Squeaking help/ tips needed (UPDATE)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fish2eat88, Aug 26, 2019.
  1. Aug 26, 2019 at 1:35 PM
    Fish2eat88
    Fish2eat88 [OP] New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    https://youtu.be/bcSjm06XZzw
    Any tips on tracking this down or anyone had similar squeaks? Im just lightly pushing the truck up and down.
  2. Aug 26, 2019 at 2:07 PM
    white_shadowww
    white_shadowww New Member
    Pete
    2016 Tundra Crewmax 4.6L SR5
    Fox 2.5 Coilovers / Maxtrac 3.5" Spindles / Total Chaos UCAs / Rear Fox 2.0 Shocks / Maxtrac 2" Lift Blocks / Method NV 18x9 / Toyo Open Country AT2 35x12.5r18
    mine sounds similar, pretty sure its coming from the poly bushings on my total chaos UCAs..i grease them often but i figured its just something id have to live with.
    im not 100% sure though so im curious to what others might have to say
  3. Aug 26, 2019 at 2:16 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    To bad i have stock uca lol. I wonder if they could be to tight?
  4. Aug 26, 2019 at 2:22 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    What all after market suspension bits do you have?
  5. Aug 26, 2019 at 2:25 PM
    white_shadowww
    Pete
    yea maybe, i've read somewhere too that if something isnt torqued to the correct ft lbs it can cause squeaking
  6. Aug 26, 2019 at 2:31 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    Just the eibach 3” lift coilovers. Needed to adjust the coilover to gain the true 3”. Havent heard anything from toytec about the new coil for a while
  7. Aug 26, 2019 at 2:33 PM
    TheBeast
    TheBeast The Beach
    last time I heard that noise was at a cheap motel 6....
    Tundra_361, gosolo and Getmeacoors like this.
  8. Aug 26, 2019 at 2:57 PM
    SoCalTundy
    SoCalTundy Member since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    I had a similiar issue. The bottom shock mount bushing was the problem. You can either spray it with lube or replace the bushings. I don't know if your aftermarket shocks are serviceable. OEM shocks are not and have to be replaced.
  9. Aug 26, 2019 at 3:23 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    Ill try spray some kind of lube there see if it makes a difference
  10. Aug 26, 2019 at 3:30 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    Sucks they are not that old, maybe 1,500 miles on it max.
  11. Aug 26, 2019 at 4:33 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Mine squeak as well. I haven’t been able to find what it is.
    But I’ll definitely try the bottom shock mount.
  12. Aug 26, 2019 at 4:35 PM
    bdpeelgren
    Round Rock, TX
    I cringe whenever I’m in a parking lot or something and there’s people around and it starts squeaking.
    white_shadowww likes this.
  13. Aug 26, 2019 at 4:44 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Don’t go spraying everything at once. Only spray one component at a time so you can track down the source.
    15whtrd likes this.
  14. Aug 26, 2019 at 5:02 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    Mine squeaks. I looked and I guess I left off one of the leaf spring plastic buttons. Anyone have one they'd throw in an envelope?
  15. Aug 27, 2019 at 1:20 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    Played around today. And notice something off. FEA63210-85BC-4227-BF8C-FA9CF4CF1813.jpgFE5C76A4-AD76-4037-A2AB-6D7F0110BD29.jpg
    First thumbnail is driver which shows a lot of thread. 2nd is passenger. So after jacking the truck up, these washers in the pics, 4E27C78F-C06D-4F1C-A5B2-CB09451D23F8.jpg8D5D81C2-F1F3-433E-B106-4B78C7E7EEBF.jpg I touched one and they had about 1/8” of play and the driver side one was still perfectly tight. So I dropped the truck and both washers are sit properly but when the suspension cycles it compresses and allows the passenger side washer to move. So i put some grease and it WORKED!!!
    So my other question, how do I torque that nut down so the washer is tight on the inner bushing? Do I need to take the shocks off? Take off the preload from the spring?? Any help be appreciated
  16. Aug 27, 2019 at 2:05 PM
    Jengel451
    The Bitterroot, MT
    Two wrenches. Open end on the top of the shaft and box end on the nut.
    15whtrd and Fish2eat88[OP] like this.
  17. Aug 27, 2019 at 2:06 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    Do I need to jack the tires off the ground? I have a spring compressor to relieve some tension
  18. Aug 27, 2019 at 2:36 PM
    Jengel451
    The Bitterroot, MT
    nah, just go for it. that won't have much of any tension on it, it's all on the spring and the 4 nuts/studs around that shock shaft.
  19. Sep 5, 2019 at 6:11 PM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    Not sure if this would apply to a Tundra but on my 14 Raptor I had to rebuild the front Fox shocks and after they were reinstalled I had a squeaking noise, after some research I found that this was common problem if the bottom bolt was not torqued to the correct 600 ftlbs. If not torqued to that it left a tiny gap that allowed the poly bushing to move side to side causing the squeak. I got it torqued properly and the squeak went away.
  20. Sep 5, 2019 at 11:40 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    Works like a charm. While the truck was down it was actually easier hahaha
    Jengel451[QUOTED] likes this.
  21. Sep 6, 2019 at 6:43 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    600 ft lbs?!?
    Tundradrenalin likes this.
  22. Sep 6, 2019 at 7:23 PM
    No Limit
    No Limit New Member
    Alberta
    Correction just looked it up 406 ftlbs 550 nm...my memory is not as good as it used to be it’s been 3 years since I got it retorqued
