2019 trd pro lift kit options?
Discussion in 'Suspension' started by Trdpronobiggie, Aug 12, 2019.
  1. Aug 13, 2019 at 12:20 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I went this direction exactly.
    I ordered my Platinum with the PRO suspension and put the full @Coachbuilder1 ensemble on... bumper spacers, front shims, drop bearing, steering rods, and +3 shackles to get the room for 34-35" tires. Mine are Mickey Thompson tires and wheels 275/65/20 -20x9 +~20 offset. This yeilded a 34.3" X 11.25" mounted setup. I have zero rubbing. At some point I'll will be moving up to a 35" with the CMC. I have the plates from Total Chaos ready to go when these tires wear a little bit more.
    I'd say go for 35's to start, you'll definitely like it better than the OEM pizza cutters for sure.
    This direction keeps your PRO parts in the game! ... and you can always go bigger later. I love my Coachbulder PRO setup! With the TRD front and rear sways this thing handles phenomenal.
  2. Aug 13, 2019 at 4:19 PM
    Trdpronobiggie
    Trdpronobiggie [OP] New Member
    19 tundra trd pro
    Can i see what yours looks like with the bullet proof lift?
  3. Aug 13, 2019 at 4:43 PM
    Mnorris1206
    08 tundra
    With any lift I think just my opinion always try to go more tire then wheel. A friend of mine has a tundra set up just like mine but he is on 22" wheels and I'm on 18" I feel my ride has alot more cushion. Just a little side note.
    Trdpronobiggie[OP] and 15Yota like this.
  4. Aug 13, 2019 at 6:02 PM
    bossgobbler32
    bossgobbler32 New Member
    This looks really nice. To me it’s the perfect stance. Nice job!
    Trdpronobiggie[OP] likes this.
  5. Aug 13, 2019 at 6:05 PM
    bossgobbler32
    Great looking truck! Solid looking aggressive stance but not overdone. Very nice!
    Toyotoholic[QUOTED] likes this.
  6. Aug 13, 2019 at 7:13 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    I run ko2 35x12.5 and haven’t needed any chop.
    Coachbuilders pro kit, 1.25” spider trax spacers, removed the front mud flaps, heated the front fender liner and pushed them in. Winner winner.
  7. Aug 13, 2019 at 8:12 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Thanks!
  8. Aug 13, 2019 at 11:25 PM
    kgb4187
    kgb4187 New Member
    You paid about 10k for mostly the suspension, your salesman should have explained all the differences before you bought it. There's no power upgrades to the PRO so the SR5 that it's based on would have felt the same. You can probably get 2k for the wheels and tires though.
    Goodie2626 and GarTX526 like this.
  9. Aug 14, 2019 at 12:54 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I'll never understand this either. Pay that much extra, for the end product, of a stamped bed and seats with TRD pro stitched in them. Should just buy a SR5.
    nlg4021 and kgb4187[QUOTED] like this.
  10. Aug 14, 2019 at 6:26 AM
    Trdpronobiggie
    19 tundra trd pro
    Can i see a picture
  11. Aug 14, 2019 at 6:39 AM
    Trdpronobiggie
    19 tundra trd pro
    Attention negative Nancy's.........
    I didnt want a base model sr5. I just didnt. I liked what i bought. Al of this could of should of sh*t is annoying and doesn't help any at all. Id like bigger tires. Id like to retain most of my ride quality but still lift it some. If you can add something positive and helpful to the conversation, great! If you "just dont understand why anyone would try to do what im asking help with trying to do", then move on. Its my money. Ill spend it how i want to.
  12. Aug 14, 2019 at 8:25 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    First thing you have to do is decide on your offset. If you’re ok with your tires being a little tucked in, you can keep your current wheels and go 295/70/18’s (34.5”) and just swap your tires with very little to no cutting at all. If you want to go 35’s, you either need wheel spacers or wheels with a lower offset to get you away from the UCAs. But that’ll require a cab Mount Chop and more trimming. If you want to go up to 37’s, you’ll also need to replace your suspension with at least a 3” lift and adjustable UCAs to move wheels forward and still get a proper alignment, but that’ll require a whole lotta cutting. Anything bigger than that I don’t recommend.
    And about buying a pro and replacing all the pro parts. You can sell just your wheels and suspension for about $5k so you’re not even losing that much. Just ignore the haters.
  13. Aug 14, 2019 at 12:08 PM
    escuzi_me
    William
    Nashville, TN
  14. Aug 23, 2019 at 7:26 PM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
  15. Aug 26, 2019 at 6:39 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Thanks
  16. Oct 29, 2019 at 1:31 PM
    Merallica377
    Merallica377 New Member
    Jon
    Picking up my 2019 Tundra TRD Pro on Friday :yes:I think I will go with the Ready lift 3" Front Leveling Kit and the 2" Rear Block Kit. Then put the Nitto 285/70/18's on the Stock TRD Rims.
    GarTX526 likes this.
  17. Oct 29, 2019 at 1:52 PM
    Cthulhu
    William your vinyl set-up on your hood is on point.
    Bama likes this.
  18. Nov 9, 2019 at 10:17 AM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    I’m in the same boat you’re in NoBiggie.
    Bought a 2016 Pro and I love it for all the same reasons: ride quality, exhaust sound, interior etc.
    What I didn’t know is that I’d have challenges lifting the truck if I wanted to go bigger (wheels, tires, altitude). So I basically paid a higher tab for a truck that already has a 2” lift kit. So like you, I have to decide if I want to enhance the existing setup (keep the Bilsteins and ride quality) or if I want to “gut” the whole thing and start from scratch.
    Personally I’m going to move forward with the ReadyLIFT ProPlus 2 which will add 2 inches to the current 2 inch lift for a total of 4 inches. I can get 35” tires on this.
    ReadyLIFT also has PP4 (6 inches total) and PP6 for (8 inches total). I believe you can get up to 37” tires on the ProPlus6.
    Point to consider, I’m not sure if the ReadyLIFT kits are tested on a 2019.
    Other options are Coachbuilder and Toytech shackles and shims which I believe will give you about 3-3.5 inches total lift to accommodate 35 inch tires.
    Another consideration is wheel offset.
    I want a slightly aggressive stance so looking at some Black Rhino’s with +12 offset. This image is from mjime714 with 35s on 18x9.5 +12 offset.
    At the end of the day, it’s your ride.
    Do whatever the hell you want to it that makes you happy!
    Good luck bro!
    salmonfacesalad likes this.
  19. Nov 9, 2019 at 1:12 PM
    No Limit
    No Limit New Member
    Alberta
    I’m picking the Truck up on Tuesday and can upload more pics then, but here are some pics my dealer sent me after the lift was installed. 2020 PRO with a 4” Readylift and +2 Coachbuilder Shackles added to the 3” blocks that come with the Readylift. This lifts the rear a total of 4 1/4” to keep the stock 1” Rake on the PRO. Without the Shackles it would be level.
    +20 offset 20” Fuel Wheels on 35” Nitto’s
    A58ECEB2-2DF9-4881-910D-EFD82588E8C5.jpg A4860C7B-5183-4E9E-94BE-732215A64066.jpg
  20. Nov 9, 2019 at 1:14 PM
    #50
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    I'm a BDS fan for sure. On my 2nd Tundra with the 7" lift. 2012 had 35X12.50X20s, my 2016 has 37X13.50X20s. Had to do a slight cut on the body mount behind the tires so they don't rub for the 37" tires; added filler plates to cover those though:
    https://sdhqoffroad.com/products/07-current-toyota-tundra-sdhq-built-body-mount-chop-filler-plates
    There is a thread either at TundraTalk or here about the Rough Country lift. Absolutely stay away from it. Search for it and you'll see why (axles breaking (half shafts rather at the CV joints)).
    Here is some good info:
    https://www.tundratalk.net/threads/bds-7-icons-questions-answered.89174/#post-497222
  21. Nov 9, 2019 at 1:42 PM
    #51
    GarTX526
    GarTX526 New Member
    Many pending.....
    That’s a sweet looking ride No Limit!!!
  22. Nov 9, 2019 at 1:53 PM
    #52
    No Limit
    No Limit New Member
    Alberta
    Thanks GarTX526 :)...can’t wait to pick it up ‼️
  23. Nov 9, 2019 at 5:25 PM
    #53
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
  24. Nov 9, 2019 at 9:00 PM
    #54
    GarTX526
    GarTX526 New Member
    Many pending.....
    Damnnnnnn that is nice!!!
  25. Dec 1, 2019 at 7:45 AM
    #55
    TacomaTundra
    TacomaTundra New Member
    Don
    Charlotte, NC
    2014 Black Toyota Tundra Limited Crewmax
    Nice ride! I've been looking at putting the 4'' Readylift on my 2014 Tundra Limited Crewmax (#RDY 69-5475) and 35'' Cooper Discover AT3 XLT's on the stock limited wheels. It's the 4 inch front and 2 inch rear lift.
    For me, it's about have a more capable vehicle in my regular travels through the mountains during the winter. What are people's thoughts on the 4'' Readylift?
  26. Dec 1, 2019 at 8:04 AM
    #56
    No Limit
    No Limit New Member
    Alberta
    I did the 4” Readylift on my 2020 PRO and love it, the stance and ride quality are perfect.
  27. Dec 1, 2019 at 8:07 AM
    #57
    TacomaTundra
    Don
    Charlotte, NC
    Thanks for the quick feedback. The 4'' Readylift seems to meet all of my criteria, as I won't be off-roading. The main goal for me is to put 35's on the Tundra and anticipate the weight of a new front + rear bumper with a winch on the front. The person at the local 4Wheelparts store this would be the best route.
  28. Dec 1, 2019 at 8:23 AM
    #58
    No Limit
    No Limit New Member
    Alberta
    I had to add shims to the front bumper to not rub with 35’s
  29. Dec 1, 2019 at 8:25 AM
    #59
    TacomaTundra
    Don
    Charlotte, NC
    I'll keep that in mind, thank you! I'm pretty set on the 4/2 Readylift for my purposes. I'll talk to the shop about the shims, although the front C4 fab bumper will go on a few months down the road.
  30. Jan 28, 2020 at 7:30 PM
    #60
    Rustynailz
    Rustynailz New Member
    2019 black trd pro
    I got 295/70r18 ridge grapplers on my stock 2019 pro just had to take the front mud flaps off... looking to upgrade with the @Coachbuilder1 pro kit soon.. only thing is I tow boats,quads, sleds so might have to do some ride rights too with the day star cradles. Don’t like the sag at all. Just gotta see if they work with @Coachbuilder1 airbag shims
