Sun Damage? What's going on here?
Discussion in 'Detailing' started by AK 6.7PSD Replacement, Jul 28, 2019.
  1. Jul 28, 2019 at 5:48 PM
    AK 6.7PSD Replacement [OP] New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    I've used 303 Protectant for 20+ years to keep canoes and kayaks in pristine condition. I use 303 on black trim on vehicles too. Recently my door handles started looking very... damaged. I use the 303 on my mirrors and bumper, mudflaps, etc and they look great. The white-looking flecks on this for handle aren't white, they're reflecting the sun. Is this UV damage or what?B2403EE2-6F44-475C-92D4-72AEFE46F0A8.jpg
  2. Jul 28, 2019 at 6:20 PM
    fordguy1470
    fordguy1470 Member-ish
    West Columbia, SC
    22 CM SR5
    Getting there
    Mine do the same thing, they’re a little sparkly in the sun. I don’t know why... I’ll worry about it if they start to get brittle.
  3. Jul 29, 2019 at 2:54 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I coated my trim with cquartz dlux trim restorer. Looks good and stays that way,
    DZ_, NewImprovedRon and War Machine like this.
  4. Jul 29, 2019 at 7:25 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Go nautical. Get replacements made from brass, custom. Works on boats, should work for you.
  5. Jul 29, 2019 at 10:53 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    My theory: The door handles are possibly molded from glass-filled nylon for strength. The sparkley bits are actually the ends of glass fibers in the plastic that have been exposed by surface wear and deterioration.
    Trooper2 and Pudge like this.
  6. Jul 29, 2019 at 5:06 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    That happened to some of the plastic trim on my wife's Kona. Unfortunately I haven't found a cure.
  7. Jul 29, 2019 at 6:04 PM
    On a 1.5 year old truck with 30k miles? Seems unlikely but I was wrong once before on something so I guess this could be the second time
    NUDRAT likes this.
  8. Jul 29, 2019 at 7:59 PM
    JohnLakeman
    :notsure: Color-matched door handles will fix the problem, whatever the cause. ;)
    NUDRAT and HappyGilmore like this.
  9. Jul 29, 2019 at 8:09 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I know you said the specks are clear, but I'll just throw this out there because I 303 all my plastic too. (Handles are painted). I have the factory folding hard bed cover. I did maybe about 4 treatments to it in 6 months of owning the truck. The bed cover did almost the same thing as your handles but white. I don't think it was clear. There were streaks from wipe marks and specks like yours. The surface is a coarser texture, too.
    My dealer warrenty'd it and I don't use anything on it now. Hope it doesn't chalk up in a few years.
  10. Jul 29, 2019 at 8:13 PM
    HappyGilmore
    Trent
    Lakewood CA
    I'd see if you can warranty them but I wouldnt say that you applied any 303 to them. Keep an eye on them at the end of the warranty and ask for painted ones if it happens again.
  11. Jul 29, 2019 at 8:16 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Do you have a photo?
  12. Jul 29, 2019 at 8:24 PM
    JohnLakeman
    Try cleaning the door handle surface texture with a cloth wet with IPA. If the "white" spots come off, it's the 303 residue in the textured surface. If it doesn't come off, then you're looking at painted or chrome-plated door handles to fix the problem. My experience is that 303 will leave a white residue on weatherstrips, and it takes vigorous rubbing with IPA to remove it. Or, you can just wipe it down with fresh 303 and let the new dissolve the old.
