2006 Tundra 4x4 Overland Adventure Build ("Barnabas")
Discussion in '1st Gen Builds (2000-2006)' started by mmccoy, Jun 24, 2019.
  1. Jun 24, 2019 at 7:07 AM
    mmccoy
    mmccoy [OP] New Member
    Mark
    06 Tundra DC TRD4x4
    Hi All,
    I just purchased a first gen Toyota Tundra 4x4 (2006). I'm hoping to slowly but surely set up an overland rig for adventuring. I plan to update this thread along the way. Feel free to shout out with any questions.
    Vehicle (at time of purchase):
    2006 Toyota Tundra 4x4 SR5 TRD Off Road
    109k mileage
    Towing Package; incl towing control brake
    Performance High Flow Muffler
    BFG K02 All-terrain
    2' Leveling Kit
    Thanks
  2. Jun 24, 2019 at 7:13 AM
    Aurora CO
    Welcome from Colorado.
    mmccoy[OP] likes this.
  3. Jun 24, 2019 at 7:50 AM
    BestGen
    BestGen Free Kyle!
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Welcome aboard fellow first genner! :cheers:
    mmccoy[OP] and CaptSpaulding like this.
  4. Jul 6, 2019 at 5:55 PM
    mmccoy
    Mark
    06 Tundra DC TRD4x4
    I decided to replace the old JVC CD player for an Alpine iLX-W650 and Jensen BUCAM200J rear view camera.
    My truck has OEM JBL system which still sounds ok to me (at least for now). I don't expect I'll swap out for a new set of speakers anytime soon but I did have to repair the current front speakers with a really basic kit I bought for $30 on amazon from simply speakers. The JBL front speaker foam tends to deteriorate after awhile.
    Completed install w/ rear view camera
    Location of the reverse power cable. This was a pain in the ass to find and to get info on where to find it so I figured I'd post.
    I wired the yellow&blue Alpine cable into the reverse power cable to make sure my camera comes on when I switch into reverse. To do this I had to remove the panel under the driver-side and remove the ventilation tube (not bolted in). Wire is tough to see but should be green and red.
    Speaker repair kit was easy to do and worked great.
    I thought the speakers were totally blown, but to my surprise after a little fix they sound brand new again.If your OEM JBLs start to sound scratchy it's probably the foam.
  5. Jul 8, 2019 at 4:36 PM
    mmccoy
    Mark
    06 Tundra DC TRD4x4
  6. Jul 9, 2019 at 5:25 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Nice! I have used that speaker kit in my wife's Sequoia and it definitely did the trick. Any reason you didn't just tap into the reverse light power in one of the tail lights?
  7. Jul 10, 2019 at 9:48 AM
    mmccoy
    Mark
    06 Tundra DC TRD4x4
    I had to open up the drivers side panel anyway to get to the ebrake wire for my Alpine system. Saved a little time by this way. But, you could definitly run it to the back and power into one of the tail lights.
  8. Jul 10, 2019 at 1:06 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I like how you tapped into it right there so it won't be easily corroded. I'll be honest I don't remember where I tapped into for the reverse wire. Probably at the tail light. Now I'm hoping I used heat shrink haha.
    mmccoy[QUOTED][OP] likes this.
  9. Jul 15, 2019 at 1:20 PM
    NMTundra
    NMTundra New Member
    I definitely tapped in at the reverse light. I'm sure I'll have to go back into eventually and redo it.
  10. Aug 22, 2019 at 1:59 PM
    bigrednuffsaid
    bigrednuffsaid New Member
    Truck looks good! What size KO2s are those? Which leveling kit? Thanks!
  11. Aug 25, 2019 at 3:49 PM
    mmccoy
    Mark
    06 Tundra DC TRD4x4
    Thanks!
    Let me double check on the leveling kit. I'm not sure I bought it like that.
    The tires are 265/70/r16
  12. Apr 12, 2021 at 12:47 PM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    You in Eugene by chance? I think I’ve been to that Trader Joe’s. Is that the one in the same square as the Mucho Gusto restaurant??
    Love your truck. Mine has the same rims, which I honestly didn’t use to like. Now I love them. I run a 285/75-r16. These trucks with those specific rims with oversize tires and a level are some of the best looking truck out there in my opinion. Sorta like the perfect stock enhanced look. We ride the dunes about four times a year. Love going to Florence/Winchester/reedsport.
