Cellphone holders
Discussion in 'General Tundra Discussion' started by Beardedbeast, Dec 1, 2016.
  1. Dec 1, 2016 at 3:43 AM
    Beardedbeast
    Beardedbeast [OP] New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    so what is everybody's recommendations for a cellphone holder in your truck,I'm finally fed up with my phone sliding around,truck is a 13 cm.
  2. Dec 1, 2016 at 6:24 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I've looked and looked and just can't find anything I like...
    I always just keep my phone on top of my wallet in that little cubby below the 4x4 knob.
    I hope you find something that works well.
  3. Dec 1, 2016 at 7:01 AM
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Unfortunately my iPhone 6plus with case won't fit so I'm still searching
  4. Dec 1, 2016 at 7:08 AM
    BigBob
    BigBob New Member
    DFW, TX
    2016 Silver Tundra SR5 4x4 TRD
  5. Dec 1, 2016 at 7:10 AM
    CaptTyler
    Tyler
    Must be the case, my iPhone 7+ fits fine.
  6. Dec 1, 2016 at 7:31 AM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    Mob Armor all the way when it comes to phone mounts,
    They run two different sizes for their "Mob Mount". Your phone kind of locks into it. Its a magnetic base that essentially mounts anywhere. It allows you to put a cord or AUX cable in while its in the mount. This is more the phone case you want when you are offroading.
    The other more daily driver friendly mount is the Mobnetic Pro. I put the magnetic sticker inside my phone case so its a little more hidden. I will throw up some pictures for you guys.
  7. Dec 1, 2016 at 7:38 AM
    CaptTyler
    Tyler
    Looks very solid. Where did you mount yours?
  8. Dec 1, 2016 at 7:43 AM
    sdhq_offroad
    GILBERT, AZ
    First 3 are the Mob Mount, last 3 are the Mobnetic Pro
  9. Dec 1, 2016 at 7:54 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Not a fan of all those bulky mounts. I ended up with this one from Scosche. It's just a magnet that has super sticky 3M adhesive on the back. You stick it wherever you want to mount it (I put mine to the left of the radio) and then put the flat magnet on the back of your phone or phone case. Magnet is super strong. One of my favorite mods so far and it was only like $12. They have a few different variations, but this one is called the "surface mount".
    AxelsHumanDad likes this.
  10. Dec 1, 2016 at 8:00 AM
    sdhq_offroad
    GILBERT, AZ
    First picture is in a employees Tahoe. My truck is over getting detailed and I don't have any pictures. I mounted it right in that open spot between the coin holder/AC knob right below the vent, posted a picture of where.
    The reason I like these mounts so much is because you get 70 degrees of tilt, so if you want to use you phone as a GPS and such, you can. I never cared for the flat mounts.
  11. Dec 1, 2016 at 8:03 AM
  12. Dec 1, 2016 at 10:47 AM
    AxelsHumanDad
    AxelsHumanDad I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Same exact device I've switched to. I have a base mount in my work van too.
  13. Dec 1, 2016 at 11:12 AM
    TheBeast
    TheBeast The Beach
    I use one of those Amazon strong magnets
