What tuner?
Discussion in 'Performance and Tuning' started by the07tundra, Dec 7, 2017.
  1. Mar 5, 2019 at 8:40 PM
    #61
    Gatire
    Gatire New Member
    2014 Tundra
    Hey Keith im loving the Bd Tuner. I even noticed a slight mileage increase even though im running the premium tune. Combined with your 6” bam system i’m running, what would you guess the power/ torque estimate to be now? The truck drives lightyears better and sounds great. Its hard to stay outta the throttle. Just curious what you thought might be my gains with the stock air box.
    dirtydeeds likes this.
  2. Mar 5, 2019 at 10:14 PM
    #62
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    do you know the gains from the HPtuner tune?
    dirtydeeds[QUOTED] likes this.
  3. Mar 7, 2019 at 8:31 AM
    #63
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    You’ve gained the higher end of 3-10hp and 10-20tq to the rear wheels over stock;)
    Glad you like it. Thanks for posting!!
  4. Mar 7, 2019 at 8:36 AM
    #64
    dirtydeeds
    Keith
    USA
    Nobody that I know of has written a tune using HPtuners for a truck with stock exhaust manifold naturally aspirated.
    HPtuners doesn’t write tunes. It’s a tool that a good tuner can use to write tunes. Given its resolution it has the capability to more finely tune a tundra than anything else out there, but again, nobody has done this yet as far as I know.
    I worked with Bullydog several years ago to write some custom tunes. And I gotta say, naturally aspirated, our truck are maximized in HP/TQ. There isn’t a lot left on the table by Toyota.
    When tuning said set up, it more about the way the power comes on and how the truck feels.
    That’s why I recommend Bullydog over anything else. They’ve taken the time to offer several options for the way the truck can be set up. They optimize for towing. Economy. Or performance amongst other things. They also remove speed go governor. Customize how the truck shifts. And how the throttle feels.
    No other tuner avaialable for a tundra offers this many options.
  5. Mar 7, 2019 at 8:39 AM
    #65
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    DAP Tune, it's well worth the money.
    I tuned my '07 5.7L 12/01/2018 and I am loving it.
    Note: I had to upgrade my tires to match the new high speed capability.
    Easy installation, and it makes the truck drive like I want it to.
  6. Mar 7, 2019 at 8:41 AM
    #66
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Well then in the case can you PM me price for the BD. I already have your 6" bam system. Does it change the speed of the shifting at all? that's where I feel it needs the most improvement.
  7. Mar 7, 2019 at 8:46 AM
    #67
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    @dirtydeeds, do you know if the BD tuner deals with AIP pump issues like the DAP tune does?
  8. Mar 7, 2019 at 10:09 AM
    #68
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Any word on a unit for the 2018+ models. I’m dying over here!
    NoMoTaco likes this.
  9. Mar 20, 2019 at 8:48 AM
    #69
    dirtydeeds
    Keith
    USA
    I can send either bdx or platinum for $380 shipped. Call to order.
  10. Mar 20, 2019 at 8:49 AM
    #70
    dirtydeeds
    Keith
    USA
    You will want to use the bypass made by HewittTech
    No tuner actually turns off Aip. They only stop the monitor from running. This shows up as a monitor thst is incomplete. You do t want monitors incomplete. Leaving them unchecked is like leaving everything in limbo. The ecu never evolves last thst point.
  11. Mar 20, 2019 at 4:38 PM
    #71
    Samoan Thor
  12. Mar 21, 2019 at 11:26 AM
    #72
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Just installed my bullydog bdx from @dirtydeeds
    This product is the real deal. Trans shifts better, throttle is actually responsive, major power gains in mid/upper range with premium fuel. It really drives like a different truck. You don’t realize just how LAME the factory program is.
    I wish i had bought this years ago
    dirtydeeds, Erichudgins and conlons26 like this.
  13. Mar 21, 2019 at 11:35 AM
    #73
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
  14. Mar 25, 2019 at 11:51 AM
    #74
    dirtydeeds
    Keith
    USA
    Thanks @Hbjeff
    Each unit has its place. Best way to distinguish the difference:
    If you intend to download only one tune, and that’s it. Then the bdx would be most convenient. It can only configure and store one tune. You could change to tow every so often, or economy. Or whatever besides that one tune. But it’s tkne consuming because you have to download it from the internet every time you want to change.
    But if you want to switch between different tunes often. Like economy during the week. Performance just for weekends. And tow on holidays. Then get the gt platinum. It stores 3 tunes and its relatively easy to switch from tune to tune.
    The both offer the same tunes/options. It’s just a matter of which tunes fit your use of the truck best.
    My position since they released the tuner in 13’ has been to help choose options since I’ve tested literally every tune they offer, plus did a bunch of prototyping with bullydog. When I text over the options to use call bullydog and make their tech support team stay on the phone with you until the download is complete.
    It’s actually really easy. Just a lot of steps. Tech support is really good about helping. And they will want to get off the phone when not needed anymore. But I always make em stay on jist for the warm and fuzzy reassurance.
  15. May 24, 2019 at 8:31 PM
    #75
    SilverCedar
    SilverCedar New Member
    2006 Tundra SR5
    Do tuners help 1st gen tundras? I’m only noticing people posting with 2nd gen or newer trucks. I’ve got an 06 double cab 4.7 4x4
    Thank you!
  16. May 24, 2019 at 10:58 PM
    #76
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Savings for a GT I’ll be in contact soon Keith
  17. May 24, 2019 at 11:14 PM
    #77
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I never heard of a major tuner when I had a 1st gen. When you think about it, the gen 1 engine/trans is a lot simpler than the gen 2. There just aren’t as many nanny controls for a tuner to circumvent.
  18. May 25, 2019 at 2:26 PM
    #78
    dirtydeeds
    Keith
    USA
    Alientech provides a tool to break into the ecu on a 05-06, but as of now nobody has taken advantage of this ability.
  19. Jun 4, 2019 at 8:03 AM
    #79
    sundance
    sundance New Member
    Their claims seem to be high to me. Interesting though.....
    Where does it plug inline?
  20. Jun 4, 2019 at 8:17 AM
    #80
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    How exactly does the BD help fuel economy? What tell the engine to do / not do?
  21. Jun 6, 2019 at 3:04 AM
    #81
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    Anybody installed a tuner on a 2019 yet? Can
  22. Jul 1, 2019 at 4:04 PM
    #82
    zeke7681
    zeke7681 New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    I'm wondering the same thing @dirtydeeds
  23. Jul 1, 2019 at 4:54 PM
    #83
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    :help:
  24. Jul 1, 2019 at 6:05 PM
    #84
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    How about OVTune?
    How does it compare with BD for NA trucks?
  25. Jul 20, 2019 at 12:15 PM
    #85
    PNWSuperWhite19
    PNWSuperWhite19 New Member
    Leroy
    2019 Super White Platinum
    Ceramic coating, paint protection, tint, retractable Amp Research running boards, center console safe, debadged, paint matched mirrors and door handles, led lights.
    What’s the price with discount?
  26. Jul 28, 2019 at 5:03 PM
    #86
    Long Bed Yukon
    Long Bed Yukon New Member
    2013 Tundra SR5 Loooong Bed 4x4
    Leveling kit 3/2, deflector, custom seat covers, Firstone airbags / compressor, 1 1/4" Bora wheel spacers, roll up tonneau cover, swing case, driver side retractable step
    What exactly does a bullydog do?? I have a 2013 Tundra, is it worth installing one?
  27. Jan 25, 2020 at 8:55 AM
    #87
    mikemkjr
    mikemkjr New Member
    2014 Crew Max Tundra
    Im just getting into the market for my 2014. It has a cai so would the bd not be the right route to go?
  28. May 7, 2020 at 2:00 PM
    #88
    Mikeylud
    Mikeylud New Member
    Carson City, Nv
    2013 White Tundra Dbl Cab
    6" pro comp lift, 37x13.5r20 nitto ridge grapplers, mayhem wheels, custom exhaust, s&b intake, bullydog tuner, wrapped roof, chrome delete, debadged, aftermarket headlights & tail lights, remote start, aftermarket grille.
    I'm interested in the bully dog for my 13 tundra. Can I install or do I need a professional?
  29. May 7, 2020 at 4:14 PM
    #89
    Tundra_power
    Tundra_power New Member
    Iv only tried s&b and trd intake with bullydog with no problems..
  30. May 9, 2020 at 11:47 AM
    #90
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    BD all the way. Installed mine 3 years ago. I did notice a power increase
