BBQ pit - Gas / Charcoal, I'm in the market, let's see what you have
Discussion in 'Food Talk' started by TXRailRoadBandit73, Jul 13, 2019.
  1. Jul 13, 2019 at 7:01 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Alright boys and girls, as the thread title says, I'm on the market for either gas or charcoal grill, currently I have both, but are showing their age, the gas one I have is a Ducane 5 burner with a side burner and top rack burner as well, it looks great on the out, it's a stainless steel grill but the inside burner covers are going out, I've ordered em 2x's, all the ignition switches are old and expensive to replace, I have to light with those super long matches, the bottom part that catches the grease to drain down is rusted out, I clean it every time I use, I hate to get rid of because it belong to my father and we had lots of uses with it together
    As for the charcoal one, same story belonged to my father with many uses, it's a Brinkmann and the burner grill can be raised or lowered with a turn of a handle on front, and a door in front as well that comes down to spread fire or to add logs of firewood or coals, it has two side trays that can be put in place or lift up and lay flat on each side, father added wheels so it can move easily around, it's not stainless, it's metal, so the legs at bottom are rotting away and I'd have to weld new ones, both side trays at bottom are rotting away, and I've looked online for parts, can't find anything, hate to part with it
    Like to see what you guys and gals have,
    The other day after work I went to Home Depot and saw one from Char-Griller that was gas AND charcoal, but cooking surfaces were kinda small
    Also, just remembered, I have sitting in the corner in my garage, from my father as well, is an Old Smokey electric smoker, I've never used
    Alright, show me what you got!
  2. Jul 13, 2019 at 7:34 AM
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    Get a weber performer. Combintion of both. Light the charcoal turn the gas off.
    Black Wolf likes this.
  3. Jul 13, 2019 at 7:40 AM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Smoker pit
    No charcoal
    Gas over charcoal for clean cooking
  4. Jul 13, 2019 at 7:50 AM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Well buddy how much $$$$ do you want to spend?
    Heres what I have cooked on for years.
    Started with a weber kettle, 18in, cant go wrong, can do just about anything from grilling thru smoking. Upgraded to a weber performer with the cart, 22in, more space, fancy ash can on the bottom and that cart top is great. Again cant go wrong there can do anything from grilling to smoking...I picked the performer up on clearance for $150, normaly closer to $400.
    Then I got a Egg, great more money to throw at this crap LOL...
    What do I like about the egg, the fact it holds temps better than the weber. I can smoke on that for 20 hours and not need to add fuel, its nuts. I can get it rocking 700 for home made pizza that's pretty damn good, can bake on it. Lots of accessories for it, but the cost, initial set up was $1200.
    You can get other ceramic cookers for half the price, and they perform as well from what I have read, and some of the BGE accessories will work in them. I chose the egg due to a local dealer that delivered and set it up, those things are heavy.
    I have never used gas or the pellet grills so I cant really comment on those.
    Good luck in your quest. Hope this helped some.
  5. Jul 13, 2019 at 7:54 AM
    RLHULK
    Rich
    2022 Silverado LT.
  6. Jul 13, 2019 at 7:55 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Heck I forgot about the Weber smoky mountain, great smokers but not set up to grill, you can but you only use the bottom part of the smoker.
    Newbie_19 likes this.
  7. Jul 13, 2019 at 8:01 AM
    I'm liking the Char-Griller Texas Trio
  8. Jul 13, 2019 at 8:19 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If you haven't bought a grill in awhile, you're going to have sticker shock. My suggestion would be to go on Amazon and search "grills". Figure out what style/features you want, then sort by average review and study the results.
    This is our replacement for the previous same model (Commercial Tru-Infrared, 3 burner w/side burner). We liked the way it cooked, so we bought another. Fifteen percent of Amazon reviews gave it One star, not a good rec. I usually shy away from products with One star reviews in high single-digit percentages, and over ten percent, I shun them.
    https://www.lowes.com/pd/Char-Broil...opane-Gas-Grill-with-1-Side-Burner/1000107411
    They have a four burner model. Indirect infrared cooking does keep the meat juicier, but it still has grilled flavor. Unfortunately, not a lifetime grill due to the painted steel cabinet. I think we got almost seven years out of the first one. Porcelain grill inserts should reduce the maintenance cost. First one, I had to replace grill inserts (SS!) after 3-4 years. The stainless cover and doors is, like all of them, pretty much for show (like on refrigerators). What's the point of wasting SS on the top and doors if you're going to set it on a carbon steel cabinet? :mad:
    If you want long life, those Egg grills ($$$$) may be the way to go, but you'll still be replacing burners and cook surfaces.
  9. Jul 13, 2019 at 8:24 AM
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    All I can say is Traeger
  10. Jul 13, 2019 at 8:29 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've got an older Junior and while I like it I'd look really hard at a Green Mountain or Rec-Tec if I were buying a new one.
  11. Jul 13, 2019 at 8:30 AM
    jtaco11
    jtaco11 New Member
  12. Jul 13, 2019 at 8:30 AM
    JohnLakeman
    What's your address? I want to come by at night and sow some of our good ole' Texas King Ranch Blue Stem crap grass in that putting green. :D
  13. Jul 13, 2019 at 8:34 AM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    For gas it is hard to beat a Webber. I have a Webber that I've had for 11 years that is still in good shape. I've replaced the grates, and flavor bars, but that is it. I also have a Blackstone griddle and a RecTec pellet smoker. They all have their place.
    Newbie_19 and Boerseun like this.
  14. Jul 13, 2019 at 8:34 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Bro I am in the same pot. Had my house built and had the builder add a natural gas hookup in the back just in case. I was thinking a decent gas one and an old school weber for coals. Personally I love the ease of gas but lover the taste of coal. Eventually I want to get a nice smoker or pellet smoker. But thats not right now. Building a house and filling it, moving to TN from HI and paying for a wedding has me tapped out. Honestly I may scroll CL to find a decent used one IDK.
    My gas one will be the infareed ones as my dad has it and I love them for the ease of cleaning
    Boerseun likes this.
  15. Jul 13, 2019 at 9:56 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Lots for great choices. Each option has its benefits and pitfalls so to speak
    As for my egg well I have warmed up and launched. Smoke/roasting brats and beef sausage.
    Be about an hour and a half. Get all nice and smoky.
    516E2C36-6FDB-49FA-904C-59A845B125B9.jpg BD6E1676-9145-4584-B930-F56D94598FBA.jpg
    Ely010606 and driverdog like this.
  16. Jul 13, 2019 at 10:04 AM
    JohnLakeman
    :drool::drool::drool: I'm limited to brats maybe once a year now...bad for my heart. Cheese-stuffed brats has to be the Daily Double. :cheers:
    RLHULK[QUOTED] and jewsNbrews like this.
  17. Jul 13, 2019 at 10:04 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    @Boosted4runner has a nice pitboss that he would recommend.
    I have a charbroil smoker/grill combo that was cheap and works really well.
    Grumpy Uncle and RLHULK like this.
  18. Jul 13, 2019 at 10:18 AM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Traeger fan here.
    I have the Timberland 850 and love it!
  19. Jul 13, 2019 at 10:20 AM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    Does it all, even bakes shit.
  20. Jul 13, 2019 at 10:21 AM
    Grumpy Uncle
    Pat
    CO
    Second the Pitt Boss.
  21. Jul 13, 2019 at 8:28 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Big Green Egg, mostly for smoking and a 17 year old Weber Silver B gas grill with cast iron grates for quick grilling.
    That old Weber just won't die. It even has the original, still working igniter.
  22. Jul 13, 2019 at 8:30 PM
    Aurora CO
    That is real nice.........
  23. Jul 13, 2019 at 8:31 PM
    cmiller219
    Nashville, TN
    Went to CostCo today and they had a Traeger rep selling this size Traeger for $799 said it normally is around $1300
    Wonder if it’s worth to pick it up at $800. How much is a decent gas grill? Half that?
  24. Jul 13, 2019 at 10:28 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Third that pit boss... it is legit for the price, very well made, I haven’t had any issues with it.
  25. Jul 13, 2019 at 11:29 PM
    Grumpy Uncle
    Pat
    CO
    Thanks Matt
  26. Jul 14, 2019 at 4:35 AM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Kamado style grill for me.
  27. Jul 14, 2019 at 4:44 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I think there is a place for both gas and charcoal. And smoker. It all depends on your style. I have 7 grills, because I like to cover all the bases.
    I prefer a real wood fire, and then grilling on the coals from that , but that takes a long time, so it is only done over weekends. During the week I grill on propane, and it works just fine; quick and easy. Then every now and then we want pulled pork or ribs and I fire up the smoker.
    I just recently got a pellet smoker which is a 8-in-1; It can be used for smoking, grilling, searing etc. and I think that might be a good option if you only want one. But it won't work for you if you believe in seeing the flames like the hardcore woodfire enthusiasts do.
    Bigboitundra and porkitt like this.
  28. Jul 14, 2019 at 4:59 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Weber charcoal kettle grill. Dynaglo 3 burner gas grill. Smokin-it model electric smoker.
    jewsNbrews likes this.
  29. Jul 14, 2019 at 5:38 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    I agree. I like having both gas and charcoal. I'm a big Weber fan and have both a Genesis Propane and Performer charcoal grills. I also have their "Jumbo Joe" for travel.
    I prefer the flavor or Charcoal but don't always have the time for that and depending on what you are cooking, its not always worth the extra time IMO so like Boerseun, I'm mainly gas during the week and charcoal on the weekends.
    Boerseun[QUOTED] likes this.
  30. Jul 14, 2019 at 6:28 AM
    Was thinking this one, but cooking area a bit small @RLHOK don't you work at Home Depot??? Heard anything bout this one???
    Like idea that has a small smoker
