LSD was working
Discussion in '1st Gen Tundras (2000-2006)' started by MS22, Sep 11, 2019.
  1. Sep 11, 2019 at 5:31 PM
    MS22
    MS22 [OP] New Member
    02 Tundra 4x4
    I changed my rear diff fluid about a week or so ago with some lucas oil, after that my chatter stopped when turning a corner all was good. I did power brake it on dry pavement a couple times nothing to harsh just to check the LSD and it left 2 scratch marks. A few times I put 1 wheel on gravel and the other on pavement and gunned it, the tire on the gravel spun a little then I could hear my drivers side start hooking up on the pavement. All was good. Went and did some work in the mountains, was going up our driveway and this happened. It is very sandy soft dirt so I dont know if that has to do with it. I didn't add extra additive. Maybe LSD is just getting old she does have 213,XXX miles .20190911_153358.jpg
  2. Sep 11, 2019 at 5:54 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I can remember wayyyy back in my college days when that was true also....about LSD that is :facepalm:
  3. Sep 11, 2019 at 6:00 PM
    gosolo
    Ray
    NW Oregon
    A good trip can go for 20 hours....
  4. Sep 11, 2019 at 6:26 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    MS22[OP] and Darkness like this.
  5. Sep 11, 2019 at 6:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    200k plus miles I wouldn’t feel like she wore out early! Throw in a true trac and youll be set!
    MS22[OP], Darkness and 02goes like this.
  6. Sep 11, 2019 at 8:58 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's a lot of miles. LSD will only do so much, you can still get stuck that way.
    MS22[OP] and 15whtrd like this.
  7. Sep 11, 2019 at 9:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The fact that one side just stood still means the clutch packs are toast
    02goes and MS22[OP] like this.
  8. Sep 11, 2019 at 9:19 PM
    coyote
    coyote New Member
    Holler at me if you need a replacement lsd I’m in Colorado and have one from an 05
  9. Sep 11, 2019 at 9:32 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    surprisingly mine at 193k seems to be strong still. but, we shall see if it keeps working.
    MS22[OP] likes this.
  10. Sep 11, 2019 at 10:47 PM
    15whtrd
    15whtrd Mr. Blonde
    Not necessarily. He’s got that left side rear tire stuffed pretty hard. Clutches will only hold so much. It will never act like a true locker. But at his mileage that very well could’ve finished it off. I had a truck with an LSD that would lay 11s all day long, but if I stuffed one of the wheels pretty hard, it would act like an open diff. The posi still stayed pretty tight and would still spin two wheels on asphalt.
  11. Sep 12, 2019 at 12:57 AM
    02goes
    02goes New Member
    I've fried some LSD clutches unsuspectingly fast on other vehicles. TrueTrac for this ride to me should be all that's needed w/o future expense. From what I hear from TrueTrac sellers is it's a quality precise drop in replacement usually w/o needing shim adjustment.
  12. Sep 12, 2019 at 6:47 AM
    speedtre
    speedtre New Member
    Inland Northwest
    This...I think the factory LSD is only pre-tensioned 200 ft/lbs torque..it will only do so much. The TRD Kazuma is pre-tensioned 400 ft/lbs....but good luck finding one of those.
    http://www.proactivate.com/tundra/lsd.html
    To OP, you could try cleaning it out like is talked about in this thread to see if it helps...
    https://forum.ih8mud.com/threads/lsd-replace-or-rebuild-what-are-my-options.554702/
  13. Sep 12, 2019 at 7:40 AM
    MS22
    02 Tundra 4x4
    Thank you much but I just bought a new set of shoes for her and dont have the xtra funds right now plus with Christmas coming up. Speedtre posted a link about cleaning it so Ill try that. If it doesn't work Ill just have an open diff was fun though when it was working. I think this is the way to reply to someones post Im still new at this.
  14. Sep 12, 2019 at 7:47 AM
    MS22
    02 Tundra 4x4
    Thanks I am going to try that out. Just had me confused as why the limited slip would work on pavement 2 scratch marks, the one wheel on gravel/grass and the other on pavement and worked awesome. In the dirt it was useless.
    speedtre[QUOTED] likes this.
  15. Sep 12, 2019 at 7:48 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
  16. Sep 12, 2019 at 7:55 AM
    15whtrd
    15whtrd Mr. Blonde
    I think the keywords here are “limited slip differential”. I really think that says it all. It’s not a non-slip differential LOL. I think your differential was doing exactly what it was designed to do. Limited slip allows the inside tire around a turn to move slower than the outside tire. This gives you basically a tame version of a locking differential. A locker will almost always bark the inside tire around a corner. A limited slip will allow them to spin at different speeds until you step on it a little bit. The only thing that locks them together are the clutches.
    Elevatorguy, Darkness and MS22[OP] like this.
  17. Sep 12, 2019 at 8:34 AM
    coyote
    coyote New Member
    @MS22 No problem -- just thought I'd throw it out the before listing in the classifieds :) Good luck!
    MS22[OP] and gosolo like this.
  18. Sep 14, 2019 at 5:35 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    It would work on pavement because the two tires were pushing against the same ground. The gravel and asphalt experiment would be similar because half the rear weight was still on the tire in the pavement. When you stuff a tire and unload another that's a big difference in force pushing that tire against the ground.
    The lsd that I've had worked like this too and sometimes using the e brake to load the unweighted tire helps.
    Are our factory lsd clutch style? Can you buy the clutches to rebuild them?
    speedtre and 15whtrd like this.
  19. Sep 14, 2019 at 8:20 AM
    15whtrd
    15whtrd Mr. Blonde
    Also two footing the gas and brake can help get the spinning tire to slow and transfer power to the stuck tire.
  20. Sep 14, 2019 at 9:47 AM
    MS22
    02 Tundra 4x4
    There is a website someone posted here where you type in your vin# and it will tell you all about your truck for free:) Mine stated that it had the factory Limited slip.Not sure about the rebuilding part. Once I get some time Im going to try that cleaning proccess that speedtre mentioned above.
    speedtre likes this.
  21. Sep 19, 2023 at 11:01 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Coming back to this post... I will eventually install a Detroit Truetrac. I had one on my Tacoma and it great in all conditions
    The Black Mamba and Elevatorguy like this.
  22. Sep 22, 2023 at 3:10 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    What is an average install cost of a truetrac?
  23. Sep 22, 2023 at 5:03 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    22 Acura tlx type S. 05 DC, 4.7, 4wd. 04 Highlander limited.
    Never messed with having a yota setup done but I’ve had a few other vehicles re geared and diffs changed. With me supplying at the parts and bearings etc, installs were about 6-800 in labor for a single diff (rwd). If you’re not re gearing front and rear, just swapping a rear diff I’d imagine it would be in that ballpark. Gears and diffs are not cheap and it’s x2 if you’re 4wd.
    RJVA[QUOTED] likes this.
  24. Sep 22, 2023 at 5:08 PM
    dirtnsmores
    Southern CA
    if you use East Coast Gear Supply it ran me about $1400 for new gears and truetrac, a local installer charged $350 to drop in the whole unit.
    The Black Mamba and RJVA like this.
  25. Sep 23, 2023 at 4:41 AM
    Elevatorguy
    You paid 350 for gear installation front and rear?
  26. Sep 23, 2023 at 7:07 AM
    dirtnsmores
    Southern CA
    My bad it was rear only. My Tacoma was 2wd
  27. Sep 23, 2023 at 3:58 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    Okay, I'm getting quoted 1500 just for labor. I'm being told the whole rear axle would be rebuilt to do the install right. Currently my truck has 190k and the rear-end seems totally fine but its a "while they're in there" kind of quote. I'll look into some other shops and see what they say.
