Help with part number
Discussion in '2nd Gen Tundras (2007-2013)' started by triharder, Jul 21, 2019.
  1. Jul 21, 2019 at 11:46 AM
    triharder
    triharder [OP] Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Help,
    The line between my heater core and pump is rotted. I need the part number and i.m not having any luck.
    Anybody seen this before.
    Part number starts with 87208? But i can.t figure out rest.
    Called a piping sub assy
    Doesn.t show on coolant microfiche or heater microfiche?
    I pm'd roman but im impatient
  2. Jul 28, 2019 at 5:58 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    Okay, thanks to roman i was able to swap this. I also learned something.
    Always check fluid in radiator not just overflow. Never thought to do it and coolant was about 1 gallon low in radiator.
    Swap was about an hour. Pretty simple. I do own a hose removable tool that i recommend for anybody who does this work. Its sharp and is dangerous in a loose tool bag. But helps. I.ll snap a picture.
    Heres the part number and pictures of rotted hose parts.
    Roman and TokerJoker like this.
  3. Jul 28, 2019 at 6:07 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Glad @Roman was able to get the right stuff you needed.
    Roman likes this.
  4. Oct 15, 2019 at 8:46 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    HbbTundra08 and TokerJoker like this.
  5. Oct 15, 2019 at 4:51 PM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    I am a fan of multi-use tools as well as tools that can be used on more than one occasion! Thanks for the link, too.:thumbsup:
