 at 10:29 AM
    kevine0001
    Kevin
    For clarification, I use the M1 75w90 for my diffs. After reading up, I have ordered and will be using 75w for the tcase
  15. Nov 7, 2019 at 8:52 AM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    This is the first I’ve heard of someone not liking the Ravenol, what difference were you noticing?
  16. Nov 7, 2019 at 9:08 AM
    kevine0001
    Kevin
    I've been using Mobil 1 synthetic in all my cars for the past several years. Jeep, Land Cruiser, Tundra, Tacoma. All no problems. However, it also has to do with changing it regularly. I think that's as important as the type of oil you use. You could use the best oil on the planet. If you let your truck go 100K between changes, then it won't matter.
