Looking for non jbl Entune with navigation
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by DPlatinum, Aug 15, 2019.
  1. Aug 15, 2019 at 9:43 PM
    DPlatinum
    DPlatinum [OP] New Member
    DFW
    2017 Quicksand SR5 Doublecab 4x4
    Undercover Flex bed cover, Pro grille,2018 led headlights, bed step, console safe, Toytec/Eibach 3” front leveling shocks OEM painted to match fender flares, tow mirrors
    Found one, Thanks all
  2. Aug 17, 2019 at 7:11 AM
    DPlatinum
    DFW
  3. Aug 18, 2019 at 3:56 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I bought one; tried hooking it up and wouldn’t respond to any commands. It powers on just fine but Touchscreen didn’t respond, microphone wasn’t detected and maps wouldn’t load. Not sure if I did something wrong (doubtful as there is only one way to install it), but I can’t use it. May just not be compatible with my model truck.
  4. Aug 18, 2019 at 4:32 PM
    Can you post a picture of it? It should work. Is the map card in the radio?
  5. Aug 18, 2019 at 4:37 PM
    shawn474
    MoCo, Maryland
    Pictures attached; yes map card is in the radio
  6. Aug 18, 2019 at 4:38 PM
    That should work. Is the map card in?
  7. Aug 18, 2019 at 4:42 PM
    shawn474
    MoCo, Maryland
    Yes it’s in; not sure why it isn’t working. I tried twice. The original radio and all functions work perfectly once I reinstalled the old one (microphone, touch screen, etc all work fine). So it is either an incompatible radio or something is damaged internally in the radio.
  8. Aug 18, 2019 at 5:04 PM
    Where did you get it from?
  9. Aug 18, 2019 at 5:07 PM
    shawn474
    MoCo, Maryland
    A member on the forum. Said it worked when he removed; have no reason to believe otherwise. I am going to see if I can troubleshoot later this week when I have time, but not looking good as I have tried it twice already. I am hopeful that is is something as simple as one of the plugs may have not been seated properly.
  10. Aug 18, 2019 at 5:18 PM
    Wonder if it was dropped during shipping?
    Good luck, hopefully it is something simple.
    I'm looking to do this also.
  11. Aug 24, 2019 at 2:13 PM
    jclem65
    jclem65 New Member
    james
    2019 cement tundra crewmax sr5 trd off road
    interior led's,fortin remote-start with i linker
    did you get this working?
  12. Aug 24, 2019 at 5:08 PM
    shawn474
    MoCo, Maryland
    No
  13. Aug 25, 2019 at 7:31 AM
    jclem65
    jclem65 New Member
    james
    ugh.........
  14. Aug 25, 2019 at 10:28 AM
    DireWolf
    DireWolf The Dark Lord - Tundra Owner
    North East Florida
    2016 Dark Gray Tundra SR5 (MGM)
    none
    Where or how is the map card installed?
  15. Aug 25, 2019 at 10:31 AM
    shawn474
    MoCo, Maryland
    Behind the map card button; the button flips down and it’s push style like an as card in a camera or phone
