2002 Tundra LSD gear oil
Discussion in '1st Gen Tundras (2000-2006)' started by MS22, Sep 5, 2019.
  1. Sep 5, 2019 at 10:51 AM
    MS22
    MS22 [OP] New Member
    02 Tundra 4x4
    Hello all! Im going to be changing my rear diff fluid, from looking around it seems that the lucas 80w 90 heavy duty gear oil and 4oz of Trans X limited slip is an ok way to go. Just wondering if anyone else used these or should I consider something different? Also would 4oz be enough additive? I read where some people used 8oz.
    Thanks much
  2. Sep 5, 2019 at 11:03 AM
    FirstGenVol Brake Czar
    2002 AC
    The Lucas says on the label that no additive is required. I didn't use any but it can't hurt. 4oz should be more than enough.
  3. Sep 5, 2019 at 11:27 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I use lucas and no additives, working fine for years
    revtune likes this.
  4. Sep 5, 2019 at 11:45 AM
    2002 AC
    Wow, that was weird. I just went to respond to a post from @MS22 and got some error message. Your last post is gone.
    But double check the bottle. Google search is showing mixed results. Maybe the changed the label? I'm curious to know what you find.
  5. Sep 5, 2019 at 11:47 AM
    MS22
    02 Tundra 4x4
    Thanks I didnt see that. Maybe Ill try it without and see how it goes. I heard that too much additive makes the LSD ineffective:notsure:
  6. Sep 5, 2019 at 11:49 AM
    MS22
    02 Tundra 4x4
    I think that was my fault I'm new at this and was trying to figure out how to reply back
  7. Sep 5, 2019 at 11:53 AM
    2002 AC
    no worries. You figured out the :notsure: shrug so that's good. And I'm not sure about using too much additive. I can't give feedback on that.
    I would just follow the instructions on the bottle and you should be fine.
  8. Sep 9, 2019 at 11:27 AM
    coyote
    coyote New Member
    Lucas here too -- at my local napa it was the cheaper option with the additive, no chattery clutches or anything so far....
  9. Sep 11, 2019 at 7:30 AM
    MS22
    02 Tundra 4x4
    So I changed out the oil with the lucas and the chatter when going around corners is gone! Before my LSD barely worked but now it works awesome:fingerscrossed::)
  10. Oct 18, 2019 at 2:56 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Good on ya MS22. The 80w-90 Lucas is a nice (and inexpensive) gear oil that hits as close to the 90w spec’d in our manuals. Just saw mine with 10k miles after doing a new wheel bearing and the oil looks brand new.
  11. Oct 18, 2019 at 5:13 PM
    MS22
    02 Tundra 4x4
    Over 1000 miles later and no more chatter but my limited slip is still only acting well limited lol. Sometimes it works sometimes it doesn't. Speedtre
    put up a link showing how to clean off the clutches hopefully that will work. Hope all went well with you and the wheel bearing
  12. Oct 18, 2019 at 7:22 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Mobil says no additive either. That’s what I run.
  13. Oct 18, 2019 at 7:58 PM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    I liked the royal purple in mine, no chatter and no additive. It also didnt smell nearly as bad when I replaced it 3 years later.
