Show your Tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by G-manCO, Nov 13, 2017.
  1. Jul 31, 2019 at 11:27 PM
    #211
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
  2. Aug 1, 2019 at 10:40 AM
    #212
    TheBeast
    TheBeast The Beach
    It's been great and I forgot to post pictures :)
  3. Aug 1, 2019 at 3:28 PM
    #213
    biebs96
    PA
    I have a Gator Evo bi-fold hard cover. Compared to a bakflip (owned by a coworker). The materials and hardware are certainly comparable. The only downside that others have said is that cover is either open 1/2 way or needs to be removed to haul large items.
    This isn’t an issue for me as my last tundra had a cap on it for 7 years and I own a trailer.
    Got it on a Memorial Day flash sale for $500 shipped.
    Only a tiny leak on one of the front corners, but a small dab of black silicone from inside and it was sealed.
    equin likes this.
  4. Aug 7, 2019 at 11:11 AM
    #214
    19Tundra77
    19Tundra77 New Member
    Corey
    2019 Tundra CM TRD Sport 4x4
    BAKFlip G2 Tonneau Cover N-Fab Polished Steel podium step bars Chrome Tailgate Inserts Polished Steel bed rail bars
    BAKFlip G2 - easy to install and the drop down brackets for the deck rail seems very stable. So far only minimal water getting into the bed @ the tailgate and not from the cover
  5. Aug 7, 2019 at 1:10 PM
    #215
    djhase
    djhase New Member
    Great idea using pipe insulation. That's gonna solve the same problem with my cover. I couldn't get the dang weather strip to stick to the bed liner stuff. Some great ideas to be had here. Thanks,
  6. Aug 22, 2019 at 7:28 PM
    #216
    Dunchues
    Dunchues New Member
    New Brunswick
    Very pleased with the Tyger roll back cover I paid Amazon 190$ for. Much better quality than the price would suggest and seems watertight so far. Took 20 mins to fit and looks fine to me.
    Henry1jg likes this.
  7. Sep 10, 2019 at 8:54 PM
    #217
    TruckCovered
    TruckCovered New Member
    That is a beautiful truck cover. I have a Bakflip MX4. They are some of the best covers around.
  8. Sep 11, 2019 at 8:13 PM
    #218
    dittothat
    dittothat New Member
    SD
    2016 MGM Platinum
    Swapped my truck covers USA American roll cover to an American work cover. Took the better part of a day to do the rail cuts and install but I’m pumped to have a toolbox back
    D0EFB76B-A21F-4C69-BFD9-E8848396F1FF.jpg C7AC426A-03CC-4910-AD34-A171569FBF3F.jpg
  9. Oct 22, 2019 at 3:17 PM
    #219
    SaltH20
    SaltH20 New Member
    2019 Tundra SR5 5.7
    Not the greatest pic but I went with the Undercover SE (unpainted). I had one on the last truck and it served my purposes very well. It is dry, and not too hard to remove if needed.Tundra1.jpg
    equin likes this.
  10. Oct 22, 2019 at 3:34 PM
    #220
    MICKs18yota
    Ohio
    2018 Tundra SR
    Like that cover can you provide some additional photos especially around the tailgate area curious it it’s tight on the tailgate or overhangs
    Thanks
  11. Oct 22, 2019 at 4:09 PM
    #221
    SaltH20
    SaltH20 New Member
    2019 Tundra SR5 5.7
    I can get some more pics soon. The cover goes over the tailgate (overhangs) so you can not open the tailgate when the cover is closed. The cover fits very well and even has some foam (stick on) in the back corners to prevent rubbing.
    equin likes this.
  12. Oct 22, 2019 at 6:37 PM
    #222
    MICKs18yota
    Ohio
    2018 Tundra SR
    thanks when you get a chance on photos that would be great I’ve got a double cab and curious what it would look like I’ve seen some of the under covers
    I’ve seen some of the undercover covers where they sit past the tailgate like 2+ inches past the tailgate and it doesn’t look good and the tailgate can still open that’s why I was wanting some better looks at it. Yours looks good.
    Thanks
  13. Oct 23, 2019 at 4:15 PM
    #223
    SaltH20
    SaltH20 New Member
    2019 Tundra SR5 5.7
    Here are some more pics. I hope they are helpful. Again, I like the cover. It is very durable and keeps things dry. Although on my old truck, after about 8 years, the rubber seal against the cab began to curl and some water was able to trickle in. I didn't bother contacting undercover to get a new rubber gasket because I was getting rid of the old truck. driverside.jpgpassengerside.jpgtailgate.jpgtailgate2.jpgunrcvrse.jpg
    Hoff, TK1979, Freakenrage and 2 others like this.
  14. Oct 23, 2019 at 5:35 PM
    #224
    MICKs18yota
    Ohio
    2018 Tundra SR
    Thanks for pictures looks good looks like it fits good no large gaps and looks like the tailgate wouldn’t open until you lift the cover thanks again
    Hoff likes this.
  15. Oct 29, 2019 at 6:53 PM
    #225
    jpfleming
    jpfleming New Member
    How is your Extang Solid Fold 2.0 holding up?
    jlarkin1918 likes this.
  16. Nov 28, 2019 at 9:28 AM
    #226
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Peragon covers?
    Beesta likes this.
  17. Dec 3, 2019 at 6:53 AM
    #227
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Lomax installed this am. Super happy with it.
    Cock-A-Doddle-Do and 406Michael like this.
  18. Dec 10, 2019 at 6:47 PM
    #228
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
  19. Dec 10, 2019 at 7:38 PM
    #229
    2chains
    2chains New Member
    Southern Ablerta
    ^^Looks great, just ordered mine from their outlet!
    jpod likes this.
  20. Dec 29, 2019 at 6:16 PM
    #230
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Henry1jg, Drifthopper and equin like this.
  21. Jan 2, 2020 at 10:48 AM
    #231
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    @Beesta, What is your review of this cover after some time. Does it close and seal nicely? Any issues with dirt getting in the tracks and making it hard to operate? Pros/cons.
    I'm interested in this cover and your thoughts would be appreciated.
  22. Jan 2, 2020 at 7:26 PM
    #232
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I use to have a roll up cover on my Tacoma. Ended up selling it because it would freeze up all the time and make it impossible to open.
    TrooperDC4x4[QUOTED] likes this.
  23. Jan 2, 2020 at 8:24 PM
    #233
    Roflo5
    Roflo5 Roflo5
    Robert
    Atwater, California
    2018 Tundra Limited 4 x 4
    TRD Pro intake and TRD Pro exhaust system, TRD Pro grill, black roof wrap, TRD Pro Sway bars, ReTrax Pro Tonneau cover, Line-x bed liner, ESP Long gun Box, Center console safe, TRD Pro Skid Plate, blacked out badges. TRD Pro gear shift, driver side grab handle Wireless Phone Charging tray, Pop-N-Lock wireless tailgate lock.
    I really like my Tonneau Cover.
    Alex_TnDra likes this.
  24. Jan 3, 2020 at 7:58 AM
    #234
    TrooperDC4x4
    Nor Cal
    Good input. I am in Nor Cal so that situation does not happen a lot where I spend most of my time, but is possible.
  25. Jan 3, 2020 at 10:23 PM
    #235
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Warmer climates and it works great but if I ever went through a car wash the cover would freeze up and I couldn't get it open. The manufacturer suggested a water repellant spray which helped somewhat but I still would have the freeze up issue.
  26. Jan 8, 2020 at 12:23 AM
    #236
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    I love the cover .... no issues as far operational... to be honest i’ve only use the truck for 6 weeks ... ive notice its leaking water more than i want to ..... that will be my project when i come home...
  27. Jan 8, 2020 at 8:34 AM
    #237
    TrooperDC4x4
    Nor Cal
    Thanks,
    I have decided on the Peragon over an aluminum roll up. Major selling points that it works great with a lumber rack, I can also mount a bike rack above the bed and have it be operational without removing the bikes. It will be nice to have a little security for the bed as I always have tools and other items back there. Everyone that has one seems to be pretty happy.
    Beesta[QUOTED] likes this.
  28. Jan 8, 2020 at 11:50 PM
    #238
    jlarkin1918
    jlarkin1918 New Member
    Jared
    Western Massachusetts
    2020 SR5 TRD Offroad Crewmax-Cement
    OEM Spray-In Liner TRD Pro Black Badges & center caps GoRhino RB20 running boards Lomax cover
    How you liking the lomax?
    What finish is that? The matte black or the black eurethane?
    You mentioned the deck rail can stay on with this cover, could you still tie something down under the cover or is the cover too close to the top of the cleats?
    Can you still move the cleats so you could tie something down on the back 2/3 with the cover in its open 1/3 position by the cab?
    PS. Love your truck, we’re almost twins except mine is the SR5 not limited...less for me to de-chrome!
  29. Jan 8, 2020 at 11:57 PM
    #239
    jlarkin1918
    Jared
    For those tyger fans on here, which tyger model is it you have and like?
    Website shows T1, T2, T3 and a T5 wondering which one it is that people are posting about?
  30. Jan 10, 2020 at 2:14 PM
    #240
    Ckatz53
    Ckatz53 Newish
    MD
    Still love it. Been through a few car washes and heavy rain, no leaks. Matte black finish. Can still tie something down and relocate the cleats as you see fit. Took about 10 seconds to remove it when I had to go pickup my 35s.
    And thanks! It's at the shop now getting the last of the chrome replaced!
    406Michael likes this.
