Cold air intake reviews
Discussion in 'Performance and Tuning' started by Cpa757va, Jul 23, 2019.
  1. Aug 2, 2019 at 3:33 PM
    Tundra_power
    Tundra_power New Member
  2. Aug 2, 2019 at 4:06 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Might be considered a waste of $ but the Trd cai and Trd duals work well together.
    ARMYGREEN and Rica25 like this.
  3. Aug 2, 2019 at 4:21 PM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    This is the route I took also.
  4. Aug 2, 2019 at 6:04 PM
    Rica25
    Ricardo
    Tulare
    No .....I inly spent about 20 or less
  5. Aug 2, 2019 at 7:00 PM
    Tundra_power
    I tested the sabm intake definitely not a waste of money. Lots of people get info from other people saying our intake is already cai this is true but not perfect. Toyota had to make it within HVS testing and emissions stand point. But right now i have the s&b intake best intake for the money with the bullydog tune..
    Hbjeff and Rica25 like this.
  6. Aug 2, 2019 at 7:01 PM
    Tundra_power
    Yea i bought the kit from g-tek fab it was a great kit.
  7. Aug 4, 2019 at 8:34 AM
    Cpa757va
    Cpa757va [OP] New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    I bought the AFe drop in dry filter but it’s not fitting my stock air box. Guess I’ll call AFE and see if i can return it.
    Rica25 likes this.
  8. Mar 9, 2020 at 7:05 PM
    CTPlatinum
    CTPlatinum New Member
    2020 Tundra Platinum 4x4
    None Yet
    Buy a toyota air accelerator and a drop in filter. The CAI are a waste of money and the SABM has been proven to do nothing but butcher your truck.
    10TundraSR5 likes this.
  9. Mar 9, 2020 at 7:25 PM
    Tundra_power
    Not true i have sabm and it was definitely noticeable in mid range and upper rpms for sure. Help me towing, it was a bigger difference than the trd accelerator and drop in filter combine.
    Tundralicious and Rica25 like this.
  10. Mar 9, 2020 at 7:37 PM
    CTPlatinum
    None Yet
    With all due respect I think your butt dyno may be a little off, I have personally seen a stock Tundra and SABM Tundra on a dyno and there is ZERO difference! Now, if you add a bunch of supporting mods then there may be a benefit.
    Rica25 likes this.
  11. Mar 9, 2020 at 7:45 PM
    Tundra_power
    Opinions will vary on this subject just like tuners and everything else with tundras. When i put the sabm on it was totally stock and i did notice a bump in torque at mid range to higher rpms. G-tek sells the kit and dyno it and gains 5-6hp peak. Now below the curve matters more but i didn't see the dyno chart but im gussing it did gain torque at around 3500rpm. Yes it did make the intake louder and meaner. I totally agreed keep stock intake. Any aftermarket intake will lose low end torque iv tested them and lost low end with no gain at top.
    Rica25 likes this.
  12. Mar 9, 2020 at 7:52 PM
    Tundra_power
    But right now i do have supporting mods for the truck mods: high flow filter, sabm, trd flow accelerator, throttle body coolant bypass if that does anything lol, bamuffler system 6in, bullydog on trail tune with 93 octane, doug throley shorty headers.
    Inquiringone and Rica25 like this.
  13. Mar 9, 2020 at 8:06 PM
    CTPlatinum
    None Yet
    There you go, I definitely can see an increase with those supporting mods!
    Rica25 and Tundra_power[QUOTED] like this.
  14. Mar 9, 2020 at 8:09 PM
    Tundra_power
    Yes everything works together for sure. But in about 5 months from now im going to do arh or jba longtube headers with bamuffler full 3in dual exhaust. And going to sell the shorties and bamuffler exhaust.
    Rica25 likes this.
  15. Mar 9, 2020 at 8:51 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Google it or look back at post #17. Another pic on #31. Adds another duct or conduit for air to the intake filter.
    Rica25 likes this.
  16. Mar 20, 2020 at 7:29 PM
    TexasArdnut
    TexasArdnut New Member
    Dennis
    2017 Tundra 1794
    Based on dyno results, cold air intakes do nothing. Put your money into a performance exhaust
    Rica25 likes this.
  17. Mar 23, 2020 at 4:21 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    After researching/looking/shopping I decided on a TRD CAI for my 2010. Already have a 10"BA Exhaust and IPT Valve Body/Shift Kit. I expected just what I got. Underhood appearance and a little different sound.Resized_20190717_175425[6917].jpg Resized_20190717_175452[6923].jpg
    GAknight, prevent and Rica25 like this.
  18. Mar 23, 2020 at 4:30 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Toyota cold air intake with drop in AFE Magnum FLOW Pro DRY S Air Filter.
    I already had a DAP tune and BAMuffler cat-back installed, so I did notice a nice increase in throttle response by adding the AFE filter. I don't believe I would have notice a difference if I didn't have a free flowing exhaust.
    Rica25 likes this.
  19. Mar 23, 2020 at 4:33 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Looks good! as long as you're happy with it, more power to you!
    Rica25 likes this.
  20. Mar 23, 2020 at 6:33 AM
    #50
    Rica25
    Ricardo
    Tulare
    Has anyone just added the air tube after the filter box ? If so what part number is it for the 2nd gen
  21. Mar 23, 2020 at 9:16 AM
    #51
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    I believe the top is larger than stock so may not exactly line up. I had that thought too before I went with the AFE super stock system.
    Rica25[QUOTED] and 15whtrd like this.
  22. Apr 22, 2020 at 8:51 PM
    #52
    Tundra_power
    I just put in the trd intake with the sabm still install and man it made a differnce in noise level and power. Yea its just butt dyno but i can really feel it or i could be crazy lol.
  23. Apr 22, 2020 at 8:52 PM
    #53
    Tundra_power
  24. Apr 23, 2020 at 4:49 AM
    #54
    10TundraSR5
    Tennessee
    Did you hydro dip your engine cover?
    Rica25 likes this.
  25. Apr 23, 2020 at 2:46 PM
    #55
    Tundra_power
    Lol i wish i just bought the carbon fiber kit Plasti Dip. Turn out ok but im not really happy with it. But i will get it hydro dip in the future.
