Give me your honest opinion on the Raptor liner look
Discussion in '2nd Gen Tundras (2007-2013)' started by Jach2008, Feb 2, 2019.
  1. Aug 11, 2019 at 4:06 AM
    #91
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Righteous!
  2. Aug 11, 2019 at 4:24 AM
    #92
    Jach2008
    Jach2008 [OP] New Member
    New Tripoli
    2008 dove gray tundra
    Afe cold intake,bilstein shocks,raptor lined Paint job,led rear light bar,touch screen radio,kicker speakers on the dash and Rockford 6x9in the doors,mbrp exhaust,amp research power steps
    Thanks man
  3. Aug 11, 2019 at 8:31 PM
    #93
    traces95z
    traces95z New Member
    Gotcha. The tint is in 3 ounce bottles which equals about 88 milliliters. Raptor says to add 100 milliliters of tint. Did you conmpensate for the difference or just
    add the one 3 ounce bottle to each liter of Raptor?
    Thanks.
    #93
  4. Aug 11, 2019 at 10:50 PM
    #94
    Jach2008
    New Tripoli
    Just add the 3 oz bottle that's it,the trick is to use a paint mixing container dump out the bottle of raptor and add your paint then your hardner,and then mix it up dump it back in, it works better this way anyway because it will be to much in the bottle,you never want to have the bottle full it will leak out of the top hole in the gun,half to 3/4 full works the best.any more questions just ask,doing a golf cart and boat the next two weeks,prep is so important so make sure you prep and clean
    traces95z and trdprobped17 like this.
  5. Aug 12, 2019 at 12:38 AM
    #95
    trdprobped17
    trdprobped17 New Member
    It looks sweet!! How is it holding up? I’m thinking about doing the lift gate and upper area of the bed. Those areas seem to get all the dings and bumps on my truck. I’m on the fence with just using any ole bedliner because I would hate to see it fade and crack up on my truck. What are your thoughts? Thanks.
  6. Aug 12, 2019 at 2:27 AM
    #96
    Jach2008
    New Tripoli
    Holding up great,no fading,no cracking,I did a bunch of vehicles already not one problem.
    trdprobped17 likes this.
  7. Aug 12, 2019 at 11:09 AM
    #97
    trdprobped17
    That’s good to know. I have been hearing about people having their bedliners crack and peel recently due to the extreme heat.
  8. Aug 12, 2019 at 3:18 PM
    #98
    _cumdra_
    _cumdra_ New Member
    Devin
    2011 tundra sr5
    Fuel Mavericks 20x10, 30x12.50 nitto terra grapplers 3inch level kit
    Looks good just needs some new shoes
  9. Aug 12, 2019 at 3:20 PM
    #99
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    Looks great. I like what you did with the wheels. They look much better than metal finish.
  10. Aug 12, 2019 at 3:33 PM
    #100
    Jach2008
    New Tripoli
    Thanks I just used flat black wheel paint
  11. Aug 12, 2019 at 3:35 PM
    #101
    Jach2008
    New Tripoli
    Yeah,just had a son so this project is on hold
  12. Aug 12, 2019 at 3:38 PM
    #102
    Jach2008
    New Tripoli
    And raptor has uv protection
    trdprobped17[QUOTED] likes this.
  13. Aug 12, 2019 at 6:46 PM
    #103
    trdprobped17
    That’s a very important feature. Thanks.
  14. Aug 12, 2019 at 7:24 PM
    #104
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I like the color better than just black like you see everywhere. I would love to never have to worry about pinstripes or scratches again
  15. Aug 13, 2019 at 4:04 PM
    #105
    Fozzy360
    Fozzy360 New Member
    Hunter
    Virginia
    2010 Tundra Crewmax Limited
    Stock
    Like it
  16. Aug 13, 2019 at 4:31 PM
    #106
    Jach2008
    New Tripoli
    I love it to ,soap and a scrub brush your done
    JH5370[QUOTED] likes this.
  17. Aug 14, 2019 at 12:49 PM
    #107
    james33440
    james33440 New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    With what you all sprayed dove gray, how many bottles did you use? I want to get the 8 liter kit on eBay but curious as to how many bottles I’ll use.
    I want to have enough to do 2 coats of black on the grill, front and rear bumpers, and mirrors and finally 2 coats of dove gray on the body just as you did. But I’ll do the door handles too.
  18. Aug 14, 2019 at 1:55 PM
    #108
    Jach2008
    New Tripoli
    I used 8 on my truck always good to have enough,can't stop and go get more I over estimated I got 4 or 5 leftover of the paint
  19. Aug 15, 2019 at 11:25 AM
    #109
    james33440
    James
    Magnaflow Exhaust
    So the 8 liter kit would be enough? How many bottles with dove gray would you say you used? I’m trying to see if the 8 liter kit would be enough or if I should get a few more so I have enough black.
  20. Aug 15, 2019 at 11:53 AM
    #110
    Jach2008
    New Tripoli
    Each bottle of tint for one liter of raptor plus your hardner,I used 3 black to do my rest of my stuff,I used 8 liters of dove gray
    james33440[QUOTED] likes this.
  21. Aug 27, 2019 at 10:52 AM
    #111
    OCWood
    OCWood New Member
    Jack
    2009 White Tundra Extended Cab
    Looks great. What have you done with the interior? could you post a couple of pics of how you transitioned/blended from the raptor to the inside paint? Thanks!
  22. Aug 27, 2019 at 11:19 AM
    #112
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    Looks like the exact reason I loved south. Nice truck though.
  23. Aug 27, 2019 at 12:05 PM
    #113
    Jach2008
    New Tripoli
    I used the same color inside the doors what a f pain in the balls,I used a paint brush and this stuff stinks inside, so don't do it use paint to match
  24. Sep 2, 2019 at 5:22 PM
    #114
    traces95z
    Did you take off the Tundra and TRD badges before painting? If so, how did you reattach them? Or did you tape them?
    Thanks.
  25. Sep 2, 2019 at 5:28 PM
    #115
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    After taking a very detailed look at every picture. My verdict is that S@#$ is AWESOME, I LOVE THE LOOK..I got to get it done.:ohsnap:
    Olenewt likes this.
  26. Sep 2, 2019 at 5:53 PM
    #116
    Jach2008
    New Tripoli
    I taped them off,was concerned with the texture they would not go back on,made the right choice
    traces95z[QUOTED] likes this.
  27. Sep 2, 2019 at 5:56 PM
    #117
    Jach2008
    New Tripoli
    Thanks man,I get so many people asking about it,I still love it,easy to clean
  28. Sep 29, 2019 at 9:19 AM
    #118
    traces95z
    Did you go 70 then realize it was too bumpy then went with 80, or was there a method to your "madness"?
  29. Sep 29, 2019 at 10:10 AM
    #119
    Jach2008
    New Tripoli
    No you put a medium coat first then then you finish with second coat with the texture you want.
  30. Oct 2, 2019 at 2:32 PM
    #120
    pool0202
    pool0202 New Member
    08/14 conversion Tundra CrewMax
    front end swap, bed swap in near future, paint to come (leaning towards quicksand bed liner)
    That cement looks great! I remember checking yours out before I sprayed mine with quicksand raptor. Tough choice between the two colors.
