Upgrading to Power Fold Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by FatBrian, Apr 17, 2017.
  1. Sep 9, 2019 at 11:44 AM
    #181
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    I would also like to be part of the Pilot program. I have a 2018 Platinum that has power folding mirrors from the factory.
    I envision a modification that folds the mirrors out when starting and fold them in when the ignition is turned off. I would expect the factory button to operate manually with the switch will still work.
    I would also like to have a connector that would allow me to wire up a switch of my choice to the harness that would be an "Override Button" and when pressed it would basically turn off the automatic folding. I mention this because I can see on a tight trail I would most likely have my mirrors folded in and on the trail there are times where you turn the truck on/off/on etc. and I would just like to override when I want.
    KTJO 4x4 and AgileTundra like this.
  2. Sep 10, 2019 at 6:49 AM
    #182
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    Same... but with 1794 Edition..
    KTJO 4x4 likes this.
  3. Sep 10, 2019 at 7:02 AM
    #183
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    member joins the community offering to develop a system which has already been described and laid out in Tacoma. Then forum members come in to detail how they want the system, not even released yet, tailored to their specific desires...
  4. Sep 10, 2019 at 8:22 AM
    #184
    showtime240
    showtime240 New Member
    Do you need any more pics?
    I have a 2015 SR5.
    I can send you pics of the truck wire harness, factory 2015 non folding mirror harness, and factory Platinum folding mirror harness.
    Let me know what you need, and can do it by this weekend.
    KTJO 4x4[QUOTED] likes this.
  5. Sep 10, 2019 at 10:54 AM
    #185
    tanuhouson
    tanuhouson New Member
    Afternoon,
    I was wondering if anyone can help out with some issues I am having. I am helping my cousin out and adding the power folding mirrors to her A1 tow mirrors. She has a 2015 Tundra TSS I think. This is my first shot at this so I am not entirely sure if I am correct. The harness for the blue and yellow wire (the folding mirror loop is what I thought it was called) had broken, so I wire connected (butt connectors) them on driver and passenger. The power is tapped into the PWR outlet and it worked for awhile. When we buttoned the car back up, the fuse kept on blowing. I think the wire connection may have snagged or got disconnected. Can you take the yellow and blue wire that allows folding and insert into the existing tow light harness on the mirror and car(on an empty spot). Any help would be great?
    Also, is there a special tool to pull fuses in these trucks?
  6. Sep 10, 2019 at 11:09 AM
    #186
    B737
    Jersey Shore
    https://www.tundras.com/threads/upgrading-to-power-fold-mirrors.12452/#post-600399
  7. Sep 11, 2019 at 8:24 PM
    #187
    B737
    Jersey Shore
  8. Sep 12, 2019 at 10:57 PM
    #188
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Send me a PM and I can start it for when I get to that point :thumbsup:
  9. Sep 12, 2019 at 11:02 PM
    #189
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Same thing :thumbsup: I can star it so when the time comes I can put you down as one of the 10
  10. Sep 12, 2019 at 11:05 PM
    #190
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Ok. The switch itself is an override over the system. It controls the system. So if you have the switch pressed in for Fold, then whether you use your key fob and hit lock or unlock, your mirrors will do nothing. They will not do anything until you press the button on your switch and Unfold your mirrors. That unlocks basically your mirrors and allows them to go back to being open to the system
  11. Sep 12, 2019 at 11:16 PM
    #191
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    UPDATE:
    Ok you SR5 Folks, and there seems to be a lot of you over here in the Tundra World compared to the Tacoma World. I may have the main harness with these Connectors.
    Here are some pics of the PNP Harness with the SR5 model OEM F/M Connectors that were delivered to me last night. I was able to mock up the FIRST SR5 Plug-N-Play Power Folding Mirror Harness tonight that I will be sending off to one of my Tacoma First Batch SR5 testers tomorrow to make sure everything matches up prior to the full release! If all works out, we are 100% good to go with EVERYTHING and I think all minor issues that were brought up during the testing phase have been addressed!!!:bananadance:
    SR5 PLUG-N-PLAY HARNESS
    3RD GEN TACOMA PLUG-N-PLAY HARNESS
    What is the difference...Here is the SR5 OEM Connectors
    How do you like my little mock-up of the 3RD GEN TACOMA OEM O1 Connector :rofl:
    I thought it would be nice to show how you connect the Power Folding Motor Wires (Black & Green) from the Extension Harness, as well as the Power Window PNP Harness (Black) and the Power Window Master Switch PNP Harness Wires (White) into the OEM O1 Connector.
    For you guys, you wouldn’t have the Power Folding Mirror Extension Harness because your OEMs have the Power Folding Motors already. So you would take the Power Motor Wires, which we would have a PNP Harness, and it would Connector to this Harness. I have my vendor currently working on your Harness as we speak but I will not release it until after the Tailgate Locks are all out and one other mod I haven’t mentioned yet :D
  12. Sep 13, 2019 at 11:41 AM
    #192
    showtime240
    Man, they look so professional.... I cant wait!
  13. Sep 13, 2019 at 12:00 PM
    #193
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    Will that harness be the same for the Limited model as well?
  14. Sep 13, 2019 at 1:39 PM
    #194
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Sign me up once you have a kit for 2017 Tundra SR5.
  15. Sep 13, 2019 at 5:30 PM
    #195
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Has anyone ordered this part and do you have an actual part no I can get from you please
  16. Sep 13, 2019 at 5:31 PM
    #196
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Stay tuned...it’ll be coming up after a couple of projects get released
  17. Sep 13, 2019 at 6:04 PM
    #197
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Right now I’m trying to get these Tailgate Kits released and finalized first. I’m getting the harness made right now. I have some mirrors on the way for the development process so I can see what exactly I’m working with, starting with the 3rd Gen Tundras. One thing at a time.
    showtime240[QUOTED] likes this.
  18. Sep 13, 2019 at 6:25 PM
    #198
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    @KTJO 4x4 Great work! Looking forward to your final product. I just bought 2013 Limited folding mirrors for my 2017 SR5 in anticipation of your harnesses. Thank you for taking the time to do this!
  19. Sep 13, 2019 at 6:26 PM
    #199
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    I must have missed the pictures or maybe it’s just because I’m trying to view it on my phone and it’s not cooperating. I’ll trying to see if I can find that on my computer or something to check out.
  20. Sep 13, 2019 at 8:04 PM
    #200
    B737
    Jersey Shore
    Here you go
    A2A82E42-46C9-4776-90B4-335D57D1ED53.jpg 7D3AA46E-20E5-477C-974B-DBCA0879A60C.jpg 6E90A6DC-236B-4CA3-96A4-8F14457F6673.jpg
  21. Sep 14, 2019 at 1:58 AM
    #201
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    So this is what a Tundra OEM Power Folding Motor Looks Like?
    So it seems like you guys don’t have connection plates like the Tacoma’s. It’s just one big arm? You have a similar spring as our BSM Mirror. Pain in the you know what to remove but once you get it out it’s out. So is that pretty accurate or is that a connection plate and not the huge arm of the mirror?
  22. Sep 14, 2019 at 7:23 PM
    #202
    Yotalou
    Yotalou New Member
    Lou
    2019 cement grey tundra
    19 I’m also interested in doing this mod
  23. Sep 15, 2019 at 6:26 AM
    #203
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    2019 Limited DC, just made room to park in the garage, mirrors must fold.
    I’m at a loss on what I’d need..
    Sign me up for anything string and a Lilly for the passenger side
  24. Sep 19, 2019 at 10:48 AM
    #204
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
  25. Sep 19, 2019 at 11:53 AM
    #205
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    They should bolt up just fine. The only thing is some members have mentioned that the wiring is slightly off on these - something about the BSM or puddle lights being mis-wired compared to stock. There are a lot of threads that mention the A1 mirrors.
    Tchase[QUOTED] likes this.
  26. Sep 21, 2019 at 9:55 PM
    #206
    Heavy_Guns
    Heavy_Guns New Member
  27. Sep 29, 2019 at 1:07 PM
    #207
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Ok I've looked all over.. Does anyone have the pinout diagram for the passenger and drivers mirrors for a 1794 set of mirrors? I know what the pin out on the truck is but I have a set of these mirrors with all the bells and whistles every single pin is taken. When I plug them they adjustment works, the turn signal works, the heat works, but I get a a BSM error. I know which wire on the truck that is for BSM (my truck is a 2019 limited) but I do not know which pin on the mirrors is for bsm, the mirrors are off a 2016 1794.
  28. Sep 30, 2019 at 7:00 AM
    #208
    JoeJob
    Joe
    New England
    Here is the info I used when I did my install, pulled from https://www.tundratalk.net/forums/t...4-sr5-platinum-power-fold-mirror-install.html
    Pin 1: Heat +
    Pin 2: Heat –
    Pin 3: Signal – (Running Light -)
    Pin 4: Signal +
    Pin 5: Puddle Lamp – (Already wired as common ground, needs rewire to make puddle lamps work)
    Pin 6: Puddle Lamp +
    Pin 7: Mirror Retract (+)
    Pin 8: Mirror Fold (–)
    Pin 9: Running Light +
    Pin 10: Mirror Vert (power)
    Pin 11: Mirror +
    Pin 12: Mirror Horiz (power)
    Pin 13: Auto-Dim –
    Pin 14: Auto-Dim +
    Pin 15-18: Memory Pins .. since I don’t have this, I didn’t research the actual pins, just know that these 4 are reserved for that.
    It should be either the the pink or purple wire for BSM+ (upper and lower right on the harness) and the negative is shared with the puddle lights.
    silverhack and Tchase[QUOTED] like this.
  29. Sep 30, 2019 at 7:02 AM
    #209
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Thanks! Long story short I found out I have a bad BSM indicator on the passenger mirror. It only took me all day to figure it out!
  30. Sep 30, 2019 at 7:20 AM
    #210
    JoeJob
    Joe
    New England
    Ha! Figures. I had trouble as well, since the mirrors I got didn't have BSM. I ended up installing new LEDs in the sail panels and they seemed to be working on startup, but would throw a BSM error when the system was triggered. Turned out the ECU didn't like the resistors I had installed for the LEDs. Once I removed the resistors, everything worked fine.
