The Cream Pie - A 2005 4wd/LS/5-Speed/SAS Conversion
Discussion in '1st Gen Builds (2000-2006)' started by the_white_shadow, Aug 8, 2019.
  1. Aug 8, 2019 at 5:55 AM
    the_white_shadow
    the_white_shadow [OP] New Member
    So I figured id start a thread to track and archive my progress on my new to me 2005 Tundra Sr5 Access cab. The truck is a 175k mile 4.0L Auto 2wd cream puff and that will soon very change. My goal is to make a streetable rig that i can use as a reserve crawler.
    Build plan:
    LS 6.0l with some goodies
    5-speed NV4500
    NP271 manual shift T-case
    05+ Super Duty front axle with 1550 joints, some type of mechanical locker, 4.88 gears
    Late model 14B rear with disc brakes and a detroit
    3-link front with Accutune tuned 2.5" coilovers and bump stops
    Mechanical steering using mini-truck IFS box with hydro assist
    leaf sprung rear - 94 F150 rear 57" leafs; Cantilever Fox 2.5" smoothie shocks
    40" Toyo MTs on ATX Chamber II Beadlocks
    Bumpers & Sliders (I really like the Brute Force front bumper)
    Going to get Trail Toys to make me a rear high clearance rear bumper
    Debadge, black mirrors
    Thinking some version of the Iron Man Ivan Stewart stripe package to get rid of some of the white
    Camper shell for them cross country overlanding trips
    Profit
    So here is the cherry '05 that i picked up last weekend. It has a "misfire" that the previous owner was trying to fix and gave up on. So far i found the new injectors he installed to be missing a few o-rings. It does run now, but leaks gas instantly on startup due to two injectors not having o-rings on the bottom.
    IsMnMuSEqYIDM0atQmCT6OuL3Vej_Tg3EPwNcgGQ_fa47b94ff519d735d23848e2eb850435ab3a2803.jpg
    o0BLX39CWzZugNfEoTtFZ7HsYFNgPlM3Ls4QLevO_31d49296501b196e3641c938e66c7fc6fb8c2815.jpg
    So far, i have removed the steps, the mud flaps, the fender trim, the chrome headache rack, and the bug deflector. Badges are next. Ive read that the large side molding has holes behind it, so i will just paint the chrome strip black and leave them on.
    The stock 4.0. The PO installed lots of new parts to fix the misfire. New sensors, throttle body, plugs, coils, plug wires, injectors, fuel pump, fuel filter, radiator, etc. I will get it running and then yank it out.
    K5_vkip857npfer_BBP49ERJZiW9BLWrV1NMRK8v_b38c1876ccf00ce9aaef5691d0847f7a707dabaa.jpg
    The LS donor truck. Its a 2005 with 148k on it. 6.0l/NV4500 5-speed/NP271 truck that runs great.
    here she is parked next to my first gen taco.
    HdlXJcfCw6OtWVDgJZGqVICFnAE1sSqsQTraLach_21cd9e09d017e62df8518f770ff8082809033267.jpg
    40" Toyo MTs
    8QY30d8llKeq4yNY3IrcNYTtaypRU7CWL3Jdv0OC_66d318e4ec45048cf492527fb5e71e3e31b2a6f4.jpg
    qNzQbYtY-Iv-Yo1qS6VUpZXnK41DGWPFMHL2hIYP_b297edb11d91c081b907b0520958fd1047531f6d.jpg
    The front axle. So far ive torched off the brackets. Still need to clean it up before the link mounts and truss can go on.
    GCvMfYbq8WTXluWlaWJs6kImhhkLgieEm5TyOxIm_a900392bf5f648e1d7888584a388d7089c5a2007.jpg
    Thats about it for now. I am waiting on a the injector o-rings to come in, then ill yank out the 4.0 and the 6.0 to start the swap. I want to get the engine in and running before i start the SAS. I will be cutting the frame off at the firewall and rebuilding it up and forward for more uptravel.
    Some of yall may recognize my crawling rig. Its a first gen truck body on a custom chassis i built. I also just finished up my first 40. Its been a lot of fun bringing it back from the dead.
    T_n5Zzb89-MAMPisopiuhk12q62ZOVW_fPXzQRO2_d3ef5fbf0bca9eb73ff95b0ba018efd99f7a8750.jpg
    qstm5_AS8garrNeHAIR0yo6odXYnZl6SaPFx8it4_ad01419df5d29bac5c876273e314b97025aa4817.jpg
    My 40
    GjfFoU1vJNi0hoVlWWvWV7XxavVNv7IbFcaklrCZ_3ec3468449107e2835061c352a997ff05585aab6.jpg
    I will update this as progress continues. Ill be in Hot Springs this weekend putting a beat down on the Squirrel with some friends.
  2. Aug 8, 2019 at 9:02 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
  3. Aug 8, 2019 at 9:08 AM
  4. Aug 8, 2019 at 10:59 AM
    FirstGenVol Brake Czar
    2002 AC
    I had no idea they offered these in the 4.0L. I only knew about the 3.4L. I can't imagine many were made with the 4.0L.
    HappyGilmore likes this.
  5. Aug 8, 2019 at 11:05 AM
    the_white_shadow
    Yeah in 05, the 4.0s came out.
  6. Aug 8, 2019 at 3:27 PM
    the_white_shadow
    That’s my plan. The oil looked clean. I’m pretty sure it has fuel in it now though since there were no o rings on the injectors. Going to drain it and see what happens.
    Watt maker likes this.
  7. Aug 8, 2019 at 4:51 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Watching patiently. If I keep my truck for any length of time I'm thinking more power is needed. Yeah an ls family swap probably isn't the most efficient if I'm keeping Toyota drivetrain, but they sure are fun engines that wake-up with minimal work/money
  8. Aug 12, 2019 at 6:31 PM
    the_white_shadow
    I installed the new o rings today on the injectors and no more fuel leaks. After an oil change and letting the white smoke clear out after a few minutes, I took it for a spin. Ran and drove great. Now to remove it.
  9. Aug 21, 2019 at 4:54 AM
    the_white_shadow
    the removal of the this nv4500/261 kicked my ass, but its out of the donor. It needs the bath. Engine removal to come soon.
    iS9BZGo4WHOE5bmYZpJETaYdvZL5AB9UZSAvbtaL_81b7895ca09170f1630db3e1760247c58133513a.jpg
  10. Aug 21, 2019 at 6:32 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Opened this thread with the eager anticipation of a 17yo...
    AggiePhil, P-Factor, Opus5150 and 3 others like this.
  11. Aug 21, 2019 at 6:46 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Right? Interesting thread title.
  12. Aug 21, 2019 at 6:55 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
  13. Aug 21, 2019 at 7:21 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Right on! I'm looking forward to seeing this project.
  14. Aug 21, 2019 at 8:26 AM
    Levy
    Levy New Member
    Levi
    Utah
    2000 Toyota Tundra
    SPC mid arm kit, bilstein 6112 leveled struts, in route to my house now are shorty headers, true dual flow master super 10s, and a cold air intake.
  15. Aug 21, 2019 at 8:31 AM
    Atomic City Tundra
    Devin
    New Mexico
    I agree. Looking to shape up into a true build thread.
  16. Aug 21, 2019 at 9:12 AM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Keep those pics rolling in.
  17. Aug 22, 2019 at 1:44 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
  18. Aug 22, 2019 at 2:02 PM
    4RunnerKid
    4RunnerKid New Member
    Oceano, CA
    '19 Cement CM SR5 4x4
    TRD Pro Bilsteins w/ single CB shim, 285/75-17 Falken AT3, Method 701, debadged, ceramic coated, Husky liners
    hell yeah. love the Dirt Squirrel, excited to see where this one goes
  19. Aug 22, 2019 at 2:28 PM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    Dude I'm so in on this thread:popcorn::burp:
  20. Aug 23, 2019 at 10:44 AM
    the_white_shadow
    Mmmmm 6.0l. Pulled it out yesterday and removed the wiring harness. I’ll send it to 150tunes to have Wayne thin it down into a stand-alone harness.
  21. Aug 23, 2019 at 11:49 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    What are your plans for gauges? Remove/Replace or will you be able to make the LS talk to the Toyota ECU?
  22. Aug 23, 2019 at 12:02 PM
    the_white_shadow
    Toyota Ecu will be gone. I’d like to get the Toyota gauges to work somehow. If not I’ll just use a tablet with the dash command app and a Bluetooth obd2 dongle. Maybe some auto meter digital gauges if I have to.
  23. Aug 23, 2019 at 12:07 PM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
  24. Aug 23, 2019 at 12:15 PM
    TXTundra2722
    2015 Black Tundra
    I came in here based off the name, looking for something else I guess
    :anonymous:
    Trust86 and (deleted member) like this.
  25. Aug 23, 2019 at 12:53 PM
    the_white_shadow
    Stay tuned. You’ll be creaming your tighty-whities in short order.
  26. Aug 23, 2019 at 3:44 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Man, Alex, wish I had the cash to buy the 4L running gear from you. Would make a great swap in my truck.
    because_wumbo-truck likes this.
  27. Aug 23, 2019 at 5:42 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    What truck would you be refuring to?
  28. Aug 23, 2019 at 7:18 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
  29. Aug 23, 2019 at 8:56 PM
    GravityGear
    Aurora, CO
    "The Cream Pie"... holy shit man... holy shit.
  30. Aug 24, 2019 at 3:10 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I've always wanted to see a first gen taco with a 4L swap
