S&B CAI shifting issue?
Discussion in 'Performance and Tuning' started by Primalbryan, Aug 22, 2019.
  1. Aug 22, 2019 at 9:54 AM
    Primalbryan
    Primalbryan [OP] New Member
    2019 Limited Tundra Off-Road TRD- White
    TRD dual exhaust
    Despite everyone on the forum saying keep the stock CAI- I couldn’t help myself after seeing how nice the S&B looks along with their airflow claims, as well as being a true CAI using the same air path as the stock intake.
    Anyway- when I floor it my truck shifts about 1k rpms under redline now. Has anyone else experienced this from an aftermarket intake?
    It’s on a 2019 limited
  2. Aug 22, 2019 at 11:39 AM
    Primalbryan
    TRD dual exhaust
    I did unplug it for 30-40 minutes during the install. After putting some more drive time in it feels back to shifting normally. I will say though I absolutely do not feel any power gains on the butt dyno. Not worse but not better. After 6k I’ll probably go back to factory intake just for ease of maintenance. I was mostly excited about the sound but my trd exhaust seems to drown it out- can’t even tell it’s there.
    SIMPLYTHETRUTH and Rica25 like this.
  3. Aug 22, 2019 at 11:41 AM
    I have older version, nothing happening on my end, I see you have the side wall on, have you taken off?
    Rica25 and Primalbryan[OP] like this.
  4. Aug 22, 2019 at 11:46 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have the same one as you on my 2010, works great. Sorry you are having trouble.
    Primalbryan[OP] likes this.
  5. Aug 22, 2019 at 12:16 PM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I find that 1st gear usually shifts 1k rpm’s earlier compared to the other gears
  6. Aug 22, 2019 at 12:36 PM
    Primalbryan
    TRD dual exhaust
    You’re right! First gear definitely does that. I live in busy/shitty downtown Seattle so it was hard to accelerate past 40, but today was able to go fly around a bit. I’m going to take the side cover off just for fun later today and will let you know if it makes a difference.
  7. Aug 22, 2019 at 12:49 PM
    Primalbryan
    TRD dual exhaust
    @ARamirez73 @e30cabrio how often do you guys clean your filters and do you run with or without the cover?
    Rica25 likes this.
  8. Aug 22, 2019 at 12:51 PM
    Rica25
    Ricardo
    Tulare
    I removed my aftermarket as well after about 1 yr and did other mods instead i I'd the throttle body by pass and also the SABM home made instead of paying the 90 bucks also have the TRD air filter
  9. Aug 22, 2019 at 12:52 PM
    Me... I clean every oil change, but that's me, and I have an extra filter, that way I don't have to wait for it to dry
    I run it without that side wall
  10. Aug 22, 2019 at 12:53 PM
    I keep hearing about this throttle body bypass, what is this? please explain
  11. Aug 22, 2019 at 12:55 PM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Coolant line that go to the TB, the just bypass them so no coolant goes to TB. Takes about 15 minutes and 0$$$$$
  12. Aug 22, 2019 at 12:57 PM
    Rica25
    Ricardo
    Tulare
    That's correct
  13. Aug 22, 2019 at 12:57 PM
    Rica25
    Ricardo
    Tulare
    He answered
  14. Aug 22, 2019 at 12:58 PM
    I don't need anything to do?
    Rica25 likes this.
  15. Aug 22, 2019 at 1:17 PM
    Video or pics?
    Rica25 likes this.
  16. Aug 22, 2019 at 1:35 PM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    One thing I did differently is I got coolant bypass caps at autozone for the nipples on the throttle body. I don’t remember the hose cap size but a variety pack is like $5
    https://youtu.be/WkbosNDnAD0
    TXRailRoadBandit73 and Rica25 like this.
  17. Aug 22, 2019 at 3:01 PM
    Primalbryan
    TRD dual exhaust
    This is new info for me, what’s the benefit of the bypass?
    Rica25 and TXRailRoadBandit73 like this.
  18. Aug 22, 2019 at 3:14 PM
    e30cabrio
    I have done the bypass on other vehicles, not the Tundra.... yet. :D
    I have 3 filters, an oiled and two dry.
    Rica25 likes this.
  19. Aug 22, 2019 at 3:15 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
    Remove negative terminal and stomp on brake pedal a few times. Sends the rest of the juice to the brake lights and drains the system.
  20. Aug 22, 2019 at 3:28 PM
    Primalbryan
    TRD dual exhaust
    I did take that cover off and holy shit. Major butt dyno gains probably all due to the amazing sound. Love it now though I’m glad I bought it haha. @ARamirez73 great idea of having two filters to eliminate the 24 hr dry time. Definitely gonna leave the cover off and follow your lead on that one
  21. Aug 22, 2019 at 3:54 PM
    I just followed instructions, the extra filter was from an old YouTube video a guy cleaning a K&N and he said he didn't like waiting on dry time, so he bought one, I followed he's lead lol
  22. Aug 22, 2019 at 4:18 PM
    Just cleaned MAF sensor n TB now we on this subject
    Rica25 likes this.
  23. Aug 22, 2019 at 5:25 PM
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    FYI, pulling the side cover makes a huge difference in the sound of the intake. I got the dry filter for mine, not the washable one. I also have the TRD dual exhaust and it's still really tame, almost stock sounding with the cover on. Im happy with mine, once the weather turns cooler I'll pull the side cover off again.
    Primalbryan[OP] and Rica25 like this.
  24. Aug 23, 2019 at 1:11 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    I just swapped/cleaned my oiled S&B filter to the newer power stack filter, open side box, power commander on Sport+/2+, with TRD dual exhaust. The sound under the hood after 3000rpm, power commander holding gears longer till almost 4500 rpm, then hearing the TRD dual exhaust is like having “tow haul” x(10).....having two filters is a must just swap and drive, you can now take your time cleaning, drying & oiling for the next swap, which I do every 10k miles
