Detail Kegs
Discussion in 'Detailing' started by War Machine, Sep 17, 2019.
  1. Sep 17, 2019 at 5:15 AM
    War Machine
    War Machine [OP] SSEM # 5 3MW
    ColoradoTJ likes this.
  2. Sep 17, 2019 at 5:34 AM
    briarpatch
    briarpatch New Member
    Way out of my price range. I'm more likely to try a Sure Shot sprayer...same idea.....a lot lower cost
    War Machine[OP] likes this.
  3. Sep 17, 2019 at 5:54 AM
    Tmank87
    Tmank87 New Member
    They think highly of it, clearly.
  4. Sep 17, 2019 at 6:02 AM
    LML 3500HD
    In your opinion, is this more directed at detail shops or towards the hobby detailers?
    Very mobile and user friendly, and if taking buying all the other products to match what this Keg can do, seems pretty legit.
  5. Sep 17, 2019 at 6:10 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    In what scenario would you use this instead of a water hose or pressure washer? If you decide to wash your truck on a road trip or something?
  6. Sep 17, 2019 at 6:16 AM
    War Machine
    To me this really only makes sense for someone who does this for a living, especially mobile. Somebody who does a lot of vehicles, and uses the same chemicals constantly. Especially considering they aren’t cheap. I just thought they were pretty cool.
    If someone had access to empty kegs, it probably wouldn’t be difficult to make one. If you want to wash your truck on road trip, just carry a bottle of Optimum No Rinse or Ech20 and a bucket.
  7. Sep 17, 2019 at 6:17 AM
    War Machine
    I’ve seen guys attach battery powered bike pumps to plastic pump sprayers.
  8. Sep 17, 2019 at 6:18 AM
    War Machine
    That’s why I said one of you should buy one.
  9. Sep 17, 2019 at 6:19 AM
    LML 3500HD
    Kinda what I was thinking. Pro on the go or someone on vacation. I was always surprised on how many people washed and waxed their tow rigs/campers while on vacation.
  10. Sep 17, 2019 at 6:25 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    The guy that tinted my windows had one plumbed directly to an air compressor, it was pretty sweet.
    For the money I’ll stick with a garden sprayer for my APC.
  11. Sep 17, 2019 at 7:06 AM
    GravityGear
    Aurora, CO
  12. Sep 17, 2019 at 7:32 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You could diy this for cheap!!!!!!!
  13. Sep 17, 2019 at 8:14 AM
    War Machine
    I keep some stuff to clean bugs off the grill while traveling, since they’ll eat into the paint pretty quickly.
  14. Sep 17, 2019 at 8:22 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    I like the idea, but it's a bit much, even for someone doing mobile detailing on a daily basis, the size and weight really make it hard to transport it. That's not to mention you will need a pump to keep it pressurized properly.
    I think the IK is still a better all around option.
  15. Sep 17, 2019 at 8:30 AM
    War Machine
    https://youtu.be/o4zvewZL-F4
  16. Sep 17, 2019 at 8:38 AM
    GravityGear
    Aurora, CO
    You won't need to pump the soda keg. You can precharge it with an air compressor, or use a mini co2 system https://beveragelements.com/product-category/gas-cylinders-regulators/portable-co2-keg-chargers/ Also the soda keg will hold 5 gallons of product.
  17. Sep 17, 2019 at 8:48 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Great idea, but considering the cost to build it, you can get the IKs for relatively the same price or sometimes cheaper, and produces a thicker foam, I think it still a better option.
    True, however the CO2 tank option will just add to the cost per wash for a mobile detailer, as the CO2 tanks will have to be replace once used up. Same goes for the air compressor, if the person doesn't already have one, they will need to get one for that application, but that cost will be lower as the compressor will not need to be replaced as often. Still the size and weight problem remains.
  18. Sep 17, 2019 at 9:02 AM
    GravityGear
    Aurora, CO
    Depends. If you're using an IK as a pro and spending time pumping the damn thing, you're increasing the amount of time per job, so you can take less jobs. Portable compressors are always handy. If they don't have one, they should get one. They are cheap and will make things like cleaning MF pads A LOT easier. But yes, this is a niche solution for those that like to flex with their tools.
  19. Feb 17, 2021 at 3:14 PM
    sterlingone
    sterlingone New Member
    Found these guys on EBay... https://www.ebay.com/str/cascadekegz still need the power washer after a mud run, but use less than a gallon of water using a rinseless wash solution to keep the rig road shiny... a lot less than the other listing and comes in several sizes
    robz and War Machine[OP] like this.
  20. Feb 6, 2022 at 5:07 PM
    sterlingone
    After using these guys on ebay, they started their own web site where they lowered their prices and include shipping! The 1.5 gallon pro kit that I carry to clean up after a road trip is awesome and makes it easy to keep up appearances. Check them out at www.cascadekegz.com
  21. Feb 6, 2022 at 5:10 PM
    sterlingone
