Towing new boat
Discussion in 'Towing & Hauling' started by FISHLIPWASHINTON, May 24, 2018.
  1. May 24, 2018 at 7:19 PM
    FISHLIPWASHINTON
    FISHLIPWASHINTON [OP] New Member
    2007 CM
    2007 CM 4X4 ALPINE EQ BACKUP LIGHTS LED JL 1000/1MONO BLOCK. 2 10IN JL 450/4 MIDS & HIGHS FOX COILOVERS & BILSTEIN REARS DEZ'S SABM MAGNAFLOW 7031 PROCOMP 35x12.50x18 AMG Battery BUSHWACKER PAINTED FENDER FLARES
    Check at shop mine dosnt
  2. May 24, 2018 at 7:22 PM
    koditten
    koditten New Member
    You broke the wheel/ tire down? The valve stems look similar. Regardless, the batteries are only good for 10 or so years.
  3. May 24, 2018 at 7:26 PM
    koditten
    koditten New Member
    I'm just curious, I deleted my sensors years ago. I "dummied" the ECU with a resistor to fool the computer that the tires were fine. My truck has no idea that I don't even have sensors in the tires.
    I figure if I'm spending a grand for rubber, I feel better checking the tires the old fashioned way.
    Bigboitundra and Prostar 190 like this.
  4. May 25, 2018 at 6:11 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Many vehicles on the road have Indirect TPMS, this works in conjunction with the ABS system to measure differences in wheel speed. There are plenty of Toyotas that have this system as well.
    The Tundras have Direct TPMS, measure pressure directly. I did not know this until last night after researching, since every other vehicle I have owned had Indirect TPMS that does work in conjunction with the ABS system.
    https://www.bridgestonetire.com/tre...ire-pressure-monitoring-system-how-tpms-works
  5. May 25, 2018 at 8:24 AM
    koditten
    koditten New Member
    This is not a good article.
    I can't think of any vehicles that have indirect tire pressure monitoring.
    As for the safety aspect, that is pure governmental propaganda.
    The TPMS is used so manufacturers can maintain their corporate MPG numbers.
    I'm sure others will argue that it is a safety feature 1st, but it will take a lot to convince me.
  6. May 25, 2018 at 8:59 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Rgnr 188 beat me to it
  7. May 25, 2018 at 10:52 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Indirect TPMS is more common than you think, Subaru for one used it a lot.
    And since TPMS originated in response the whole Ford Exploder / Firestone tire rollover mess, I can’t agree it’s all about mileage.
    I will agree that a good old gauge beats TPMS any day.
    And I like your theory about RF interferance.
    If the problem persists without any electronic devices on the boat being powered, then I would suggest OP connect the boat trailer to the truck, drive it until the light comes on, and take it to have the code read while active, and the light is still on.
    Also curious if the TPMS light flashes, or comes on steady?
  8. May 25, 2018 at 11:49 AM
    FISHLIPWASHINTON
    2007 CM
    Light flashes at first then stays on
    Put boat away drive 5 min or less and turns off
  9. May 25, 2018 at 9:30 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Flashing at first does indicate a system fault, not a low pressure issue.
    So what about the radio interference idea? Anything electronic on the boat that stays powered up?
  10. May 25, 2018 at 9:35 PM
    No pics of boat? :notsure:
    Bigboitundra and koditten like this.
  11. May 26, 2018 at 5:46 AM
    FISHLIPWASHINTON
    2007 CM
  12. May 26, 2018 at 5:56 AM
    Nice boat!
    Bigboitundra likes this.
  13. May 26, 2018 at 5:57 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Nice boat! Wireless steering on that trolling motor?
  14. May 26, 2018 at 8:26 AM
    FISHLIPWASHINTON
    2007 CM
    No wireless on trolling just a bullet proff fortrex. Cant afford new ULTREX
  15. Jun 13, 2018 at 1:55 PM
    FISHLIPWASHINTON
    2007 CM
    Well TMPS light came on again took it to the shop they had relearn the computer and all should be good now
    Dont know why reprogram computer but hope it works
  16. Mar 9, 2019 at 7:27 AM
    FISHLIPWASHINTON
    2007 CM
    Well just replaced all sensors and light came on again while towing boat
    I have a electric break controller fyi
    I plugged in a tool to check the all wired up correct checks out fine
    Any suggestions
    Thanks
  17. Mar 10, 2019 at 7:58 PM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    You can't afford not to have an Ultrex..It will change the way you fish..I'm a long time BBC member and you might make a quick post with your issue...Just to be frank. Your boat has ZERO to do with your truck tire pressure issue . In fact i have never heard of this problem before. I pull my Skeeter ZX200 once or twice a week year round and never an issue..
  18. Mar 11, 2019 at 7:46 AM
    FISHLIPWASHINTON
    2007 CM
    Never had a problem towing old boat
    Im lost just the idiot light on dash something to piss u off
  19. Sep 7, 2019 at 9:37 AM
    FISHLIPWASHINTON
    2007 CM
    Do you think I should change 7 plug receptacle?, it shouldn’t matter but light only goes on when i tow boat then have to take back to les schwab to havw them turn of fix
  20. Sep 30, 2019 at 6:21 PM
    #50
    Rubberdown
    Rubberdown Spilling my guts here.
    Not at all correct. Only measure tire pressure. Has nothing to do with wheel speed.
    Your trailer will not affect your TPMS feedback. Something is wrong on your truck end. Don’t know what it is but it’s something with your truck.
