Front cv axle retainer clip part help needed. Where to find one?
Discussion in '1st Gen Tundras (2000-2006)' started by KarmaKannon, Jul 15, 2019.
  1. Jul 15, 2019 at 8:09 AM
    KarmaKannon
    KarmaKannon [OP] Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I am trying to find the little retainer clip that goes on the inner cv side of the front axle shaft. It's the one that is just holding the CV to the axle by it's spring pressure. I took my CV axle apart and got the extended shafts in there but the little wire c shaped clip destroyed itself on the way out. I think it caught the edge of the pipe I was using to slide hammer the factory axle out of the inner cv.
    Anyway if someone can help with a part name or where I should look I'd appreciate it. I've searched around and can't find it online. I'll post pics in a minute.
    Thanks!
  2. Jul 15, 2019 at 8:28 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Can you point it out in this picture?
  3. Jul 15, 2019 at 8:45 PM
    KarmaKannon
    Utah
    Some junk
    No I don't see it. I'm actually an idiot the clip/ring thing is on the hub side. It's what keeps the axle in the hub side CV. I completely forgot to take a picture while I was at the shop today. Too many things on my mind I suppose.
