Wheels, powder coat or not?
Discussion in '2.5 Gen Tundras (2014-2021)' started by blandon, Jun 5, 2019.
  1. Jun 13, 2019 at 10:32 AM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    Not mine, but just did a quick search:
    blandon[QUOTED][OP] likes this.
  2. Jun 13, 2019 at 1:09 PM
    blandon
    blandon [OP] New Member
    Butch
    2016 TRD Off Road
    Looking it up to see how far that is from me now!! Thanks!!!
    Borgs[QUOTED] likes this.
  3. Jun 14, 2019 at 10:04 AM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    That turned out clean Sean, subtle but compliments your trucks color well. Did you spray the lug nuts, how would they hold up to a lug wrench? My wheels are powered coated, but Ive wanted to experiment with a bronze color, would it just peel off if I didn't like it?
  4. Jun 14, 2019 at 10:10 AM
    TundraCoast
    Ian
    California
    1794 4x4
    Same as others, had OEM wheels powder coated "textured black" to match the side steps about $65 per wheel.
  5. Jun 14, 2019 at 10:26 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I did spray the lugs and I assume when I rotate my tires the dip will peel off them when i put a socket on them.
    Supposedly the stuff peels off pretty easily, the key is to have a lot of coats, at least 7 from what I read. The thicker it is, the easier it is to peel. They also sell a dip dissolver that supposedly works well but sounds mess, spray on and brush or power wash off.
  6. Jun 14, 2019 at 11:32 AM
    TundraCoast
    Ian
    California
    1794 4x4
    Did you do a step by step on your wheel project? I would need to degrease my wheels big time. What did you prep with.
  7. Jun 19, 2019 at 10:38 AM
    blandon
    Butch
    2016 TRD Off Road
    Thanks Borgs!! I worked out a deal with this guy and I’m picking up these wheels next week!!!
    kgb4187 likes this.
  8. Jun 19, 2019 at 12:28 PM
    ajc2016CM
    ajc2016CM New Member
    Mag grey 2016 SR5 CM TRD Off Road
    Thinking of going the powder coat way. For those that have done it, how does it hold up? Chipping or flaking?
  9. Jun 19, 2019 at 1:11 PM
    WhiteTundra1794
    WhiteTundra1794 New Member
    White Tundra 1794
    none yet
    Mine is tough as nails so far. BTW a paint shop told me that the PC would be much better if the wheel is sand blasted cleaned not solvent cleaned. Mine were sand blasted.
    Black Wolf, Rex Kramer and ajc2016CM like this.
  10. Jun 19, 2019 at 2:28 PM
    kgb4187
    kgb4187 New Member
    I bought these wheels, going to have them powder coated in a dark bronze I think
  11. Jun 21, 2019 at 2:13 PM
    Borgs
    Borgs New Member
    PA
    That’s awesome! Good luck!
  12. Jun 21, 2019 at 9:45 PM
    W Bill
    W Bill New Member
    I'm sure that will look great, OP.
    I'm going to say something different, just for anyone else who might be in the same situation. With a super clean truck like yours already all blacked out, I'd chrome a set of factory wheels. The contrast would pop. Wheels would be stock and custom at the same time. Just a suggestion for anyone looking for ideas.
  13. Jul 5, 2019 at 1:07 PM
    Savagebass
    Savagebass New Member
    Brandon
    MICHIGAN
    2019 TRD Sport
    Front and rear leveling kit Front window tint DIY bedrails Blackout badges
    Blasted and powder coated OEM wheels. Color is called "Blackjack".
    Rica25 likes this.
  14. Jul 9, 2019 at 10:55 AM
    blandon
    Butch
    2016 TRD Off Road
    Finally got the new wheels and tires on!!! Went with KO2 285/65/18. Love the way it looks now!
  15. Jul 11, 2019 at 5:49 AM
    blandon
    Butch
    2016 TRD Off Road
    What exhaust do you have on the truck?
  16. Jul 11, 2019 at 5:55 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Are these available online, or did you have them painted / coated?
  17. Jul 11, 2019 at 7:25 AM
    jtaco11
    jtaco11 New Member
    They look perfect the way they are. Seen some black wheels up close scratches/chips more stuff to stress over
  18. Jul 12, 2019 at 6:42 PM
    blandon
    Butch
    2016 TRD Off Road
    Thank you sir! Exhaust is the next mod on my list, just trying to figure out which one to go with. The dual tip looks pretty slick on your truck!!
  19. Jul 12, 2019 at 7:57 PM
    Donkeypunch
    Donkeypunch New Member
    I paid $375 for all 4 which included sand blasting. But I got a hookup.
    blandon[OP] and kgb4187 like this.
  20. Jul 12, 2019 at 8:16 PM
    #50
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    Cheapest I found around my area outside Houston was 200 a wheel. So for 200 for four sounds good to me.
  21. Jul 18, 2019 at 9:43 PM
    #51
    Rica25
    Ricardo
    Tulare
    Has anyone had issues powder coating the wheels by them ring put in the oven and possibly warping?
