Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. Jun 4, 2019 at 9:22 AM
    #511
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD Praux
    That could work. I'd like a solution that allows the use of the trailer hitch as well. Either for towing my trailer or mounting my bike rack.
  2. Jun 4, 2019 at 9:55 AM
    #512
    W Bill
    W Bill New Member
    I'm considering their Max Modular URTC rack which looks a little better. It's also more expensive.
  3. Jun 4, 2019 at 11:03 AM
    #513
    DZ_
    DZ_ New Member
    Frederick Co., MD
    That looks good, though I wonder about accessibility to the front half of the DB HD with a rack. Maybe a rack at the rear and on the cab would be better?
  4. Jun 4, 2019 at 11:38 AM
    #514
    rideandfly
    rideandfly New Member
  5. Jun 4, 2019 at 11:51 AM
    #515
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Yep. Saw that. LOL'ed when I got to the hacksaw part.
    What solutions are you looking at?
  6. Jun 4, 2019 at 12:50 PM
    #516
    rideandfly
    Knocking this idea around right now, subject to change, hope it makes sense.
    US Paddler Rack:
    Cut the vertical angle off of bottom of US Paddlers mounting base where it used to be a lip over the inside of the truck truck bed. Use neoprene gasket material as a cushion/spacer between the horizontal piece and Diamondback cover.
    Base with vertical angle:
    Use a shortened vertical square post with a square plate welded on to bolt directly to the Diamondback cover. The existing square tube on the rack will slide over the smaller square post on the Diamondback cover. This should make a quick disconnect system.
    Male vertical post on right to be shortened and have plate welded on base to be bolted to Diamondback cover. US Paddlers rack base on left with existing female square tube to be reinforced after cutting vertical angle off:
    https://www.usrack.com/instructions/paddlers_truck_rack_instructions.pdf
    Dilsky likes this.
  7. Jun 4, 2019 at 1:07 PM
    #517
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Yea I did up a drawing somewhere just can't find it. I would like it to sit on top of the cover so you can still open it without taking the rack off. I ordered 3 70" bars of this https://8020.net/1530-s-black.html and am going to make some bases that will bolt into the existing hole with the exception of adding holes in the center panel.
  8. Jun 4, 2019 at 1:09 PM
    #518
    rideandfly
    Yep, would prefer to open the cover without removing racks, but will only be able to open tailgate with my arrangement.
  9. Jun 8, 2019 at 5:27 AM
    #519
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Well, I called in and ordered an HD and the 8" storage bin on Thursday.
    I tried to talk them into color matching and giving is a forum discount. No success on either pursuit. Sorry fellas.
    Is my cover here yet???????
    Jack Burton likes this.
  10. Jun 8, 2019 at 11:33 PM
    #520
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Sorry don't know if u can. Honestly not sure what u mean either by changing locks to the bolt locks?
  11. Jun 9, 2019 at 9:33 AM
    #521
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Just finished up the install and tweaking today. Have had it on for about a month, but just got to putting the front seal on today and tweaking the front locks.
    I think the next step is to try to seal up the tailgate a bit now, can't have the front be mostly dry and the back be a constant stream coming through.
  12. Jun 9, 2019 at 9:45 AM
    #522
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Any thoughts on why its leaking?
  13. Jun 9, 2019 at 10:15 AM
    #523
    belanger9
    Edmonton, AB
    A bunch
    Cover isn't leaking, it's working perfect. I didn't have the seal on the bulkhead until today, and you could see a small gap on the drivers side at the front which I got rid of by tweaking the cover locks. There's also a couple small gaps in the bed itself between the bulkhead and the sides, along with the tailgate. I'll be buying a tailgate seal at some point, then I'll have to get some silicone seal for the last few gaps.
    DZ_[QUOTED] likes this.
  14. Jun 14, 2019 at 7:44 PM
    #524
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
  15. Jun 14, 2019 at 9:37 PM
    #525
    Abefroman
    Abefroman New Member
    Springfield, MO
    2009 Tundra SR5 4X4
    So the locking pieces don’t get scuffed up on the bed rail if I’m not mistaken
    equin likes this.
  16. Jun 19, 2019 at 9:54 PM
    #526
    Dilsky
    Shawn
    Edmonton, Alberta
    Extruded aluminum came in today. Now I just need to get the bases made to attach to the cover. I went with 1.5x3.0 inch 80/20 aluminum and the bars are 70" long.
  17. Jul 1, 2019 at 12:37 PM
    #527
    Dilsky
    Shawn
    Edmonton, Alberta
    Made this today as a mock up for where the rails will sit. End goal is a roof top tent on 3 bars. I think the height should be good, just below the roof
  18. Jul 17, 2019 at 7:32 PM
    #528
    back_cast
    back_cast New Member
    Denver, CO
    HD went on today :)
    On a side note - I helped my buddy install a BakFlip on his truck the other day and that thing felt flimsy as hell compared to the Diamondback.
  19. Jul 30, 2019 at 11:24 AM
    #529
    rideandfly
    Saw another Diamondback on a Tacoma today. They were Surveyors using the Diamondback since 2006 and they really like Diamondback!!!!
    Surveyor Work Truck:
    mgm16trdpro, Dilsky and equin like this.
  20. Jul 31, 2019 at 12:23 PM
    #530
    ejd049
    ejd049 New Member
    2018 Tundra Crew Max TRD Off Road 4X4
    Thats a cool set up. My Dad was a surveyor for 30+ years and used a suburban, like the Toyota set up better.
    rideandfly[QUOTED] likes this.
  21. Aug 12, 2019 at 10:09 PM
    #531
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    0CF4B13E-E733-4B55-83B5-840428599435.jpg A530B5ED-7930-4A9C-AF6C-BF77055C2BF3.jpg
    after a month finally here
    mgm16trdpro, Dilsky, equin and 2 others like this.
  22. Aug 13, 2019 at 12:10 AM
    #532
    hma153
    hma153 New Member
  23. Aug 13, 2019 at 2:58 AM
    #533
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Damn that ships in a big ole box
  24. Aug 13, 2019 at 4:06 AM
    #534
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    Bolt brand, you can use your ignition key or any other key you choose, instead of carrying a key for everything
    mgm16trdpro[QUOTED] likes this.
  25. Aug 13, 2019 at 10:35 AM
    #535
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    6-½ ‘ long, but I got a tool box in front that’s why it look so big..lol
  26. Aug 16, 2019 at 8:19 PM
    #536
    mgm16trdpro
    Northern NJ
    Oh ok I got ya now. Yeah I have the bolt lock for my hitch. It is awesome to be able to use my ignition key to unlock.
    Honestly never thought about it for the cover though. I didn't even know that was possible. To be honest I have a very large set of keys, between toys, work, and the fact I dont trust anyone lol. So 1 more for the cover is just that, 1 more to my ridiculous key chain. I actually carry 2 lol.
    don3032[QUOTED] likes this.
  27. Sep 8, 2019 at 4:02 PM
    #537
    mountainpanda
    mountainpanda New Member
    2016 Super White SR5 TRD 4x4
    I’m interested in a diamondback cover. I don’t have the bed rails, would it be better to get them to install it or is installing without them equally effective?
  28. Sep 8, 2019 at 9:08 PM
    #538
    mgm16trdpro
    Northern NJ
    Ask diamondback, they're very knowledgeable and will know for sure. All I can say is mine has the track and works great with it. I'm guessing u can with out it but I can't say for sure. Best bet ask DB, they'll tell u for sure.
  29. Sep 9, 2019 at 1:16 PM
    #539
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    No need for bed rails.
  30. Sep 9, 2019 at 1:52 PM
    #540
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
