Cold air intake
Discussion in 'Performance and Tuning' started by Redtundra18, Aug 29, 2019.
  1. Sep 13, 2019 at 1:01 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I mean a truck with turbo or SC would make that with a cai.
    Rica25 likes this.
  2. Sep 13, 2019 at 1:02 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Yeah, I'm not saying I believe it.
    Rica25 likes this.
  3. Sep 13, 2019 at 1:23 PM
    15whtrd
    15whtrd Mr. Blonde
    I take those dyno graphs with a grain of salt.
    I’d hate to say they were lying, but I figure they gave you the worst pull of the truck for the baseline, and the best pull with the intake for the gains. That would explain the large margin.
  4. Sep 13, 2019 at 2:31 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    I did a Stock Air Box Mod (SABM) on my truck. There's plenty of information about it if you're interested.
    Yotayoda, Rica25 and 15whtrd like this.
  5. Sep 13, 2019 at 2:48 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    LOLWUT? :rofl:
    It made 3 more HP and 7 more TQ.
    What part about that is unbelievable?
    19TundraPlatinum, Rica25 and 15whtrd like this.
  6. Sep 13, 2019 at 2:49 PM
    15whtrd
    15whtrd Mr. Blonde
    Rica25 likes this.
  7. Sep 13, 2019 at 2:51 PM
    15whtrd
    15whtrd Mr. Blonde
    I imagine he’s looking at the part of the graph at 3.25 X1000
    TTund16 and Winning8 like this.
  8. Sep 13, 2019 at 2:56 PM
    Rex Kramer
    Georgia
    Is it normal to do your pulls in 3rd gear?
    Rica25 likes this.
  9. Sep 13, 2019 at 2:57 PM
    15whtrd
    15whtrd Mr. Blonde
    I would think fourth gear should be the number.
    Rica25 and Rex Kramer[QUOTED] like this.
  10. Sep 13, 2019 at 3:03 PM
    15whtrd
    15whtrd Mr. Blonde
    Rica25 and Rex Kramer like this.
  11. Sep 13, 2019 at 3:06 PM
    Rex Kramer
    Georgia
    Yes it is.
    Rica25 and 15whtrd[QUOTED] like this.
  12. Sep 13, 2019 at 3:07 PM
    15whtrd
    15whtrd Mr. Blonde
    Then it doesn’t make sense that they would do a pull in third gear right? The only time I can recall seeing it done as if there wasn’t a true 1 to 1 gear to be had.
  13. Sep 13, 2019 at 3:11 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Did you change throttle body gasket?
    Rica25 likes this.
  14. Sep 13, 2019 at 3:31 PM
    Rex Kramer
    Georgia
    It only makes sense if you intend to mislead the public.
  15. Sep 13, 2019 at 7:09 PM
    AZTundra
    Paul
    Phoenix, AZ
    Think he's looking here under the graph:
  16. Sep 13, 2019 at 7:15 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I was looking at 3250 rpm, the useable rpm. Don’t really care about top rpm.
    TTund16 and Rica25 like this.
  17. Sep 13, 2019 at 9:31 PM
    TTund16
    TTund16 New Member
    wouldn't that test in 3rd, cook the trans fluid! lol
  18. Sep 13, 2019 at 9:33 PM
    15whtrd
    15whtrd Mr. Blonde
    I guess no worse than having it in S mode and flooring it.
    Rica25 likes this.
  19. Sep 13, 2019 at 9:47 PM
    TTund16
    TTund16 New Member
    Doesn't S4 or higher eventually shift out of 3rd where the torque converter is locked or has a chance to lock vs. keeping it in S-3?
    I guess if you are flooring it, it may never lock!
  20. Sep 13, 2019 at 9:50 PM
    #50
    TTund16
    TTund16 New Member
    Curious what's inside a TRD CAI besides a filter and some sensors? Is there a blower to force air or anything else that stock doesn't have?
    Rica25 likes this.
  21. Sep 13, 2019 at 9:59 PM
    #51
    15whtrd
    15whtrd Mr. Blonde
    The box is slightly larger in the lid area. It also comes with an airflow accelerator, which is basically a slightly larger and different shaped tube that connects the box to the inner fender wall. And I think it comes with a smooth intake tube that gets rid of the sound deadener built into the stock intake tube. Whatever you call that thing LOL
  22. Sep 13, 2019 at 9:59 PM
    #52
    AZTundra
    Paul
    Phoenix, AZ
    No blower, but it does use a different air accelerator. Stock is on the right. You can also buy this piece by itself without buying the whole intake kit.
    Rica25, TTund16[QUOTED] and 15whtrd like this.
  23. Sep 13, 2019 at 10:01 PM
    #53
    15whtrd
    15whtrd Mr. Blonde
    That’s what I did.
    The Afe super stock intrigues me even though I know it doesn’t do much.
  24. Sep 13, 2019 at 10:01 PM
    #54
    AZTundra
    Paul
    Phoenix, AZ
  25. Sep 13, 2019 at 10:03 PM
    #55
    AZTundra
    Paul
    Phoenix, AZ
    I picked up the TRD CAI during the April 40% off sale, so it was only $255. Otherwise I don't think it's really worth the asking price.
    Rica25, TTund16 and 15whtrd[QUOTED] like this.
  26. Sep 13, 2019 at 10:05 PM
    #56
    15whtrd
    15whtrd Mr. Blonde
    It sure is I candy though! And I would get some satisfaction knowing that it’s a Toyota part.
    Otherwise I do think the Afe super stock would be comparable alternative. It replaces that intake tube and filter. I already have the afe filter.
    Rica25 likes this.
  27. Sep 13, 2019 at 10:12 PM
    #57
    TTund16
    TTund16 New Member
    Do you have to change any settings or computer parameters because of intake air flow changes?
    Rica25 likes this.
  28. Sep 13, 2019 at 10:20 PM
    #58
    AZTundra
    Paul
    Phoenix, AZ
    Nope. The computer will compensate for the change as needed.
  29. Sep 13, 2019 at 10:45 PM
    #59
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Yup! All new cars or truck have so much sensors and ecu, it adjust itself.
    TTund16 likes this.
  30. Sep 17, 2019 at 1:39 PM
    #60
    Openroad98
    Openroad98 New Member
    Abraham
    Loveland, CO
    2019 Cavalry Blue SR5 TRD
    Stock for now...
    I plan on adding the S&B system shown below when finances improve, fun budget is greatly reduced after Dirty Deeds exhaust group buy... but the S&B has been tested (not on a Tundra) for air flow VS particulate capture, and blew K&K out of the water. As a service center manager, I have seen engine "dusting" or dirt making its way thru the K&N systems way more than I care to see. Pull an intake tube after a year of running K&N and usually you will find dust and dirt built up in the bottom of the intake pipe. I don't work for either company, just what I have experience with and what I will be installing. AFE seems good too in the diesel truck world, good filtration with air flow.
    https://www.sbfilters.com/cold-air-intakes/toyata-tundra-5-7l-07-12-intake-kit-75-5039?variant_id=81
    Rica25 and Yotayoda like this.
