PCV Valve Replacement Instructions-4.7L
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Jan 14, 2019.
  1. Jul 24, 2019 at 5:26 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Here is a look into a 2002 PCV grommet hole after about 10k miles with new valve gaskets service. Prior, this hole was gunked before changing the PCV valve last year. The new valve seems to be working fine, but you can see some cack droppings starting to develop down inside the cover hole.
    Sangre Kid likes this.
  2. Oct 9, 2019 at 4:33 PM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    Are most people replacing because this part fails and throws a code, or age, or if your pulling stuff near it it’s a good idea to just change it out? Thanks
    Tundra2 likes this.
  3. Oct 9, 2019 at 4:36 PM
    FirstGenVol [OP] Brake Czar
    2002 AC
    I've never actually heard of 1 failing. I replaced mine because it was 17 years old and it's a $10 part. It was pretty nasty too.
    Schcoman likes this.
  4. Oct 9, 2019 at 4:45 PM
    The SoAz
    None
    Oh ok. Has anyone here ran catch cans? Cats on the 4runner page were all about them, keeps stuff cleaner, but also lots of nay sayers. Mostly boosted engines that ran them but the theory seems sound.
  5. Oct 9, 2019 at 4:57 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I had one on my old 24 valve Cummins, I liked it.
  6. Oct 16, 2019 at 1:08 PM
    Fred
    Hand Protectors
    Mine (PCV) was all gunked up when I changed it during the valve cover gaskets replacement at 150k miles. Probably had been clogged since 80k miles when I noticed a black soot ring around the PCV area. Didn’t pay much attention to it and drove it another 70k miles which probably lead to early failure of the VCGaskets/tubes.
    Here is a good link which explains things better.
    http://www.agcoauto.com/content/news/p2_articleid/197
  7. Nov 2, 2019 at 12:40 PM
    batsquatch
    batsquatch New Member
    Justin
    Bellingham, WA
    02 Tundra SR5 4WD
    Did this today @ 131k. Was unsure when last replaced but valve didn’t look too bad. Grommet was pretty toasted. Came out in 3 pieces and all accounted for. Truck seems to idle a hair smoother, could be my imagination.
    Filthyphil likes this.
  8. Nov 2, 2019 at 2:41 PM
    The SoAz
    None
    DC3A2B6E-FB78-4724-95BF-4B6AFD103567.jpg I did mine today while swapping injectors, it was pretty nasty.
  9. Feb 7, 2020 at 3:44 PM
    2002 AC
    Been studying the PCV more. It's actually more important than I realized. I want to replace the PCV on my wife's Rav4 but it's a hell of a lot harder to reach. I couldnt even find it initially and had to watch a YouTube video. Bummed that it won't be easy.
  10. Feb 7, 2020 at 3:57 PM
    Fred
    Hand Protectors
    You got this.
    I wish I had replaced mine at the 80k miles mark when I noticed the black soot ring around it. Wonder what is that? Told myself: Myself its a Toyota Tundra and it will last forever.
    Probs why my cam and crank seals have light seeps and why my VC gaskets failed at 130k.
    speedtre likes this.
  11. Feb 25, 2020 at 5:07 PM
    Filthyphil
    Phil
    Pulled my PCV out tonight with plans of getting a new one at the dealer tomorrow when I go to town.
    Pulled the PCV right out no problems at all “was expecting the worst.” PCV was in good condition could hear the valve sliding up and down and could blow easily through it, and there was minimal gunk buildup. I’ve decided to clean it well with mass airflow cleaner because it’s safe on plastic and just check it every 6 months or so.
    revtune, NUDRAT, abcinv and 4 others like this.
  12. Jan 14, 2021 at 4:34 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Do the threaded valves on the later models (03+) still have a grommet to replace? Going to order a new valve online, not seeing a grommet part. Can't tell by looking without starting to tear into it.
  13. Jan 14, 2021 at 4:35 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    No they do not.
    bmc02[QUOTED] likes this.
  14. Mar 21, 2021 at 6:05 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Thank you! Exactly what I needed. Love this community!
  15. Mar 21, 2021 at 9:23 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Hey Guys,
    I bought a spare set of valve covers. I intend to have them powder coated and then
    Swap themout with a new plugs and valve cover gasket.
    My 05 has a grommet style PCV. my spare set has a thread in type.
    will older valve covers work on 05 and 06 engines?
  16. Mar 3, 2022 at 7:45 AM
    kidked888
    kidked888 New Member
    Kansas
    2004 Tundra Double Cab 2WD
    Is this something that needs to be a genuine Toyota part? Or can I just run to the auto-parts store and grab one.
  17. Mar 3, 2022 at 10:16 AM
    2002 AC
    Aftermarket is probably ok but the Toyota part wasn't very expensive a few years ago. Less than $20 I think. Try McGeorge or Serra Toyota for best prices.
  18. Mar 3, 2022 at 10:36 AM
    shifty` Is the Gila Copter a love machine?
    I just swapped my PCV out in my '06 which has same config as yours if V8, and it was thread-in, I removed the OEM part with 72k miles on it. You'll need to do the 4 half-moon plugs at the back of the head (2 on each side) with FIPG also It was $8 from the dealership.
    12204-50030 --
    PCV Valve (Left) $8.29
    I ordered at parts.toyota.com and set it up for store pickup with some other little odds and ends.
    I'm suspicious if you're telling me yours isn't thread-in.
    Don't forget, there's more to valve cover gaskets than just the main gasket. You need FIPG to seal a couple of the right-angle corners, you need the plug hole gaskets (8), new hardware gaskets (18) at least. If you need more info, holler.
    bmf4069 likes this.
  19. Mar 4, 2022 at 4:10 AM
    bmf4069 Yup, that's car parts in a dishwasher
    00-02 just pops in. Kind-of a pain when that has hardens up and keeps trying to pull it out.
    shifty`[QUOTED] likes this.
  20. Mar 4, 2022 at 4:28 AM
    #50
    Festerw
    Festerw New Member
    04 Tundra DC
    We covered it on the first page but 00-02 is the press in, 03-06 is threaded.
  21. Mar 4, 2022 at 5:56 AM
    #51
    Right, but @AV8R4AA is saying they have an '05, which has vvti and should be thread-in.
    Also said he got a spare pair of valve covers of an older model which are thread-in, but that makes no sense unless they were pulled from an '03-'04.
    Seems like there's a conflict here - either someone already installed pre-2003 valve covers into his truck, or the info given is incorrect, or there's something else weird going on here.
  22. Mar 4, 2022 at 10:25 AM
    #52
    Edited to correct. Thanks for the heads up, I gotta quit posting before the brain is fully functional.
    shifty` and Festerw[QUOTED] like this.
  23. Mar 11, 2022 at 5:33 AM
    #53
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Tried to replace pcv on 05 tundra at around 100k miles, could not get it to break loose (thread). Gave it as much as I could while not wanting to break something. So said screw it I'll try another time.
    Ended up using that pcv valve when I bought 06 sequoia with 200k, it came right out no problem.
    Still need to try again on truck.
  24. Mar 11, 2022 at 5:36 AM
    #54
    The SoAz
    None
    Maybe try it when it’s hot(the engine)
  25. Mar 11, 2022 at 5:38 AM
    #55
    2002 AC
    Or like a spark plug, try tiny adjustments to tighten and loosen instead of just loosen.
    bmc02 and FrenchToasty like this.
  26. Mar 11, 2022 at 5:39 AM
    #56
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Yeah I was thinking that, aluminum head expansion vs steel plug... Thing that throws me is how easy the Sequoia was with twice the mileage. Unsure if it was original or not though.
  27. Mar 11, 2022 at 6:03 AM
    #57
    Could just be that some prior person used threadlock when replacing. You never know. Doing while engine is hot is worth a shot.
  28. Mar 11, 2022 at 6:14 AM
    #58
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Little PB blaster application for 3 consecutive days May help. I did my manifold bolts and O2 sensors and they all came out easy. Can’t under emphasize the back and forth with stubborn bolts. It lets the threads clear debris instead of packing it in the grooves.
    bmc02 likes this.
  29. Mar 11, 2022 at 6:24 AM
    #59
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I bought truck at 60k miles and almost certain its the factory valve. But they come with a thread lock/sealant pre-applied. Which would also make removal while hot the best plan...
    I'll try again this spring. With gas prices she's been parked until I need it for turkey hunting season.
  30. May 29, 2022 at 4:04 PM
    #60
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Just did this PCV valve replacement today. It was easy, probably one of the easiest maintenance items ever (with my luck things are usually stuck). The old valve still moved up and down inside the housing but was very dirty. Simple thread-out the old and thread-in the new. Replacement PCV valve used: https://shop.advanceautoparts.com/p/carquest-pcv-valve-pcv549/10099422-P?searchTerm=pcv
    The foam cover on it is nastyyy. When I pulled it off a cloud of particulates puffed out and I'm sure it's a mix of dust and deteriorated foam. Moving it around causes puffs of dust and deteriorated foam to come out, coating my hands. I bet it's more deteriorated foam than dust, but since I don't have another foam cover on-hand I just reused the old one.
    Does anyone know the diameter of the thread-on PCV valve? I used a monkey wrench.
    Also, I'm unsure of how deep to thread in the PCV. As I threaded-in, resistance started to build until the final rotation, with 1 full rotation of decent resistance to get the tube facing out. I could've threaded it in even more but I stopped once I got to similar depth that the old one was threaded in. I didn't want to damage these aluminum valve covers. Comments are welcome on if I stopped too soon or threaded too far.
    tacoguybill and Schcoman like this.
