Fuse
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Hinos, Sep 16, 2019.
  1. Sep 16, 2019 at 3:33 PM
    Hinos
    Hinos [OP] New Member
    Hinos
    Toyota tundra
    V8
    Questions about fuse
  2. Sep 16, 2019 at 3:38 PM
    What's the issue?
    Hinos[OP] and saybng like this.
  3. Sep 16, 2019 at 3:38 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I dont know..and welcome from Ventura California
    Hinos[OP] and TXRailRoadBandit73 like this.
  4. Sep 16, 2019 at 3:56 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  5. Sep 16, 2019 at 5:33 PM
    Yes, Dr Seuss does have a short fuse.
    NewImprovedRon likes this.
  6. Sep 16, 2019 at 5:43 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Or a .22 shell or bullet.....
    Hinos[OP] and NewImprovedRon like this.
  7. Sep 16, 2019 at 8:31 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    Put in a wrong battery, burned like 3 fuses. Started up the truck& it runs great, bt den, ac/window& Cant put it drive or reverse I'm very exhausted. I luv dis baby very much. Pls & thank u.
  8. Sep 16, 2019 at 8:44 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Putting in a different group size battery wouldn't damage anything. Are you saying that you reversed the polarities or shorted something?
    Hinos[OP] likes this.
  9. Sep 16, 2019 at 8:47 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    Same size. But didn't realize it was wrong. Positive went to negative & negative went to positive
  10. Sep 16, 2019 at 8:47 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Year make model always helps
    I’m sure that’s theirs an override pin of the gear shift lock out somewhere around the gear shift but it has to have some more burnt out fuses or fusible links somewhere keep looking and when In doubt follow the - of the battery to a chassis or engine ground and + goes to alternator and starter it will make life easier in the future. Installing wrong size battery will not blow fuses installing the polarities wrong will.
    Trooper2 and Hinos[OP] like this.
  11. Sep 16, 2019 at 8:51 PM
    computeruser6
    Dirk
    Escondido
    With what you described there are probably many fuses blown, but it seems like at least the big 180A fuse didn't blow. Do you have a multimeter?
  12. Sep 16, 2019 at 8:52 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    2015 tundra.
    TXMiamiFan likes this.
  13. Sep 16, 2019 at 8:58 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    Yes the battery I bought came the reverse positive and negative didn't realise it till I connect it.
  14. Sep 16, 2019 at 8:59 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    I have a 19 at home wen I get home from work in 40 min I can post some pics of what to look for in the fuse box
  15. Sep 16, 2019 at 9:01 PM
    computeruser6
    Dirk
    Escondido
    Some of the differences between Battery Council International group sizes aren't size differences but rather just terminal locations/orientation. I would disconnect the battery, get a cheap multimeter at the nearest hardware/auto parts store, and start checking all of the fuses.
    Hinos[QUOTED][OP] likes this.
  16. Sep 16, 2019 at 9:04 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    Yes pls thank u.. appreciated
  17. Sep 16, 2019 at 9:06 PM
  18. Sep 16, 2019 at 9:53 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    That one that is circled is the fuse for your shift lock solenoid it’s in the cab under dash a 7.5amp check that but you should be checking all fuses
  19. Sep 16, 2019 at 9:54 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    I bought da same size battery. It was a reverse on my end wen I hook da cables.
    Blown 3fuses. Change battery & fuses. Truck started, gas it, bt no ac/power window& couldn't drive nor reverse.
  20. Sep 16, 2019 at 9:59 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    That one circled not the green orange and 3 greens sorry fat fingers is your 180amp main fuse that one is one piece main fuse bit of a pain to change have to remove battery and fuse box theirs a video on YouTube hopefully that doesn’t have a blown fuse link inside it’s like 6 integrated fuses in their
  21. Sep 16, 2019 at 10:00 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    I will look into it
  22. Sep 16, 2019 at 10:01 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    Wow.. never seen it would b.but I check it as well.
  23. Sep 16, 2019 at 10:06 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    You see that red circle theirs a little cap their if you pop that out and stick a long key or a small screwdriver in their you can shift your car out of park that will override the brake lockout solenoid but you should inspect all your lights and make sure they all work cause you might have several blown fuses
  24. Sep 16, 2019 at 10:08 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Hope this help keep us posted Good luck
  25. Sep 16, 2019 at 10:14 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    Yes will keep u posted. I really appreciate ur effort. I'm jst tryng to fix pit by pit.
    Black Wolf likes this.
  26. Sep 17, 2019 at 7:10 AM
    With those lights out, it’s not going to shift from park unless u over-ride it like in the above pic. Check those fuses inside the cabin too
  27. Sep 17, 2019 at 7:15 AM
    Hinos
    Hinos
    Toyota tundra
    V8
    All da lights wrk.. even da engine runs great
  28. Sep 17, 2019 at 7:18 AM
    Aurora CO
  29. Sep 17, 2019 at 9:21 PM
    computeruser6
    Dirk
    Escondido
    How did it go OP?
  30. Sep 18, 2019 at 3:30 PM
    Hinos
    Hinos
    Toyota tundra
    V8
    I'm stuck.. it seems like.. da entire fuse cannot b pull apart.da 1 in da pic. Is da 1 I gotta take out.
