Onboard Air or Portable Air?
Discussion in 'Recovery & Gear' started by Zero One Actual, Jun 7, 2019.
  1. Jun 7, 2019 at 1:47 PM
    Zero One Actual
    Zero One Actual [OP] Member among Members
    I am debating between an ARB on board air system or the ARB portable one? I do not wheel or go off gird weekly, but plan on having the air for tire inflation as a primary purpose, with any other emergency that may arise as a secondary purpose for the air.
    Since I do not wheel heavily, I am wondering what peoples opinions (yes I said it) are on the on board set up and expense versus a portable setup like the ARB portable system? Thank you for any advice.
  2. Jun 7, 2019 at 6:48 PM
    2014 Tundra Boy
    2014 Tundra Boy New Member
    2014 White Tundra TRD
    I also don’t off-road heavy either, so it’s portable for me. I’m too chicken with it under the hood with all the dust and debris. I’m sure it’s great but like I said, too chicken
  3. Jun 7, 2019 at 6:54 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    I have multiple vehicles and I went with ARB portable so can take it with me regardless of which vehicle I use.
    deepblu89, 15whtrd, xma and 1 other person like this.
  4. Jun 7, 2019 at 6:58 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    I can see on-board for a dedicated trail rig. but when you sell the rig, bye-bye on board system.
    I'm a fan of portable. It will be with you life of the unit & is far more versatile.
    GODZILLA likes this.
  5. Jun 7, 2019 at 7:01 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I purchased this from Costco..use it for air, plug in my air mattress, charge my phone..etc..fully charge last me 4 days..
  6. Jun 7, 2019 at 7:33 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I’ve got the ARB twin portable. I can move it between trucks or take it out when I don’t need it. All the hoses and stuff fit in the box so everything stays together. It also stays nice and clean unlike if it was mounted under the hood.
    4x4_Angel and porkitt like this.
  7. Jun 7, 2019 at 9:11 PM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    On board for me. I don't use it often anymore tho (used to chase desert races) I have the arb twin. It's underneath the truck even with the doors and has been there for a couple years. Dust and mud with no issues. I also have a tank with it so I can fill a 35" tire in no time.
    drobb likes this.
  8. Jun 7, 2019 at 9:13 PM
    Duneflyer
    Darren
    Yuma AZ
  9. Aug 16, 2019 at 6:27 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    I have a 5 pound CO2 tank with 120PSI reg. I take it with me when we go anywhere offroad.
    Tank, reg, and extra hose/fittings was about $150.
    lewi3069 and the_midwesterner like this.
  10. Aug 16, 2019 at 6:36 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Portable.
  11. Aug 16, 2019 at 9:21 AM
    CO_Native
    CO_Native New Member
    Englewood, CO
    2019 MGM CM TRD Sport
    Portable - unless you do heavy-wheeling & think you'll need air without power. Honestly, not even many of the Jeepers have on-board air out here in CO. It's cheaper & more practical to have portable. The real question is compressor or CO2 tank. CO2 is faster to fill, but you have to watch to make sure you don't run out. Compressor is slower but always available if you have power.
    When I had my Jeep with 36's, I bought the Viair 450p. 12v, 100% duty cycle (this is important for heavy-use), and it filled those big tires in less than 2 minutes each. I now keep the compressor in my Tundra & have used it for everything from my own tires to filling blow-up kayaks to helping folks with a flat at work. Small & convenient.
    https://www.amazon.com/dp/B000X9EGFS/ref=emc_b_5_t
  12. Aug 16, 2019 at 9:38 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    How about you get an air storage tank for under the truck, and get a portable air system. Then you kinda have both, plus extra capacity when you need it on your truck, you can have a full tank ready to go and hook your portable pump to that tank when needed, and then use the pump directly for other things. Stand alone tanks are pretty cheap at harbor freight.
    15whtrd likes this.
  13. Oct 6, 2019 at 12:01 PM
    TheBeast
    TheBeast The Beach
    bump ! looking for a portable air system. ARB or VIAIR ?
    35"s tires. which one do you recommend ?
    Pinay likes this.
  14. Oct 6, 2019 at 12:06 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I have this...been excellent and airs up fast!! Engine gets hot so may need to cool down before placing back into bag. Powered by plugging into battery of your truck with engine on.
    https://www.amazon.com/gp/aw/d/B000X9AXR8?psc=1&ref=ppx_pop_mob_b_asin_title
  15. Oct 6, 2019 at 12:12 PM
    TheBeast
    TheBeast The Beach
    thanks !. I was looking also at the one recommended by @CO_Native
    VIAIR 45053
    CO_Native and Pinay like this.
  16. Oct 6, 2019 at 12:16 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    One I have is $100 less and as I said gets aired up fast!
    Funny story, after Crab Flats run in Aug I was airing up and couldn’t figure out why this time was taking so long. I was with Tony @fisherman951 and he offered to use his. Well, he looked at my compressor and was like, what’s this plug? Is that supposed to be in there??
    Duh!! :angrygirl: Forgot to take cover off air inlet so the compressor can get air!!
    So just don’t do that and you be good!
  17. Oct 6, 2019 at 12:30 PM
    TheBeast
    TheBeast The Beach
    Pinay likes this.
  18. Oct 6, 2019 at 12:34 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I have a cheap one from Amazon I think 50 or 60 bucks I have used it 3 times it’s definitely not fast but filled up my 35s with no problems. Just grab a beer and wait it out lol. I don’t do enough off-roading to justify couple hundred dollars or more on a compressor.
  19. Oct 6, 2019 at 12:35 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    From their FAQ's
    Q: What is “Duty Cycle”?
    In short, Duty Cycle is the amount of time that a compressor can be run in a full cycle (typically one hour) that includes the compressor’s run time and rest time. Select VIAIR compressors are equipped with a thermal overload protector to protect the unit in case of over duty cycle or high temperature operation.
    TheBeast[QUOTED] likes this.
  20. Oct 6, 2019 at 12:39 PM
    TheBeast
    TheBeast The Beach
    I think if you do multiple vehicles (you and your cheap ass buddies..) the 100% duty cycle option might be better
    Pinay[QUOTED] likes this.
  21. Oct 6, 2019 at 12:42 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :rofl::rofl: Even if I aired up others it won't take so long that I would worry about it running an hour. Just my truck alone gets it kinda hot to the touch but that's cuz it's been on and working so understandable but cools off fast.
    4x4_Angel likes this.
  22. Oct 6, 2019 at 1:28 PM
    Zero One Actual
    I still haven’t been able to decide which one to get either. Let me know what you go with.
  23. Oct 6, 2019 at 2:08 PM
    TheBeast
    TheBeast The Beach
    ended up ordering the VIAIR 450P since I had an Amazon gift card :) I can't justify ARB at double the price for a quality that is not what it used to be.
  24. Oct 6, 2019 at 3:02 PM
    Zero One Actual
  25. Oct 6, 2019 at 3:24 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    If you need a mount for the ARB compressor then let me know! I have the mounts for sale made for the ARB twin. Can also use the mount to install any other compressor of your choice. It’s really nice to have air all the time.
    TheFreshMouse and jordan0317 like this.
  26. Oct 7, 2019 at 6:14 AM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Love my ARB portable. If someone else needs air they can use their battery not mine. Comes mounted in a nice toolbox where i keep the upgrade filler hose with gage, tire patch kit.... the portable stays packed away until needed, not subjected to heat and dust of engine bay.
    TheBeast and Pinay like this.
  27. Oct 7, 2019 at 12:43 PM
    SMITTY_4x4
    SMITTY_4x4 New Member
    Stefan
    2015 SR5 4x4
    Just Starting
    I have something that works great but is not designed for this intended purpose. I use an old firefighting SCBA tank and modified the hose fitting to an air chuck. It fills up tires FAST! I just have to be sure not to open it too fasy as there's no regulator. Someone that has old SCUBA tanks could maybe have those filled with regular air? Not sure I don't dive.
  28. Oct 7, 2019 at 3:26 PM
    CO_Native
    Englewood, CO
    Yep, just duty cycle. I got the heavier duty unit because I had huge tires & was refilling them weekly after trails. The lesser is more than enough for 90% of applications.
  29. Oct 7, 2019 at 4:47 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I would use it once a year so portable
  30. Oct 7, 2019 at 5:20 PM
    Dakar650
    Dakar650 New Member
    Shawn
    2019 Cement Limited
    I went with the Viair system. Comes in a bag and can move from truck to truck
