Towing vibration
Discussion in 'Towing & Hauling' started by KeetAz, Aug 5, 2019.
  1. Aug 5, 2019 at 9:44 AM
    KeetAz
    KeetAz [OP] New Member
    Gilbert AZ
    2020 SuperWhite PRO
    3FD0C548-DA53-47E2-B660-0039E208AF67.jpg Howdy fellas. Yesterday I took my quad up to the mountains for a little fun away from the heat here in PHX. While towing my utility trailer I was noticing some steering wheel vibration and wobbling. Never does it without the trailer. It’s a 10 ft Big Tex. Bought it brand new. It’s got maybe 400 miles on the tires. The weird thing is it doesn’t do it all the time. Could it just be the roads? I noticed my passenger seat vibrating like crazy as well. I’m new to towing so I would love some feedback! Truck has 5000 miles on it btw
  2. Aug 5, 2019 at 11:37 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    With 400 miles on trailer I would check lug nuts and air in trailer tires might want to jack up trailer and rotate tire make sure they are round some trailer tire aren’t the best quality pretty much all imported
    Mwray8909 likes this.
  3. Aug 5, 2019 at 11:38 AM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
    I run close to max psi in the tires as I read that’s what most do? Am I wrong doing this?
  4. Aug 5, 2019 at 12:17 PM
    LML 3500HD
    Are the tires on the trailer balanced?
    Tire condition? Any bulges in the sidewall (inside).
  5. Aug 5, 2019 at 2:15 PM
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    I have an Aluma 6310H (3K axle). It begins to vibrate at 68 mph. Tires balanced, no help. One of the tires is noticeably Out of round. Since I don't have it loaded to near capacity, I dropped the tire pressure to 46 psi cold. That helped a lot. My other trailer, a steel 6x12 that weighs twice as much was horrible until I replaced the tires with better quality radials. Now its smooth as silk. Will replace tires on the lighter trailer this fall.
    bc
  6. Aug 5, 2019 at 2:47 PM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
    My tires are radials and seem to be in excellent condition. What’s weird about this is it has times that it’s smooth as silk, and others where the truck will almost like shake with steering wheel wobble.
  7. Aug 5, 2019 at 2:48 PM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
    What’s a good way to test for balancing? Or is it something I’d have to take to a tire shop?
  8. Aug 5, 2019 at 3:24 PM
    blaserdude
    Eugene
    none
    The pavement can set up a harmonic vibration. If tires are out of balance or out of round it will amplify the problem. The 4 wheeler in your pic is not loading the suspension much so you are not getting much damping there. Where the center of gravity of the trailer and load is located has an affect. Tires can look great but still have lousy ride quality. Most utility trailers and new vehicles for that matter come with cheap tires.
  9. Aug 5, 2019 at 3:27 PM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
    So do you think I should alter how I load my quad? Weighs about 750 lbs
  10. Aug 5, 2019 at 3:48 PM
    LML 3500HD
    Are there balancing weights on the rims?
  11. Aug 5, 2019 at 3:56 PM
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    I've experienced this issue and still experience it somewhat. Removing the rear sway helped a bit. I haven't hauled my tractor anywhere yet so I'm not sure how it handles with a heavy load but light loads are bumpy on certain roads. New trailer too...2017 tandem axle.
  12. Aug 5, 2019 at 4:00 PM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
  13. Aug 5, 2019 at 4:20 PM
    LML 3500HD
    That be your problem.
  14. Aug 5, 2019 at 4:37 PM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
    Thanks a lot for the input Colorado. I’ll get them balanced.
  15. Aug 5, 2019 at 7:40 PM
    LML 3500HD
    Most trailer sales businesses do not balance trailer tires due to cost.
  16. Aug 5, 2019 at 7:46 PM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
    Of course they don’t......oh well. Taking to Discount tire this weekend. Thanks again
  17. Aug 5, 2019 at 8:14 PM
    LML 3500HD
    When you test it out, let us know.
  18. Sep 28, 2019 at 5:58 PM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
    ****UPDATE****
    Well to nobody’s surprise, ColoradoTJ was correct. Took the trailer tires in for balancing. Finally drove the quad up for some riding today. Vibration and steering wheel shake 100% gone. Tows like a freakin dream now. Best $30 I ever spent! Thanks again for the input. This forums is awesome!
    jeremyd and ColoradoTJ like this.
  19. Sep 28, 2019 at 6:16 PM
    LML 3500HD
    Glad it was a simple and cheap fix!
    My trailer vibration today was not so cheap, but an easily diagnosed one. A friend from work borrowed my equipment hauler and pretty much didn’t know anything about towing. He had a brake controller (said he didn’t) and the gain was maxed out. He totally destroyed two tires on the forward axle.
    77D4A1DA-9D80-4D9C-A70F-594D5E50570F.jpg 7E9364E2-7B6B-4789-9C76-BF8747B8D10F.jpg
    These tires were brand new 15 days ago.
    He also did the drag test for one of my emergency break a way chain.
    Cost him 300.00 today.
  20. Sep 28, 2019 at 6:19 PM
    KeetAz
    Gilbert AZ
    2020 SuperWhite PRO
    Holy crap. Sorry but towing is the last thing I’m lying about having experience in. Especially when he has a friend like you with so much experience. Glad it was only tires that took the punishment
  21. Sep 28, 2019 at 6:35 PM
    LML 3500HD
    @COMiamiFan and I will find out tomorrow with around 300 miles of towing.
    TXMiamiFan likes this.
