Interior LEDs...FAIL..
Discussion in 'Lighting' started by TheBeast, Oct 22, 2016.
  1. Nov 4, 2016 at 10:22 AM
    TheBeast
    TheBeast [OP] The Beach
    I ended up using VLEDS interior lights including the footwell LED strip (very cool btw). No issues to report. A bitch to put back the deflector shield though on the map lights
    ChucklesToy and SouthBoundSteve like this.
  2. Nov 7, 2016 at 3:23 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    I don't know how you got those to work, they wouldn't stay popped in on my vanity mirror clips because the LED ends are twice the size of the factory bulbs. Even when I held them in, I couldn't get the lens cover back on, it wouldn't go all the way on because of the LED thickness.
    I'm returning mine.
    The other interior bulbs I got from them are all installed and work great.
  3. Nov 7, 2016 at 9:36 PM
    Tundra Fan
    Toby
    Here's a comparison .....
  4. Nov 8, 2016 at 8:44 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Gotta be the wrong one
    NewImprovedRon likes this.
  5. Nov 8, 2016 at 7:13 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    I got a flat pliers and just kinked the ends a tad for the vanity lights to stay in place.
  6. Nov 8, 2016 at 9:17 PM
    Tundra Fan
    Toby
    I thought about doing that, but I was worried about breaking them. I ordered the ones from vleds, they should be here tomorrow.
    On another note, I ordered an extra 74 bulb for my glove box. I finally tore that thing apart today to get the bulb out, and it's some weird connector attached to the bulb that plugs into the connector. Guess I'm not changing that one out. :(
  7. Nov 14, 2016 at 10:15 AM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    That's crazy wrong. The vanity LEDs I got from VLEDs are exactly the same size/shape as the OEM bulbs, just with LED inside.
  8. Nov 15, 2016 at 1:09 PM
    Tundra Fan
    Toby
    Yea, I ordered those from VLED's after I returned the ones pictured. The new ones worked fine.
    ChucklesToy likes this.
  9. Dec 4, 2016 at 3:59 PM
    tommyhus
    tommyhus New Member
    Thomas
    2012 Tundra
  10. Mar 16, 2017 at 8:38 PM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I just went full retard For the second time on lights and have completely bent the prongs on both sides up front.
    Then took a screw driver to fix and not thinking blew a fuse!!!!
    My wife's laughing at me so hard
  11. Mar 16, 2017 at 9:02 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    lol that's not good.
  12. Mar 17, 2017 at 2:36 AM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    Found a video online. They wrapped packing tape around the map bulbs and just wiggled. Left the aluminum reflectors in.
    I followed this (took the 7.5a fuse out first) and haven't had any problems.
  13. Mar 17, 2017 at 3:32 PM
    ChucklesToy
    Chuck
    Round Rock, TX
    Very smart...remove fuse first, then use some tape...I saw a video from one of the LED suppliers where he used a plastic trim tool, so that is what I used. Sure wished I had pulled the fuse out first though. Didn't realize how the reflectors and bulbs' connector wiring was so close.
  14. Oct 24, 2017 at 7:08 AM
    Dougthebeast
    Dougthebeast GTF out of my way!
    Doug
    Newnan GA
    2008 Tundra TRD DC Sapphire Blue
  15. Oct 24, 2017 at 7:19 AM
    Dougthebeast
    Doug
    Newnan GA
    Any idea what bulb is for the bottom of the doors?. Not listed at superbrightleds.com
  16. Aug 21, 2019 at 4:19 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Do you still get good light spread without the reflectors in the front map lights?
    I had a tough time getting the halogen bulbs out with the reflectors in place. They more or less fell out in the process and now I can't seem to get them back in place. It looks like I'd have to take the entire outer tan trim piece off in order to get the reflector back in. I don't have the motivation to pull the entire thing just for those. I'm somewhat bummed but I'm hoping I still get light spread without the reflectors.
    Does anyone else have any experience with the reflectors being out?
    I got these bulbs off of Amazon for the dome and map lights. Everything is functioning properly.
  17. Aug 21, 2019 at 7:52 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Answered my own question. Plenty of light without the reflectors.
    No street lights.. doors are closed and the windows are tinted pretty good. Can’t complain about the light output.
    Mshkaki likes this.
